Nema.
Ja cekam da igo povrati nazad licencu da mogu kupit ![]()
Nema.
treba da cekam novi jailbreak...mogu da ima novi jailbreak V6.01 ....22 decembar.... ![]()
C'etait un gros Fake....
arrete !!!!!!!!! peux etre pas quand meme ?!!!! aye ![]()
Sisi les mecs on avoué
Il n'y aura pas de jailbreak pour le 6.0 ou 6.0.1 confirmer par la dev team ! Peu etre il attende la 6.1
It"s very hard to understand your languages
, I love my Igo on the appradio without an iDevice, which does the job but,
I don't understand Dejan what you have uploaded in those 2 files? License for Igo Primo or what?
So I downloaded with my jailbroken iPhone the Igo app, but you have to pay 30,99 € for the appradio support?!
so If you buy Igo Primo, you have to pay 33,99€ for the app, and than you have to pay an extra 30,99 € just for the Appradio support? :s
Thanks for al the hard work ![]()
For appradio support better you paid that
no hack avaible
Dejan, i forgot if the problem of wrong time displayed in appradi is fixed ?
you know using native igo from sd card....
i remember you've done something, but been a long time i'm on normal use...
( i've sold my ipod touch 4 today....kolko kosta da kupim i4 jlbrk ? ![]()
Tu peux jailbreak ton ipod en thered....
hvala gospodin ![]()
Hi,
I'm new to the forum. Today I tried to install AppRadio Plus (on firmware version 2.63).
When the installation is complete, I restart the radio (i.e. turn the car off and on), but then Windows CE and thus the installation process starts again.
What do I have to do now?
Another question: Sygic navigation does not seem to work. I constantly get the black screen which says driving and watching movies is dangerous etc. etc. Does anyone else have the same issues? Any ideas of how I can put Sygic on the MicroSD and run it without iPhone?
Thanks in advance and thanks for all the hard work!
Hello, take off you microsd card
and reboot...
For navigation only igo 8 mips run in appradio whitout iphone... With iphone igo primo and navgate drive. Navfree, waze.
and reboot...
Dejan i also jailbreaked my Appradio. How can i use igo 8 maps with out my iphone? Are there any instructions i can follow to get igo 8 running with out my iphone??
http://avic411.com/index.php?/topic/34027-igo-in-appradio-appradio/page__view__getnewpost
Here all file for run igo without iphone, but sound dont work...
and reboot...
I tried that as well, but then it says iGo cannot be found. Therefore I thought the SD card should stay in the radio.
To summarize what I did
1. Copy the appradio plus files on an SD card and put it in the radio
2. Install AppRadio plus. When the installation is complete, turn off radio and remove SD card.
3. Boot radio, click on Igo
4. "iGo cannot be found".
Have you install igo in your sd card ? ![]()
Yes no probleme work with and without its compatible but no necessary
Only for sph -da01
Dont install 2.46 / this version i a test of me 2.46 = 2.22
Install directly release of Sserhy working great !!!!
For navigation use igo is the must actualy for appradio display
(djskam have post one release in this topic) i upload my igo asap
Dejane ba de mi na nasem objasni kako da app radio krekenujem preko mini sd kartice imam ovaj radio model sph02 ,u kaeticu sam ubacio ovaj softwer app radio plus ali nikako neide sta da uradim breee......
Ne radi za sph02 samo za sph01
Ok Dejo Steta Danke Digger.....
nema na cemu ![]()
there exists the possibility of an output of the firmware jailbreak for DA100?
Hi, i made a Dutch translation. ![]()
Just got my Appradio DA01(for cheap!) and i'm figuring out what i can do with it. I'm going to install the AppradioPlus firmware tomorrow.
Thnx for all the work you guys put into this.
[edit] installed, nothing seems different, i can't open the additional menu.
When i go to settings, nothing but the original settings...
If there's still anyone out there reading this old topic, help?!
What i did:
- upgraded AppRadio to 2.63 official firmware.
60% in upgrading eboot i got an error msg saying:
Application CIS.exe has performed an illegal operation and will be shut down. If the problem persists, contact the program vendor.
Program: CIS.exe
Exeption: 0xC0000005
Adress: 01CE656C
Appradio froze, so all i could do is hit the reboot button.
Tried eboot upgrade again, it said completed. So i installed the second part of the upgrade with SD card 2. No problems at all.
If i check fw version now it says 2.63 and all seems to be working fine.
So i installed the latest AppradioPlus files i could find in this topic: SD_AppRadio_plus_26_263
Install went without any errors. Only i can't seem to get the additional menu.
I tried putting the Drive_Win_CE_Mips.rar files on the SD card, but that doesn't do anything...
Is this for app radio only? Or will it work on other pioneer units in app radio mode? I have an avh-x8500bhs.. I don't want to damage it if this isn't compatible by trying to install.. Thanks
