AVICnet 2.1 for AVIC F series, working OBDII! Updated 2014/04/30
By ryar · Oct 19, 2011in Completed Mods/Themes💬 700 posts👁️ 270,055 views
Page 19 of 28
Posted Jun 12, 2012 · 19:37 UTC#451
Did you delete the iGo save folder? The user lists files inside are required to display shortcuts in the programs, ect menu. Garmin has been removed in this version avicnet 2.1.
not sure where the iGo save folder is located. i cant seem to find it anywhere. the only thing i deleted from the avic2.1 download was the maps and poi's for the USA.
as for the Garmin thats what i though. the folder is still there though. but since i seem to be missing all the extras then itll probably show up when i fix that issue.
Edit: just found the Save folder for iGo and it is still in there. i will go look on the unit in the car in a bit to confirm.
second edit: so for some reason the files in that folder didnt copy over. got it working now.
Thanks Ryar. you are awesome (and others that have helped with this hack)
Edited Jun 12, 2012 by gabbygenier
Posted Jun 12, 2012 · 21:06 UTC#452
Good job gabbygenier, I'm glad you were able to fix the issue. I don't have my unit handy, but if there is a garmin folder with a "run" folder within you just need to add the garmin files and you are all set. There are several sites such as mobilism, gps underground, and mobile passion where you can get those files from. You will then need to create a shortcut leading to it to it in the settings/menu/navigation menu. Map the location as my flash disk/apl4/garmin/run/run.exe and you are all set. You can find unlocked maps on TPB.
PMS, I vaguely recall playing with the use_os_volume=1 command and I remember I set the TTS volume for Primo in the stock iGo settings and somehow those settings took precedence over Primo's. I don't remember any more details unfortunately. Comment out the keybind commands for volume in the sys.txt just in case. Also, try use_os_volume=0 instead, maybe this will force Primo to use it's own set volume rather then the volume the SD music is at.
I never tried using the screen off feature, sorry I can't help you with that one.
Edited Jun 12, 2012 by ryar
Posted Jun 13, 2012 · 01:37 UTC#453
PSM and ryar,
I used to have the exact problem of voice guidance blowing my eardrums alway! But now, I don't have this problem anymore thanks to the use_os_volume=1 directive.
Like ryar, I don't recall exactly what I have done! Something like you would have to adjust the volume of the AVIC when playing MP3 (before launching Primo, I'm talking in an iGo8 mod environment, maybe not in AVICNet ... I never use AVICNet) to match approximately the same volume level as some volume levelS (note the big S) within Primo (you have to play with the free-running knob), before launching Primo. I'm sure that you can do it since I've done it myself ... just play with this idea.
As for the SCREEN OFF corruption, this is again because the Primo is not native to the AVIC HU. If you turn the SCREEN OFF under SYSTEM SETTINGS before launching Primo, you won't have this problem. Try it ... but I'm afraid that there is nothing that we can do about it! :(
Good luck.
Posted Jun 13, 2012 · 12:58 UTC#454
Made the shortcut and it now works, had some issues with it not being correct but it now works. now to get the maps to load :)
Also. just to let ppl know. i used a cheap non powered usb hub and was able to have my ipod and the OBDII reader working at the same time. next ill try adding a usb key with some maps loaded onto it and see if that will work also.
Edited Jun 13, 2012 by gabbygenier
Posted Jun 18, 2012 · 17:04 UTC#455
So does anyone else here use the voice dialing (started by pressing the volume dial) with Ryar's AvicNet2.1 and a f900bt? Currently pressing the volume dial isn't doing anything for me and I suspect it might be a hardware issue, but wanted to confirm that the button does work with AvicNet.
Thanks,
PMS
Posted Jun 26, 2012 · 14:05 UTC#456
Thanks,
PMS
just tested this with my 700bt and it works fine. i know it doesnt help you much but i figured id try it out.
on a completly diff topic. has anyone tried a newer garmin UI? the one currently used is an older UI from garmin. the newest UI with Ecoroute. since our systems have BT i was wondering if wed be able to get this working. http://gbr.garmin.com/ecoroute-hd/ my gf has one for her car and its pretty kool actually.
if someone points me to how to get the UI i would be willing to try it out to see if it would work
Edited Jun 26, 2012 by gabbygenier
Posted Jun 26, 2012 · 18:54 UTC#457
I don't think it's a hardware issue with my AVIC as I just discovered that if you hold down the middle button for a couple seconds it registers as 'mute'.
Hmmm... I'm wondering if that custom CE6 that disables the gyro for f900bt units may also disable voice recognition. I don't believe the Euro versions had voice recognition and I think that custom CE6 was the work of Russians.
I've actually switched back to using iGo8 for navigation as Primo2.0 has a few issues that are becoming deal breakers. Namely, erratic sound volume issues, corruption of "Screen off", and frequent disabling of the backup camera. I'll switch back to a North American CE5 and see if that does the trick.
