Jailbreak Appradio / Appradio Plus
By Dejan · Feb 02, 2012in AppRadio, AppRadio 2, AppRadio 3💬 621 posts👁️ 281,903 views
Page 20 of 25
Posted Sep 24, 2012 · 12:34 UTC#476
i'm having the same probleme here, i tried to install again, but wen start up windows ce i get a black screen, so how you did to unintall the appradio+, to install again...
thanks...
edit2:
hello all ...
and the topic is a bit confusing and dispersed information is difficult to ascertain response to a problem ...
so I managed to solve the problem and already have jailbrake functional ...
my doubt was how to uninstall the AppRadio +, to try to install again, it took one hardreset and try the installation again and then went to work and problem solved ...
Edited Sep 25, 2012 by touromelga
Posted Sep 26, 2012 · 13:17 UTC#477
Would it be possible to install a VNC client on the Appradio firmware ? and then use it to vnc connect to a vnc server running on the Andriod or Apple device ?
Posted Sep 26, 2012 · 13:51 UTC#478
Hello.
I'm Italian and I have added the italian translation in the language.ini.
Bye!
language.zip
Posted Sep 28, 2012 · 12:55 UTC#479
How do we find out what chipset these are running? Obviously some sort of MIPS chipset, but which one? Would be helpful to find a sound driver.
Posted Oct 14, 2012 · 15:42 UTC#480
Thanks for this!
This is the reason why I bought the appradio 1, It took me a while to find and install everything,
but I did the latest firmware update and Appradio + (2.63). It's great! Igo 8 works very well and fast! (you need a fast SD, otherwise its slow),
It got me navigated to my destination in Belgium! (got all tomtom maps 2011.12 of Europe for Igo)
The only problem is that I have no sound of Igo? Because of my tomtom maps perhaps? ( +++ a lot of bugs, normal right? (turning up the volume, etc.) ;) ), Normal?
It would be awesome if there was a tweak to change radio stations while in apps like in igo ..
Will try the other navigations apps, does tomtom navigator 7 work on MIPS chipsets?
thanks in advance!
Posted Oct 17, 2012 · 09:28 UTC#481
Hello, it would be possible to turn off the timer for five minutes to change radios in a quarter of an hour or more?
MfG fighterzg6
Posted Oct 18, 2012 · 18:25 UTC#482
throughout this thread several people have asked for the proper uninstall procedure, but I haven't found the answer. Could someone explain the process to me?
Posted Oct 20, 2012 · 12:48 UTC#483
simply go to setup through icons on appradio "plus" fonctions...
Posted Nov 25, 2012 · 08:02 UTC#484
Bonjour a tous,
je viens de commander l'autoradio pioneer SPH DA02, est j'aurais aimé savoir si celui ci est bien compatible avec tous vos jailbreak pour le SPH DA01.
Et si ne n'est pas le cas, m'indiquer alors s'il y a des jailbreak compatible pour cellui ci.
Je devrais reçevoir mon autoradio d'ici une semaine, si tous va bien et que le site respecte ses engagements ...
Merci d'avance pour vos réponses éventuelle.
Posted Nov 25, 2012 · 13:38 UTC#485
Bonjour,
J'ai un Appradio SPH-DA02 avec le firmware 4.14
Est ce que je peut le jailbreacker.
Je n'ai pas trouvée de réponse sur ce modèle avec le soft 4.14
Merci de vos réponse.
Cordialement.
Posted Nov 25, 2012 · 14:04 UTC#486
Hello, I have a SPH-DA02 AppRadio with firmware 4.14 Is what I can jailbreacker.
I have not found an answer on this model with soft 4.14
Thank you for your reply.
Cordially.
Posted Nov 25, 2012 · 19:35 UTC#487
pour le sph-da02.... je ne sais pas du tout...contrairement au da01 dispose de sa micro sd en facade et qui permet de charger le mode appradio plus....
en theorie ce n'est pas impossible ( suffirait de se mettre comme en mode mise à jour avec le programme appradio plus ) mais en pratique....c'est un risque potentiel pour vos postes...( je ne me souviens plus du contenu des 33 posts de ce sujet ...)
