Hi Mach1Chris, I noticed if the unit is in the process of booting and then the unit is interrupted (key on/off) it will initialize on the next start-up. Could this be the cause of your frequent initializations? The AV is a pain and I am having the same issue, hopefully someone can figure out how to load to map or main menu.
I think that's probably the issue. Many car ignitions have this bad habit of dropping the accessory voltage when cranking the engine, so the Avic will start booting when you start turning your key, but then if the voltage drops enough during engine crank (I think less than 10V or something) then it'll start the boot process again. Mine always did that, but I ended up solving it with the help of another Avic411 thread which had schematics to wire up a batch of 10 rechargable AAs. You can find it by searching for my posts as it took me a couple iterations to get it right. *** found it here: *** http://avic411.com/index.php?/topic/19417-ignition-mod-on-f900bt/page__fromsearch__1 You might also avoid your issues by turning the key all the way quickly so the Avic doesn't have enough time start that first boot process. -PMS
You know what... i think you guys are right, must be the partial startup. Made sure I start the car right up the last 6 times i've started it now and it hasn't happened a single time. Good catch guys, thanks!
Going to try and get the italian forums UI tweaks added to mine. If I get it all working, I'll post up an addon zip that ryar can add if he wants..