-PMS
Edited Jun 26, 2012 by PsychoMcSatan
Posted Jun 27, 2012 · 16:15 UTC#458
Aha, finally determined that the middle button does start voice recognition, even with CE6, but only when you are on the AV screen(?)
I'm guessing that the modded navigation functions iGO8 in AvicNet block it for some reason. No big deal though as I rarely use it. It's just an extra button press or two to activate it on off the chance I need to make a call while driving, so no big deal.
My next challenge is to start up hobdrive and end up on the map/navigation screen of iGO8 when I start up the car. I modified Ryar's hobdprimo script, but replacing the call to Primo with 'Show ("iGO8")' only brings me to the AvicNet menu. Show ("MainMenu") brings me to the main menu. I suppose I could simulate button presses to get me there, but is there a direct script call that would bring up the iGO8 map after starting hobdrive?
Thanks,
PMS
Edited Jun 27, 2012 by PsychoMcSatan
Posted Jun 27, 2012 · 20:00 UTC#459
Just took a look and while it does look sweet, I think we're limited to Windows CE based software. I believe the Garmins use their own proprietary OS so it'd be very unlikely that this could be made to run on an AVIC.
-PMS
Posted Jun 29, 2012 · 18:40 UTC#460
-PMS
Booooo. dislike :(
what version is in the files? or how do i find out if its the latest version?
Edited Jun 29, 2012 by gabbygenier
Posted Jun 30, 2012 · 03:16 UTC#461
Hey guys,
I currently run Daftia's Hybrid mod and enjoy it. I was wondering if I could just somehow load HobDrive? I have a few tweaks such as my car as the map pointer that I'd rather not do away with. Plus I have no idea what this mod looks like and I don't think I want primo? TIA
Posted Jul 11, 2012 · 19:20 UTC#462
OK, here are the steps for people experiencing GPS fix issues within Primo (due to gyro sensor), it is for f900bt and x910bt users only:
1) Update the CE5 winCE firmware image using the following steps. For NA units, use the download on the fx3.1 page: http://avic411.com/i...firmware-image/, or you can use this one: http://avic411.com/i...install-guide/. For Euro users make sure you have winCE 5 on your unit. If so all you need is CE6. If you need CE5 you should be able to use the one from the Italian thread: http://www.ulozto.cz/11020524/ce5-rar . Here is how as to update your winCE as per the fx3.1 thread:
1. Insert SD card into AVIC and turn it on.
2. When the pioneer logo comes up, press and hold the menu, map, eject and the reset buttons at the same time. When your screen goes completely blank, let go of the reset button but continue to hold menu, map, and eject buttons. This will bring you to a blue screen, telling you to reset the unit (ignore this), you will have to enter the service combination. Press the volume knob in this sequence and you will see * signs for each push: Up, Up, Down, Menu, Left, Right.
3. Select Wince Upgrade
4. Select Update SD Format
5. Wait until it says restart in the bottom center. Reset the unit and leave the SD card in.
2) After updating to CE5, flash the CE6 winCE image using the same steps as above. It is here: http://www.ulozto.cz...219-wo-gyro-rar.
3) Copy AvICnet on to your unit. Copy maps, pois, dem files, ect.
4) Reboot. That's it!
One thing to note, the CE6 is not actually an update to Windows CE6. It is just CE5 with a few updates and modifications (such as disabling the gyro).
Hi,
there is thus some disadvantages? I mean when I use igo8 I would like the gyro sensor-active ...
Posted Aug 07, 2012 · 02:28 UTC#463
Hi All -
Have downloaded the rar files for AVICnet2.1 along with the password file, but I am getting a corrupt file or bad password error when trying to uncompress.
Main Packages are in the links below:
AVIC Net 2.1:
Download File - 295.1 Mb
The password for the zip file is here: password.rar
AVIC Net 2.0:
NA VERSION:
http://www.wupload.c...ETenglishNA.rar
EURO VERSION:
http://www.wupload.c...etEnglishEU.rar
Please do not share the download or password here or anywhere else!
TTS files for Primo 2.0 are here, note these links don't seem to last long:
Download File - 329.9 Mb
Posted Aug 07, 2012 · 12:45 UTC#464
Try copy and paste on the password.I had similar problems and solved them by trying c and p.
Posted Aug 12, 2012 · 03:48 UTC#465
The links aren't working. Old version is asking for user name and password before you can even download it.
Posted Aug 17, 2012 · 06:01 UTC#466
Hi Ryar,
I want to inform all of you, that TomTom is working now 8) Just download the MAPS copy them to the Root of your SD-CARD without any other folder (if your map is DE_AT_CH_890_4234) just make the Folder DE_AT_CH_890_4234 on the Root of your SD don't copy them in the MAP-Folder. You can only use the maps between 890_4234 and 890_4236 don't forget to activate it. :-P
The GPS:
Choose other NMEA GPS receiver GPS baud rate 57600 and PORT 6.
