🔒 Locked
AppRadio Extensions 2.0 Beta - Full iPhone control
By mikedecaro · May 06, 2012in AppRadio, AppRadio 2, AppRadio 3💬 2,444 posts👁️ 945,070 views
Page 10 of 98
Posted Jun 27, 2012 · 20:19 UTC#226
The lastest version in cydia is far behind the version on this thread.
Posted Jun 27, 2012 · 20:27 UTC#227
In cydia version 1.1.4 latest official release work fine in 5.1.1, but beta 2 dont work in 5.1.1, you dont see your iphone in appradio...
Posted Jun 27, 2012 · 20:31 UTC#228
Hmm, odd, I too installed 5.1.1 on my iphone 4S but AppEx beta 2 is working fine. I do have the latest version of AppRadio+ installed as well, not sure if that makes a difference?
After upgrading to iOS 5.1.1 my TOM TOM navigation didn't load any more.. I think it has it's own backgrounder process or something, cause it just asks for me to load the AppRadio phone App..
other than that most things worked pretty good, the things listed on the first post are still buggy, but those are at least documented. I donated some $$to Mike, so I'm excited to see Beta 3 in action. RIght now I'm rocking Display Out until it's ready to play with
Posted Jun 27, 2012 · 20:43 UTC#229
iPhone 4s iOS 5.1.1 working Fine (except known Bugs)
Also navigon, etc.
Edited Jun 27, 2012 by d4Rk
Posted Jun 27, 2012 · 22:40 UTC#230
Also navigon, etc.
You use 2.0 beta or 1.1.4 version?
Edited Jun 27, 2012 by Lusi69
Posted Jun 27, 2012 · 23:10 UTC#231
are you guys doing a "clean install" of the beta??? I feel like that is probably your problem
Uninstall (whatever version of ApEx that you are using)
Reboot
Install the beta (I e-mailed to myself and installed via iFile on the phone itself)
Reboot
Should work fine!!!!
Posted Jun 27, 2012 · 23:41 UTC#232
Pretty sure after a fresh jb and upgrade to 5.1.1 my device was cleaned up and I only installed SB settings an AppEx for my tests.
Some other things stopped working too that aren't appEx related.
Like I couldn't see, only hear videos through the regular iPod source that previously I could watch with no issue.
Posted Jun 28, 2012 · 05:12 UTC#233
Latest Beta.
Posted Jun 28, 2012 · 16:40 UTC#234
Does the AppRadio app work in app mode? What do you mean by "it didn't really work"?
Thanks Mike for replying. Well unit doesnt have an advanced app mode. So apps like motionx/waze/best parking will display on the unit without jailbreaking just fine but you cant control them via touchscreen on the pioneer unit. The appradio app doesnt really do anything except list compatible apps.
Posted Jun 28, 2012 · 20:00 UTC#235
hey mike were you able to get the touch signals to be able to more than just simple gestures?
Not yet.
If you can't control the AppRadio app with the head unit, this won't work.
Posted Jul 02, 2012 · 02:36 UTC#236
Updated the first post with the Beta 3 link. This version should fix the issue with app switching. There is still a problem with the AppRadio app getting stuck on the SpringBoard. It's a known issue with Backgrounder that I'm trying to work out. Restart SpringBoard to clear the issue.
Edited Jul 02, 2012 by mikedecaro
Posted Jul 02, 2012 · 06:19 UTC#237
thanks again mike!
Posted Jul 02, 2012 · 06:55 UTC#238
Do I need to add a source to my directory to find this file? When i do a search it only finds the old file on the BigBoss repository. Or do i have to load the file from the first post?
:: edit i downloaded the file with Ifile but i feel this is still a valid question. ::
Edited Jul 02, 2012 by gfirerescue
Posted Jul 02, 2012 · 11:40 UTC#239
I have try this beta 3 in my iphone 5.1.1 : now my appradio and my iphone dont work !!! When i connect my iphone my appradio launch appradio application but dont have access in appmod... I have a black screen in appmod, appmod dont work... I have try unistall this beta, reboot, unistall / reinstall appradio application, reboot appradio, i have unistall all ect... I have tested launch directly in my iphone springboard application compatible, again black screen i dont see picture now in my appradio... :-( Mike your extention is not compatible in 5.1.1 ??
