Hi Dejan!
I have mounted an sph da02 on my car and i want to jailbreak it! I have the 4.17, what i have to do? This?:
1. update to the latest sph-da02 firmware 4.17.
2. download the sph-da01 firmware 2.64
3. extract the files from AppRadio_plus_26_264.rar, but not the appradio directory.
4. extract the CE66 folder from the sph-da01 firmware.
5. boot up the deck with the sd card. This will boot the deck to the desktop.
6. click start, programs, windows explorer. select the SD card directory. double click on the "UpgradeMPU.exe" this will install the sph-da01 firmware on the deck. when prompted, remove the SD Card before rebooting.
7. reboot the deck, check to make sure everything is working, you can check the firmware version on the settings page.
8. now extract all the files and folders from the AppRadio_plus_26_264.rar to the CD card.
9. reboot the deck again with the SD card in and start the install of the appradio plus.
10 remove the SD card after the install.
11 reboot and verify, you should see the new background on the screen.
When he says extract, i have to put the files into the sd card and run it on the appradio? There are any videos with the process?
Thanks a lot!! And sorry for my english!