My problem is IgoPrimo, it crashes always when I try to create a new route. I have my crash.log
------------------ Crash Log Begin -------------------
Current System time: "2012-08-16 14:46:35"
Build version: 9.2.1.179499
Build configuration: Product--ARCHFAM
OS version: 5.0
Uptime: 0 h 4 m 14 sec 0 msec
Memory Stats:
FreeMemory: 1 MB, 148 KB, 0 B
TotalUseableMemory: 53 MB, 412 KB, 0 B
MaxMemory: 53 MB, 412 KB, 0 B
ReservedMemory: 1 MB, 0 KB, 0 B
ActualCacheSize: 10 MB, 656 KB, 606 B
GarbageSize: 9 MB, 147 KB, 482 B
Exception: 0xc0000094
At address: 0x02bd2a80
0x02bd2a80 (A)
WinCE CallStack snapshot (function names unknown - map file \Storage Card\APL4\IgoPrimo\iGO.map not found):
0x26012fe4 (A)
0x26012590 (A)
0x2601275c (A)
0x26012830 (A)
0x265d01f0 (A)
0x02baca40 (A)
0x02bb3da0 (A)
0x9bc0e414 (A)
0x9bc3822c (A)
0x9bc12238 (A)
0x9bc0e32c (A)
0x02bd2a80 (A)
0x26104498 (A)
0x2611af18 (A)
0x26104b90 (A)
0x260d3734 (A)
0x260d28bc (A)
0x260d29b4 (A)
0x260d2a20 (A)
0x260b7ab4 (A)
0x26031fec (A)
0x26035ce4 (A)
0x26634b0c (A)
0x26018fd4 (A)
0x2639052c (A)
0x265dc07c (A)
0x265d2228 (A)
0x2630b484 (A)
0x2630c98c (A)
0x2630c504 (A)
0x2630e84c (A)
0x2630f730 (A)
0x265cff80 (A)
0x265d01a4 (A)
0x265c252c (A)
0x02b8df80 (A)
Global status:
bInFocus: 1
bMouseDown: 0
bInLogic: 0
bInRender: 1
CurrentState[128]: st_EasyNav
GPS Pos: (11.878152,43.477958)
Camera: pos:(11.878152,43.477958) rot:0 persp:7000 zoom:100.000000 eng=0)
State queue:
0. st_MainMenu
1. st_EasyNav
Waypoints:
0. roadpos:(11.878010,43.477941) realpos:(11.878152,43.477958) Name:Strada Statale Umbro Casentinese Romagnola, 52100 Arezzo, Tucciarello
1. roadpos:(11.877634,43.479689) realpos:(11.877825,43.479710) Name:Strada Statale Umbro Casentinese Romagnola Arezzo, Tucciarello
Route Parameters:
Vehicle type: Car
Planning method: Fastest
User pref. mask: 0xEDA
Correctness: 88
User u-turn penalty: 3000
Maps:
map\Belgium_R3_NQ_2012.Q1_120522.fbl ver:0x02ea time:0x4fbbbe89 cid:2122813
map\Czech Republic_R3_NQ_2012.Q1_120522.fbl ver:0x02ea time:0x4fbbbe89 cid:4744253
map\Czech Republic_R3_NQ_2012.Q1_120522.fbl ver:0x02ea time:0x4fbbbe89 cid:4752445
map\France_R3_NQ_2012.Q1_120522.fbl ver:0x02ea time:0x4fbbf360 cid:7005245
map\France_R3_NQ_2012.Q1_120522.fbl ver:0x02ea time:0x4fbbf360 cid:7013437
map\France_R3_NQ_2012.Q1_120522.fbl ver:0x02ea time:0x4fbbf360 cid:7029821
map\France_R3_NQ_2012.Q1_120522.fbl ver:0x02ea time:0x4fbbf361 cid:7046205
map\France_R3_NQ_2012.Q1_120522.fbl ver:0x02ea time:0x4fbc152d cid:7078973
map\France_R3_NQ_2012.Q1_120522.fbl ver:0x02ea time:0x4fbc1d74 cid:7095357
map\France_R3_NQ_2012.Q1_120522.fbl ver:0x02ea time:0x4fbbf361 cid:7119933
map\Germany_R3_NQ_2012.Q1_120530.fbl ver:0x02ea time:0x4fc61921 cid:8569917
map\Germany_R3_NQ_2012.Q1_120530.fbl ver:0x02ea time:0x4fc61921 cid:8578109
map\Germany_R3_NQ_2012.Q1_120530.fbl ver:0x02ea time:0x4fc61922 cid:8586301
map\Germany_R3_NQ_2012.Q1_120530.fbl ver:0x02ea time:0x4fc61922 cid:8594493
map\Germany_R3_NQ_2012.Q1_120530.fbl ver:0x02ea time:0x4fc61922 cid:8602685
map\Germany_R3_NQ_2012.Q1_120530.fbl ver:0x02ea time:0x4fc61922 cid:8610877
map\Germany_R3_NQ_2012.Q1_120530.fbl ver:0x02ea time:0x4fc61922 cid:8619069