Edit : reset settings and deleted manually file, install again ! WORKS GREAT :) :) :) NICE JOBS !!!!!
Edited Jul 02, 2012 by Dejan
Posted Jul 02, 2012 · 12:52 UTC#240
This beta is separate from the version in Cydia. Just install the file from the first post. It will overwrite the Cydia version.
now i restore my iphone....
You shouldn't have to restore. AppRadio Extensions is loaded from /Library/MobileSubstrate/DynamicLibraries. Just delete the one or two files from that folder and restart springboard/reboot the phone. If the problem still exists after removing the files, it's not caused by the Extensions.
It is compatible. I'm testing on a iPhone 4 running 5.1.1.
Posted Jul 02, 2012 · 13:14 UTC#241
Ok thanks a lot Mike :-) i test now :-)
You use 5.1.1 ok so, i dont Know why dont work for me :-s i have correctly install :'(
Again thanks you for your work Mike and for your reply to help me :-)
Posted Jul 02, 2012 · 16:00 UTC#242
So, i have try your recomandation, and work fine ! i have delete manually file, and reset all setting in my iphone ! have retry ton install beta 3, and now work fine :) i see picture and controle works, and appmod work correctly ! (i think i had a failed installation)
thanks a lot Mike !!!!!!!!!!!!!
Posted Jul 02, 2012 · 21:40 UTC#243
AR1 : firmware 2.56
iPhone 4 + IOS 5.1.1 + AppRadio 1.7.1
I've uninstalled AppExt beta 2, downloaded beta 3, installed with DiskAid.
1st try, KO. I could launch user applications but I've forget to reboot the iPhone, so reboot and now OK. Reboot is mandatory.
Great job, I tried tomtom France 1.9, TomTom Europe 1.10 and I can manage them from AR screen, portait and landscape format screen, with iCoyotte running in background and sound of both in the car speakers, even with Radio or CarMediaPlayer as well.
Just some small issue when trying to switch from iCoyotte to Inrix for example : when I press central button I come back on iCoyotte or Appradio is displayed but nothing more I can't close it and the only solution is unplugged the connector.
Another issue with iCoyotte, but AppAxt is not concerned : it always starts with night screen on AR but full-light on iPhone screen, I've to commute (finger up to down) on the iPhone to set night position and then to day position (finger down to up) to be full-light on the AR screen.
Posted Jul 02, 2012 · 22:56 UTC#244
Great job Mike this makes me love my appradio 2 even more now
Posted Jul 03, 2012 · 04:18 UTC#245
Is there any reason that this wouldnt work on an iPod touch running 5.1.1? I've tried installing it and it shows in Cydia as installed but i dont get any settings in the settings menu and none of the benefits show up either.
Posted Jul 03, 2012 · 04:33 UTC#246
Maybe you should read a little more in this thread.
Posted Jul 03, 2012 · 05:44 UTC#247
Mike you are the man!
God Bless you.
Posted Jul 03, 2012 · 11:40 UTC#248
Mike, it would be possible to lock the screen of the iphone when using APPEX with gps for exemple because iphone heating and risk to safety ... it is possible with backgrounder and supports native appradio applications.
For example when I use icoyote i deactivates APPEX in sbsettings and i active backgrounder on icoyote, then I can lock my iphone and still use Icoyote directly from my appradio and therefore the iphone does not heat.
heating of the iphone is a real problem with Pioneer did not take into, and long-term use is dangerous
Posted Jul 03, 2012 · 14:02 UTC#249
Make sure PreferenceLoader is installed. I added a list of dependencies to the first post of this thread.
I can't mirror the screen when the display is off. Does anyone know if changing the brightness of the display helps with the heat issue? Maybe I can work with that.
Edited Jul 03, 2012 by mikedecaro
Posted Jul 03, 2012 · 18:32 UTC#250
I can't mirror the screen when the display is off. Does anyone know if changing the brightness the display helps with the heat issue? Maybe I can work with that.
Ok thanks :-)
Page 10 of 98
