Okay
Thank you
Okay
Thank you
Downloaded about 24Gb of maps, a lot do not work but have finally managed to pick out most of the European ones that I need that do. ![]()
The clock still keeps losing time, is there a setting that I am missing????
Registry key is set for European time. Does WinCe loose the time when unit is switched off?
so i can confirm that you can install sph-da01 firmware on sph-da02 decks
below are the instructions.
1. update to the latest sph-da02 firmware 4.17.
2. download the sph-da01 firmware 2.64
3. extract the files from AppRadio_plus_26_264.rar, but not the appradio directory.
4. extract the CE66 folder from the sph-da01 firmware.
5. boot up the deck with the sd card. This will boot the deck to the desktop.
6. click start, programs, windows explorer. select the SD card directory. double click on the "UpgradeMPU.exe" this will install the sph-da01 firmware on the deck. when prompted, remove the SD Card before rebooting.
7. reboot the deck, check to make sure everything is working, you can check the firmware version on the settings page.
8. now extract all the files and folders from the AppRadio_plus_26_264.rar to the CD card.
9. reboot the deck again with the SD card in and start the install of the appradio plus. ![]()
10 remove the SD card after the install.
11 reboot and verify, you should see the new background on the screen.
The only thing i haven`t tested yet is running the igo program as i can`t find a download link for the mips version. Can someone send me the link for the download?
Good news and tutoso i can confirm that you can install sph-da01 firmware on sph-da02 decks
Find igo in my dropbox : http://dl.dropbox.com/u/31548666/APL.rar
But sound not work on sphda01 ![]()
Class work unknwon00. Can I back to the original firmware?
Good news and tuto
thanks i can confirm that the igo/gps works
now to find a mp3 player that works, then i can disconnect the iphone forever ![]()
There's no audio driver for the WinCe so you can't play Mp3's off the microSD card if that's what you where planning.
I leave a jailbroke iPod touch permanently connected.
i`ll work on the audio driver after i get back from holidays.
Will this work with Appradio3 and Iphone5 jailbroke with 7.04? Looking for alternatives since Appradio extensions doesnt work.
moi j'ai testé quelques applications, genre VNC et lecteur MP3 mais sinon j'utilise rien d'autre j'ai essayer les applications des systemes AVIC mais sa marche pas
snif application non compatible WinCE !!
En faite tu trouvera des applications essentiellement pour pocketPC c'est la ou j'ai trouvé tout ce qui tourne sur l'appradio, sinon Pioneer prevoi une mise a jour à la fin du mois et une autre fin Mai !!!!
Bonjour Dejan,
Tu les telecharges ou tes apps ?
Recherche ds google toutes les applications compatible MIPS fonctionnerons mais helas pas de son... Merci pioneer pour ce matos de m*****Bonjour Dejan,
Ive completed this whole process until after installation of plus. It says it installs fine and everything goes smoothly and I reboot but, nothing has changed whatsoever. Any ideas?
Il faut regarder le fichier language et ajouter la langue voulu.
Bonsoir, je dois faire le domade.
Comment puis-je traduire en italien?
Après avoir modifié le firmware, vous pouvez revenir à 04h17?
Vous pouvez l'utiliser sans l'iphone?
Impossible sans iphone.
Hi,
"but not the appradio directory" --> does it mean I have to delete all that is under the appradio directory?
Thank You
Gengis
Jésus m'aime
Jesus Liebt Mich
Jesus Loves Me
salut Dejan,
Possesseur depuis longtemps d'un pioneer sph da 01 je viens juste de découvrir le jailbreak et tu m'en vois émerveillé.
J'ai donc téléchargé le jailbreak pour la version 2.64 installé sur la carte sd installé sur le poste.
Le soucis c'est que lorsque j'appuie sur le bouton paramètre du poste sa ne se lance pas comme je peux le voir sur la video en fait rien ne se lance je ne peux pas accéder aux applications.
J'ai beau avoir tout lu mais j'ai vraiment du mal avec l'anglais
Pourrais tu m'expliquer un peu merci
salut Dejan,
Salut, c'est bien installé? Le warning message est bien valide au demarrage tte seul sans que tu valide ?
fonctionne en PIONEER AVIC Z-140?
Non Only Appradio 1et2
hi guys, i'm very gratefull to you for your help.
i was installed appradio plus in my sph-da01, all good... works fine.... BUT, i can't launch igo.... "Cannot fin run" .... i see that the files isn't in the nand or SD card.
im from chile, here isn't usefull this GPS App... how can i delete this icon from the "menu", in other hand, how can i install another app? i have to copy it to APL folder in the SD? pleasy explain it....
cheers and thanks....
(sorry if i wrote something bad, i'ts not my native languaje)
Sorry for my late reponse, try that ![]()
https://dl.dropboxusercontent.com/u/31548666/APL.rar
works 100% with appradio 1 SPH-DA01
but, the must is you use igo iphone jailbreak and install background manager
Thank you very much, i will try with this file....
please, one more question: i'm using an iphone 4, but the image is yellow and i can ear some interference (i used an iphone 3gs, and the same result), but when i connect my dad iphone 4, the image is normal and have no interference. do you have an idea about the problem?
thanks again!!!
thanks again!!!
try to clean up connector 40 pin in your phone
for me, the best usage for appradio 1 or 2 is iphone 4 + background manager
result here : http://avic411.com/index.php?/topic/38423-appradio-backgrounding-application-with-ios-7/
(jailbreak with pangu... and background manager work fine...)
Thanks, I'll try cleaning it...
The iPhone that I use, is already jailbroken, I will install background manager to see what can do ![]()
Ah, and thanks for the Igo files, works great with the Chilean map.... ![]()
Cheers from chile!!!!
pleasure ![]()
