x920bt firmware and map upgrade to CNSD-210FM for free?
By Starseed99 · Dec 26, 2011in Hacks/Mods💬 103 posts👁️ 65,422 views
Page 2 of 5
Posted Jan 17, 2012 · 19:29 UTC#26
thanks for explaining that .dll file was holding me back from upgrading worked like a charm now enjoying the update
many thanks
Posted Jan 18, 2012 · 22:40 UTC#27
aside from the upgraded maps does it help interface with iphone any more than what it does already? ex Netflix like my 4300DVD did.
Posted Jan 20, 2012 · 18:10 UTC#28
Mine I had to touch top left also for exact version
Edited Jan 20, 2012 by TeamRiceRacing
Posted Jan 22, 2012 · 12:53 UTC#29
Thank you, this worked perfectly.
Posted Jan 22, 2012 · 23:44 UTC#30
Hello ppls I have a 920bt and have tryed to update and its not working . My reciever is at 02.000 and when I try upgrading to 2003 , it doesnt see sd card . When I put the cnsd-210fm from pirate bay it trys to work just the password doesnt . I have tryed all sorts of things . Can anyone lend a hand?
FreeTime
Posted Jan 23, 2012 · 06:31 UTC#31
I tried this today, and i think I got everything to work. I was wondering, under AV mode, what is "Mirror AV"? Also, I noticed the Pandora button is now gone in AV mode. Is it gone or is it somewhere else?
Also, thanks to the OP.
Edited Jan 23, 2012 by fredyfunk
Posted Jan 23, 2012 · 20:01 UTC#32
Ok I finally figured it out . It worked just as the directions said when I had my truck running. Wierd I guess, but it updated all is working fine. So I wanted to shout out to all u that made this happen. THX
FreeTime
Edited Jan 23, 2012 by FreeTime
Posted Jan 27, 2012 · 00:42 UTC#33
Ok so I confirm this works and the unit is updated with no problems, I wanted to wait till I drove 50 kms before posting that it works just in case...
The procedure is quite easy, download the crack above and the official 2.03 update from pioneer, overwrite the two files in the official update and put that on a SD card and the system will update to version 2.04
Next once that is done, take the SD1 dir from the update file and put that on a SD (needs to be bigger then 2gig) insert SD like normal and the system will ask a few questions say yes/ok to all and once you are presented with a question for the password type the following on screen PASSWORDPASSWORD and hit ok. Should take about 22min to update and restart...
Now take the SD2 directory from update and put on the sd and insert that go into the bluetooth settings and then firmware update to start that update it will goto 3.22
So everyone can now enjoy new maps and firmware 3.01 as per the above files...
I've only tested this on the x920bt and have no idea what it will do to other units
i tried THE password and it doesnt work i put PASSWORDPASSWORD
Posted Feb 05, 2012 · 02:54 UTC#34
Worked like a charm, thanks!!
Posted Feb 09, 2012 · 17:43 UTC#35
Worked perfectly!
Posted Feb 17, 2012 · 04:15 UTC#36
OK maybe I am missing something... I put the password PASSWORDPASSWORD in and it just says retype password OK, and I do it again and again, and again...
Any thoughts? Anyone?
BTW, I read the posts several times, and believe I upgraded to 2.04 correctly, it said 100%
Edited Feb 17, 2012 by gl35
Posted Feb 17, 2012 · 21:25 UTC#37
If the password isnt working then when u did the hack part u must not of replaced the files correctly.The procedure is quite easy, download the crack above and the official 2.03 update from pioneer, overwrite the two files in the official update and put that on a SD card and the system will update to version 2.04 Then run the sd1 file with the new maps and the passwordpassword should work.After that then run the sd2 file in your machine. U will have run the sd card 3 times in your reciever, the 2003 with hacked files in it, then the sd1 that wants passworpassword, then the sd2 file to update the bluetooth.It didnt work for me until I had my engine running but but but finally it worked. good luck
Edited Feb 17, 2012 by FreeTime
Posted Feb 18, 2012 · 08:59 UTC#38
i'll try again... I can swear I replaced the files correctly. One is in the first directory the other is one more directory deap for the 2.04 patch, which I downloaded the 2.03 from Pioneer.
Thanks. I will give it another go tomorrow.
Posted Feb 18, 2012 · 17:12 UTC#39
worked perfectly except the bluetooth firmware, which I don't care much about.
Posted Feb 19, 2012 · 21:55 UTC#40
Went back in to do the 2.04 update again, and it does not recognize it... as if it has been done already.
Am I supposed to use the euro maps? I'm going to try a different card now
Edited Feb 19, 2012 by gl35
Posted Feb 19, 2012 · 22:03 UTC#41
The 2.004 hack will not load again, the first time it did, now it does not boot to it.
anyone got any ideas?
What I did so far.
downloaded the 2.004 patch, copied the two files over the the two from the Pioneer 2.003 from the Pioneer web site.
copied them to an sd card. put the card into my x920bt and it said it upgraded to 100%.
downloaded the CNSD-210FM from the torrent copied contents to my sd card, put it in my x920bt. It asks would I like to upgrade, I say yes. It asks for password i put in PASSWORDPASSWORD, it says enter again, I say OK, it says enter agian I say OK. over and over till I turn the car off.
I upgraded the BT to 3.22, that seems to have took.
on the system screen when I hold my finger on the top left it says I am at 2.003
Posted Feb 25, 2012 · 20:34 UTC#42
can i try this formula: first, i have Avic X920BT, ...with the original up date from pioneer web site and it's working with yhat crack?...all a want its to transorm my US maps to an european ,...with this a mention abouve it;s working? Please help!
Regards, Ciprian
Posted Feb 25, 2012 · 20:41 UTC#43
Starseed, please confirm if that " CNSD-210FM " it is for US or Europe? 10x .
Posted Mar 04, 2012 · 17:41 UTC#44
hello all. trying to figure out this upgrade. I replaced the two files on the original update I also put the SD1 folder from the maps update. The radio updated 15 files in about 4 minutes. So I doubt that the maps were updated. Please help me update the maps, maybe I'm missing a step
Posted Mar 04, 2012 · 19:37 UTC#45
I figured out what I was doing wrong!! I wasn't taking the files out the SD1 folder and making it the root. Now i would like to know what significant changes were made to the unit through these upgrades besides new maps
Posted Mar 05, 2012 · 21:32 UTC#46
hello,
having problem with the sd1 and sd2 update. the patch update to 2.04 worked, i see where it changed in my system info. just can't get themap update to work. any ideas. when i put the card in the unit, files come up and start playing sounds like japanese music. funny. only 6 wave files. any help is appreciated.
Posted Mar 05, 2012 · 23:31 UTC#47
Figured it out, had all the files in a folder on the card. put the in individually and worked like a charm. what feature is the Mirror AV
Posted Mar 12, 2012 · 23:59 UTC#48
I have an X920BT.
SD1 update went smoothly, but I can't get the SD2( bluetooth ) update to run. I currently have BT v.3.11. From what I understand, SD2 should update it to v.3.22
Am I correct to assume that the SD2 update won't start automatically like SD1?
You insert the SD card, then go into settings-->bluetooth, then hit the Firmware update button, correct? I tried that, but the button is grayed out.
I tried paying around with the way the SD2 files are arranged on the root directory, but it's still unresponsive.
Anyone have this issue?
Edited Mar 13, 2012 by 93notchlx
Posted Mar 16, 2012 · 19:30 UTC#49
Anyone have updated fileshare links. The original posts CNSD-210FM_US download link is not working anymore.
Thanks,
JG
Page 2 of 5
