new HDD support
By Jaloga · Dec 17, 2011in Hacks/Mods💬 20 posts👁️ 6,173 views
Posted Dec 17, 2011 · 14:43 UTC#1
It ma broken my hard drive, and I bought a new one, but not like I have to make 4 partitions, please need help
thanks you
Posted Dec 20, 2011 · 20:16 UTC#3
where I can find a Toshiba hard drive?
Posted Dec 21, 2011 · 04:03 UTC#4
You can try ebay, or i sell them in the classified section. See link below.
Posted Dec 22, 2011 · 11:34 UTC#5
I have the Toshiba 60 GB, now that's what I do? original hard drive is 30 GB Avic,
What should I do to create partitions, please I need help
Posted Dec 23, 2011 · 14:14 UTC#6
Start by reading the sticky posts in this forum, especially http://avic411.com/index.php?/topic/663-z1-z2-and-z3-hdd-faq/
Overview of process:
Unlock stock drive
Disable security on both drives
Use acronis backup software to ceate a backup image of the stock drive
Use acronis to restore the back up image to the new drive
Good luck.
Edited Dec 26, 2011 by garrettoomey
Posted Dec 24, 2011 · 08:51 UTC#7
It serves a toshiba GACE? or just the Toshiba GAX?
worth a Hitachi at 54 rpm?
Posted Dec 25, 2011 · 20:06 UTC#8
I have a 40GB Toshiba hard drive at 5400 rpm GAS, it is recognized that the avic?
Merry Christmas
Posted Dec 26, 2011 · 00:01 UTC#9
Yes a 40gb gas drive should work, but i recommend GACE or GAX.
Posted Dec 26, 2011 · 17:33 UTC#10
thanks you
Posted Dec 30, 2011 · 20:57 UTC#11
formatted in FAT32 or NTSC?
Posted Dec 31, 2011 · 14:01 UTC#12
Fat32
Posted Jan 02, 2012 · 19:54 UTC#13
Thanks you
Posted Feb 01, 2012 · 18:29 UTC#14
I have a problem making a restoration of the backup image does my HHD I do not see it on my computer
help
Posted Feb 02, 2012 · 19:12 UTC#15
Is the drive unlocked? If not, you won't see it on your computer.
Posted Feb 02, 2012 · 21:27 UTC#16
and what should I do?
Posted Feb 03, 2012 · 10:00 UTC#18
Thank you,
I will explain what has happened to me, I bought a second hand hard drive and it worked perfect and I used to put data and perfect, was in NTSC format it to FTA32
When I prepare to go back next that I have in the pen drive to pass on the hard disk, foodservice and at the end because I did not see the hard drive in my PC, but appeared in Device Manager, but I can not to it, put it on the Z but I say put it unusable disc. but to bring it to the PC if appeared in device manager but I got into the BIOS and it seemed,
At it's because the disc does not see the PC and the disk unusable Z tell me? I did something wrong? not to work the hard drive?
thank you
Edited Feb 03, 2012 by Jaloga
Posted Feb 24, 2012 · 23:25 UTC#19
Just buy a drive from garrettoomey. You won't regret it, and won't have to worry about any of this stuff. Plus you can always update the maps later to his drive since it'll be unlocked permanently.
I was a satisfied customer, about 3 years back!
Posted Sep 30, 2012 · 15:50 UTC#20
Thank you,
thank you
Did you fix your drive? I'm in a similar situation: I removed the HDD from the Z unit and started to run the upgrade frm Acronis 10. At one point the message "The archive is corrupted" shows during upgrade and from that time the hdd became unreconized on the PC (vizible in Disk Management but uninitiated...) and reported as hdd can not be used on the Z unit.
If anybody have a sollution please posted here.
Thanks.