map\Germany_R3_NQ_2012.Q1_120530.fbl ver:0x02ea time:0x4fc61923 cid:8627261
map\Italy_R3_NQ_2012.Q1_120618.fbl ver:0x02ea time:0x4fdf5b14 cid:10593341
map\Italy_R3_NQ_2012.Q1_120618.fbl ver:0x02ea time:0x4fdf5b15 cid:10609725
map\Italy_R3_NQ_2012.Q1_120618.fbl ver:0x02ea time:0x4fdf5b15 cid:10617917
map\Italy_R3_NQ_2012.Q1_120618.fbl ver:0x02ea time:0x4fdf5b15 cid:10626109
map\Italy_R3_NQ_2012.Q1_120618.fbl ver:0x02ea time:0x4fdf6fe8 cid:10650685
map\Luxembourg_R3_NQ_2012.Q1_120522.fbl ver:0x02ea time:0x4fbbbe91 cid:12076093
map\Netherlands_R3_NQ_2012.Q1_120615.fbl ver:0x02ea time:0x4fdb11e6 cid:14181437
map\Poland_R3_NQ_2012.Q1_120522.fbl ver:0x02ea time:0x4fbbbe96 cid:15262781
map\Poland_R3_NQ_2012.Q1_120522.fbl ver:0x02ea time:0x4fbbbe96 cid:15270973
map\Poland_R3_NQ_2012.Q1_120522.fbl ver:0x02ea time:0x4fbbbe97 cid:15279165
map\Slovakia_R3_NQ_2012.Q1_120522.fbl ver:0x02ea time:0x4fbbbe9b cid:18367549
map\Liechtenstein_R3_NQ_2012.Q1_120522.fbl ver:0x02ea time:0x4fbbf454 cid:22561853
map\Monaco_R3_NQ_2012.Q1_120522.fbl ver:0x02ea time:0x4fbc1d74 cid:23086141
--------------------- LUA stack ----------------------
Lua stack[ 0] :
Lua stack[ 1] :
Lua stack[ 2] :
Lua stack[ 3] :
Lua stack[ 4] :
Lua stack[ 5] :
Lua stack[ 6] :
Lua stack[ 7] :
Lua stack[ 8] :
Lua stack[ 9] :
Lua stack[10] :
Lua stack[11] :
Lua stack[12] :
Lua stack[13] :
Lua stack[14] :
------------------- Crash Log End --------------------
Can you see if this is a memory problem.
Regards
Edited Aug 17, 2012 by Travolta
Posted Aug 17, 2012 · 07:31 UTC#467
I think Primo runs best with 128 M of Ram,and doesnt like our 64!I am running it on a WayteQ stand alone unit and it runs like a dream.When I try it on my F900 or F500 it crashes.
Posted Aug 19, 2012 · 06:12 UTC#468
Same problem...links shut down. Any ideas?
Posted Aug 20, 2012 · 22:07 UTC#469
Re-upped on the 2nd post of this threead. It looks like oron shut down.
Edited Aug 20, 2012 by ryar
Posted Aug 20, 2012 · 22:42 UTC#470
Awesome, thx! Are there voices included in the package?...guess I'll find out shortly! Cheers!
Posted Aug 21, 2012 · 01:30 UTC#471
Primo voices re-upped as well, the link is on the bottom for post #2.
Posted Aug 21, 2012 · 03:46 UTC#472
You rock!! As an FYI in case anyone else is out there the link for the TTS is still dead, but if you go to address manually it's there. Thanks again!
Posted Aug 21, 2012 · 12:27 UTC#473
Hi Ryar Nice to hear from you,hope you are well.
Posted Aug 21, 2012 · 18:49 UTC#474
Thanks ovallball, nice to hear from you too. How is your f500bt? Mine crapped out; the digitizer broke and would not accept touch screen commands. Too bad, at least I got several years heavy use out of it before it bit the dust.
Posted Aug 21, 2012 · 20:28 UTC#475
So after spending my whole day off on this I'm running the Italian version with ryar's tts file. Talk about breathing new life into an AVIC (F90BT)! Absolutely amazing! It runs smoother than it literally ever has. All the audio works as well with the Italian storage card files. Only issue as of now is language stuck on Italian on stock igo and settings files. Other than that this is pretty damn sweet!
Page 19 of 28
