Jailbreak Appradio / Appradio Plus
By Dejan · Feb 02, 2012in AppRadio, AppRadio 2, AppRadio 3💬 621 posts👁️ 281,903 views
Page 23 of 25
Posted Apr 24, 2013 · 21:28 UTC#551
Ne radi za sph02 samo za sph01
Nagodio sam ba Dejo radi kao svajcarski Sahat ubacio sam software od sph01 u moj sph02 app radio i poslije toga instalirao appRadio plus i radi pravo sada rastura.....Hajde Pozdrav iz Hamburga.....
Posted Apr 25, 2013 · 18:37 UTC#552
Jel radi ??? Znaci nema vise warning message ???
Posted Apr 26, 2013 · 16:05 UTC#553
Can some of you smart french guys please make a how-to guide on installing this? (maybe in the topic start?) With the right links etc?
Because alot of non-french folks here don't seem to get it... (including moi! ;-) )
I'm stuck. I installed Apradio+ software (it sayd installation succesfull) but i don't get the additional menu. Everything is still the same as before...
Is there btw any method to speed up the appradio because its slooooow takes ages when it's booting up before you actually see the menu and everything.
Posted Apr 27, 2013 · 16:33 UTC#554
Because alot of non-french folks here don't seem to get it... (including moi! :wink: )
 go into the settings menu of the iphone and scroll down to appradioplus and open it? In there is where you will find the setting for what will show up on the radio. Also a major complaint of the Appradio is its slow boot time. No fix that I know of.
Posted May 08, 2013 · 18:23 UTC#555
Eehm.. settings menu on the iPhone?? I don't have a appradioplus app on my iphone, and there is none @ the store... (or do you need to have a JB for this?) i saw youtube vids wich showed an extra menu on the appradio with wich you can run iGo navi from an SD card without the iPhone...
Posted May 08, 2013 · 20:47 UTC#556
It is below Facebook in the setting menu on a jailbroke iPhone. It called AppRadio Extensions. Show in Menu
Posted May 09, 2013 · 05:58 UTC#557
No need jailbreked iphone.
In sphda01 just go in setting menu in your appradio for open appradio plus.
Posted Jun 20, 2013 · 05:58 UTC#558
Hello
Is it possible to make a firmware for appradio 2??
Posted Jun 20, 2013 · 11:14 UTC#559
Hello
No...
Posted Jun 20, 2013 · 12:19 UTC#560
No...
Yes, there's just no one working in it
Posted Jun 23, 2013 · 23:52 UTC#561
Hello everyone,
Please if anyone can help me, I'm grateful.
I have the AppRadio (sph-DA01) with version 2.63 and tried to install Jailbreak (SD_AppRadio_plus_25_263.rar of page 28), proceeded as follows:
1 - I formatted the memory card and put the contents of the folder SD_AppRadio_plus_25_263.rar to the root of the card as follows: ce66tool, ce66tool.mscr, mortscript, readme, toolhelp.dll and the folder AppRadio.
2 - I turned on the AppRadio and put the card, then I made hard reset (the button next to the micro sd).
The AppRadio turns on but does not install anything, I tried several times and never installed, just connect normally.
I'm doing something wrong? if so, what?
Sorry for the English, I'm Portuguese.
Thanks in advance
Posted Sep 05, 2013 · 10:39 UTC#562
Hello everyone,
Thanks in advance
Does you format your microsd in fat format?
Posted Oct 23, 2013 · 17:00 UTC#563
jailbreak appradio sph-DA01)  version 2.64
Posted Nov 10, 2013 · 14:39 UTC#564
Since Pioneer was so gracious to update the AppRadio 1 for iOS7, is there any news of development on a new jailbreak for 2.64?
Posted Dec 15, 2013 · 21:21 UTC#565
bonsoir a tous je suis a la recherche d'une application mp3 et divx pour wince du sph-da01
merci
Posted Dec 29, 2013 · 19:27 UTC#566
Sph-da01 is finish... abandon and too old :-(
The best is is one iphone or ipod touch ios 5 jailbreaked and backgrounder installed with activator.
Lagaloche aucune possibilite, les driver audio non jamais pu fonctionne sous mips car en gros la partie hardware c'est de la daube!!!!!
Posted Feb 15, 2014 · 11:45 UTC#567
Update for Appradio Plus 2.64 (full compatibility with IOS 7.x)
Edited Feb 21, 2014 by Dejan
Posted Feb 15, 2014 · 17:14 UTC#568
Hallo bakiraga,
wie hasst Du die Firmware des SPH-01 auf das SPH-02 bekommen? Viele Grüße aus NRW
hello bakiraga,
how do you hate the firmware of the SPH-01 on the SPH-02 get? Many greetings from NRW
Edited Feb 15, 2014 by nudels64
Posted Feb 18, 2014 · 08:09 UTC#569
Läuft dieses AppRadio+ auch auf einem AVH X2500bt???
Posted Feb 21, 2014 · 17:24 UTC#570
I know this is an old thread but is there a working version of this for the Appradio 1 with version 2.64 software?
Tried Dejan's download on page 38 and it fails during install saying it is for version 2.63.
Posted Feb 21, 2014 · 18:22 UTC#571
try this package
if you have any probleme just boot in wince (insert sd card with official pionner firmware and manually launch UpgradeMPU.exe)
i have install sucessfully in my appradio and work perfectly with ios 7 (my config, appradio 2.64 + jailbreak , iphone 4 ios 7.0.4 + jailbreak)
AppRadio_plus_26_264.rar
Posted Feb 22, 2014 · 09:04 UTC#572
Thanks Dejan that file worked, just a slight problem with the clock.
Can you or anyone recommend a good source for UK/Europe Igo maps?
Posted Feb 22, 2014 · 17:00 UTC#573
Thepiratebay for download recent map :)
But the must is official igo with appradio (on iphone)
Posted Feb 24, 2014 · 07:08 UTC#574
try this package
Will this work on a AVH X2500bt too???
Or only for the "AppRadios"?
Posted Feb 24, 2014 · 09:09 UTC#575
Sph-da01 Only....
Page 23 of 25