Posted Nov 25, 2012 · 19:39 UTC#488
bon selon Dejan, et je lui fais entierement confiance à ce sujet, appradio 2...negatif ( sauf si quelqu'un veut "risquer" )
Posted Nov 25, 2012 · 20:16 UTC#489
Salut,
Merci de ta réponse rapide,
Sur le SPH-DA02 il a la même configuration physique lecteur de carte SD en façade mais aucune idée de la différence entre les deux modèle
peut être l’électronique.
Je ne vais pas tenter le risque et suivre vos conseil.
Qui sait peut être avec le temps les Russe trouverons peut être une solution.
Sinon il n'y aurai pas une astuce pour supprimer le message d'avertissement au démarrage, c'est ce qui me gêne le plus.
Merci bonne soirée
Posted Nov 26, 2012 · 17:00 UTC#490
merci de ta reponse yonel
Posted Nov 27, 2012 · 08:06 UTC#491
Salut,
Moi aussi j'ai un SPH DA02 et j'ai essayé de le jailbreaké comme le DA01 avec le firmware 4.14 mais ca a pas marché:(
J'ai donc essayé comme pour le DA100, mais là, non plus.
J'ai essayé tous ce qui est possible, mais rien a faire!
Elle est plus tetu que moi cette bête là!!
Je l'ai donc mis a jour en 4.16, tout recommencé mes essaie de jailbreak et toujour rien!!!!!
J'espere maintenant, qu'on va pas nous laisser sur le bord de la route avec notre DA02…;)
Posted Nov 27, 2012 · 21:52 UTC#492
Bonsoir,
Seul le 1er model est compatible avec le jailbreak les autres ne le sont pas. Pour retirer le message d'alerte seul appradio plus peu le faire grace a un auto click... Je ne pense pas qu'un jailbreak arrivera sur les autres gammes ios sachant que ce poste est une veritable deception...
Posted Dec 08, 2012 · 18:55 UTC#493
Bonjour je possede l'appradio depuis sa sortie mais je vais abandonné l'iphone pour un android.Je voudrais donc savoir s'il y avait une solution (jailbreake ou non) pour utiliser un smartphone android sur mon SPH DA01 ? Si ce n'est pas possible je suis pret a echanger mon SPH DA01 (qui permet les jaiblreak) contre un SPH DA100...
Posted Dec 08, 2012 · 23:22 UTC#494
Salut, tu peux changer.... le 1er model n'est pas compatible android et aucune solution pour. perso je te conseil d'abandonner l'appradio même avec la version android tu sera dans le "caca" pour etre polie. L'appradio Android ne supporte pas Jelly Bean "lol" un comble... donc galaxy S3 et cie... ne fonctionnerons pas avec :)
Pioneer une marque à bannir lorsque l'on souhaite une interactivité avec un autre appareil !
Posted Dec 09, 2012 · 23:00 UTC#495
Dejan.... et ça ?
Posted Dec 10, 2012 · 11:39 UTC#497
Sa c'est l'appradio 2 (100) et pas le 1 (01) donc une grosse difference... Celui si fonctionne avec android !!!!
Posted Dec 10, 2012 · 12:17 UTC#498
Ce soir j'essai de te faire une demo de ma config appradio / iphone avec Carmediaplayer et Igo :-)
Posted Dec 10, 2012 · 17:11 UTC#499
Great :) we are waiting.
I steel hope, that iGO make some discount for Pioneer AppRadio support, then i will buy this activation meni :)
I cant wait that i will use iGO on my AppRadio on AVH-8400BT model.
I realy love this AppRadio mode!
Posted Dec 10, 2012 · 18:15 UTC#500
AVH-8400BT is better that appradio spa-dh1 :( s
Igo is a nice GPS !
Page 20 of 25
