Jailbreak Appradio / Appradio Plus
By Dejan · Feb 02, 2012in AppRadio, AppRadio 2, AppRadio 3💬 621 posts👁️ 281,903 views
Page 12 of 25
Posted Apr 18, 2012 · 18:44 UTC#276
how can I find the instructions?
mini instructions - aboutscreen in the setup
Posted Apr 18, 2012 · 19:15 UTC#277
Pour ton bug au niveau du son, c'est simple pour le resoudre tu lance un mp3 ou la radio avant de lancer APPRADIO PLUS et tu aura plus se pb :)
Ensuite pour le second tu aurais pas à tout hasard appuier sur le bouton centrale de ton appradio ????
Pour quitter Appradio plus toujours utiliser le bouton 'EXIT" qui se trouve à la fin des icones sinon vous aurez constament des bug d'affichage.
Merci pour ces precisions..... je teste demain !!! :shock:
Posted Apr 18, 2012 · 19:18 UTC#278
bah oui, quand tu sors, c'est exit !!!!!!!!!! pffffffffff :P
Posted Apr 18, 2012 · 19:29 UTC#279
Rhoooooo... c'est pas beau de se moquer.... :mrgreen:
Posted Apr 18, 2012 · 19:34 UTC#280
Appradio Plus 2.2 by Sshery with multilangue FRENCH / ENGLISH / RUSSIAN :
http://dl.dropbox.co...plus_22_245.rar
Dejan, you get the old file language.ini, take a new one - in your translation errors in the variables (for example, msg_setup_param8 = "Time Zone")
language.rar
Edited Apr 18, 2012 by SSerhy
Posted Apr 18, 2012 · 20:03 UTC#281
language.rar
SSerhy,
First off thank you for your efforts. I really appreciate what you are doing for the Appradio community.
My question is about the installation process. I am currently on 2.45. I'm assuming all I need to do is download the AppRadio_plus_22_245 file and put on a sd card and that's it? Or do I need to download stock 2.45 firmware from the Pionner website and replace files from the rar file? Please let me know. Once I spend more time on this I will make an effort to contribute to the English speaking community in any way.
Edited Apr 18, 2012 by elrey
Posted Apr 18, 2012 · 20:13 UTC#282
Sserhy can you explain all the features of appradio plus?
then....I don't understand how can install navi or other apps... The apps remains in the appradio memory or in the SD card?
igo for example... or other apps.... what procedure should I follow to install?
Posted Apr 18, 2012 · 20:40 UTC#283
yes, for install, just unrar package in your microsd , insert card in your appradio, turn on appradio, select language, install package, reset appradio (turn off you auto 5 min for restart)
1. put program in sd card
2. edit file in sd card: Appradio\System\Menu\iPhone\icons.xml
3. update files Appradio+
I find it hard to write in English, I can write in Russian )
Posted Apr 18, 2012 · 20:46 UTC#284
language.rar
Thanks you :)
Posted Apr 18, 2012 · 20:48 UTC#285
Thank you SSerhy. I'll take things from here. Like I said I will install Appradio+ this afternoon and try to explain everything for the English users.
Posted Apr 18, 2012 · 20:48 UTC#286
here my igo :
http://dl.dropbox.co...1548666/APL.rar
3d map avaible (in city supported), no warning message, full activated, multilang ect...
French map in this version (Q3 2011) but simply add your map works perfectly (.fbl)
demo video in igo thread.
Edited Apr 18, 2012 by Dejan
Posted Apr 18, 2012 · 21:04 UTC#287
Thank U Dejan!!!!! I will try it after download is complete!
Posted Apr 18, 2012 · 21:04 UTC#288
Update of 2.22 with french language :
AppRadio_plus_22_245.rar
Posted Apr 19, 2012 · 11:18 UTC#289
Could someone up and english version of Dejan's patched firmware and also can anyone explain why I get the incorrect time zone and it is very hard to change the time in the control panel
Posted Apr 19, 2012 · 12:51 UTC#290
in the latest version everything should work correctly
also, if iphone is connected, then after a while the clock is adjusted automatically by gps
Posted Apr 19, 2012 · 12:54 UTC#291
Hi Sserhy for me gps say a wrong time... I am correctly set Gmt, but gps say a other time, but when i launch igo automatly time set right... :-S
Edited Apr 19, 2012 by Dejan
Posted Apr 19, 2012 · 14:26 UTC#292
Anyone got an english version of this yet, I assume this is the one with working sound etc ?
:mrgreen:
Posted Apr 19, 2012 · 16:29 UTC#293
All version have english language, but all version sound dont work... Problem with wince
Posted Apr 19, 2012 · 19:40 UTC#294
What doesnt havent sound? Wince or the applications them selves?
Edited Apr 19, 2012 by elrey
Posted Apr 19, 2012 · 20:23 UTC#295
I've noticed a few bugs that affect the running of igo etc :
1.) When using the volume buttons or any buttons on a steering wheel, black lines develop on the Igo and Wince GUI
2.)As indicated before the default time and date is Jan 2009, even when changed in Control panel and the App radio settings it reverts back to this default time, eventhough it is saying it is GPS time it is not, is there anyway to adjust or resync this ?
3.) No sound from Win CE apps, as Dejan has pointed out it is a Win CE issue but any smart people out there care to take the challenge and get it working.
Posted Apr 21, 2012 · 19:06 UTC#296
attention, if you choose skins in first igo version ( igo of the first page ), it bugs because the skin files is empty....you have to say ok every time....and after 10 times or more pushing ok, you can take control but igo always want to redirect to the last skins choosed....( don't know how to force back initial config )
even after reboot, it says file empty and you can't use igo...so...be carrefull...
Second thing, if you get out by not choosing "exit" button it can "freeze" the "normal" fonction of appradio....only volume works....
i 'll try to uninstall and get it back in order...
Posted Apr 21, 2012 · 22:58 UTC#297
after a few days,I decided to return to the original firmware.I found several problems with appradio plus...The most serious bug occurred when I disconnect the iphone while igo software was running: the screen went black with small green dots,and it was necessaryto reboot the radio. I appreciate the effort being made by the community to add new features or solve problems of the original firmware,but I think it'sbetter to have fewer features and do not go crazy...at least for now!
Edited Apr 21, 2012 by pistillo99
Posted Apr 22, 2012 · 07:33 UTC#298
it's real we must manipulate this carrefully.
But what's really cool from sserhy it's that we can uninstall it to get back to standard.
normally pioneer will release new updates, but looking bugs in new appradio 2 too....don't make me think something "better" will come ;(
Posted Apr 22, 2012 · 11:27 UTC#299
set the time zone in settings appradio +
still does not work?
Posted Apr 22, 2012 · 13:08 UTC#300
sserhy, even if you set time zone ( unless i've downloaded wrong version app+ ) it still react the same with time setting....
but dejan found another version of igo where we can select to not "sync" time zone...just normal adjust of time , nothing else...
i've just done it, with setting too in app+, it seems to be correct....i'll tell you "asap"
Page 12 of 25
