🔒 Locked
AppRadio Extensions 2.0 Beta - Full iPhone control
By mikedecaro · May 06, 2012in AppRadio, AppRadio 2, AppRadio 3💬 2,444 posts👁️ 945,070 views
Page 27 of 98
Posted Jan 26, 2013 · 07:18 UTC#651
Odepaj - I am not able to DL/open our link with either ifile or myfile from my 4S. I desperately need a cracked 1.8.2 appradio version. Thanks in advance
It's a plain old .ipa file, download it from your computer, delete the normal AppRadio app from itunes and replace with the cracked 1.8.2 then sync it to your phone.
Posted Jan 26, 2013 · 14:01 UTC#652
I'll try that.... Thanks again
Posted Jan 27, 2013 · 13:53 UTC#653
Incredible work. Can't wait for iOS6 update. Keep up all the great work!
Posted Jan 27, 2013 · 23:11 UTC#654
Odepaj ~ I dwnloaded the package from your link and there is not a .ipa file in it at all..... just a whole bunch of differnent files along with a 10 second .avi film????
Posted Jan 27, 2013 · 23:35 UTC#655
Does anyone else have a cracked version of appradio 1.8.2? I've been racking my brains trying to figure another way to revert back to 1.8.2. I actually have the orginal 1.8.2 on my itunes (my PC) but when I try to install it on my jailbroke 4S it starts and then pops up "Appradio can't not be installed" (just for information purposes - I did upgraade my appradio to 2.0 and then read this forum)
Posted Jan 27, 2013 · 23:37 UTC#656
What are you doing to download it? You should only have to left-click the link, it's directed at the .ipa in my dropbox account. There's no way it's giving you anything else.
Posted Jan 27, 2013 · 23:38 UTC#657
Have you removed the updated 2.0 from your phone before you try to install your original 1.8.2?
Edit: If you still have your original 1.8.2.ipa you don't need a cracked version. You just need to figure out why iTunes is saying it can't be installed.
Edited Jan 27, 2013 by odepaj
Posted Jan 27, 2013 · 23:45 UTC#658
To Odepaj ~ Yes I did remove it (from my iphone) before I hooked it to my computer with the original 1.8.2 on my itunes... No luck..... Same error...
To the "downloading your cracked version via dropbox" question ~ All I am doing it left clicking on your link from a window 7 computer and saving.. It savs as a .zip and once
extracted.... it has multiple files in it... but no .ipa file.
Posted Jan 27, 2013 · 23:48 UTC#659
That is really strange, it should sync back to your phone just like normal?
Edit: Both links will now download as a zip file to make it easier for everyone.
The highlighted is your problem, the link is pointed directly at the .ipa file itself, no need to save it as a zip and extract it. If you have no option to save it as is, here it is in a zip file if you want to try it: https://www.dropbox.com/s/wcn78oynqmtr2xq/AppRadio-v1.8.2cracked.zip?dl=0
Edit: I'm a little concerned that even a cracked .ipa might not install for you if iTunes is giving you problems with your original 1.8.2
Double edit: I'm not sure how strict avic411 mods are, but I'm sorry if this is to much hijacking in the thread.
Edited Oct 02, 2018 by odepaj — Reason: Updated download link
Posted Feb 04, 2013 · 16:32 UTC#661
So, I see another update to the appradio app today, I'm guessing it's another stay away job.
So the big question, with ios 6.1 jailbreak just about to be released (literally minutes) will this aid the update of app radio extensions and how is the progress coming on with ios 6.1 ???
Posted Feb 04, 2013 · 19:00 UTC#662
Today released jailbreak ios6.1 - this will speed output version AppRadio Extensions 2.1? compatible with 6.1?
Posted Feb 04, 2013 · 22:10 UTC#663
Yeah is there an update coming for 6.1?? I just did the Evasi0n jailbreak (which is the easiest most seamless jailbreak I've ever seen) and I desperately want AppRadioEx back!! Its been so long and I miss it so dearly. Mike????
Posted Feb 05, 2013 · 02:23 UTC#664
Still working on it. I'll keep you guys posted.
Posted Feb 05, 2013 · 02:42 UTC#665
Awesome!
Is iOS6 still an obstacle for running unsupported apps, or can the recently released Pioneer SDK provide a workaround?
Posted Feb 05, 2013 · 02:48 UTC#666
It's still an issue. I don't have access to the SDK.
Posted Feb 05, 2013 · 03:13 UTC#667
New to this app radio stuff can anyone help me?
I can't get this to work. iPhone 4 ios 5.1.1 AVH-P8400Bh
I followed all the instructions but when I hook up my phone none of the apps that I selected in the settings are visible on the AVH-P8400Bh screen?
Posted Feb 05, 2013 · 15:35 UTC#668
great news Mike!
Posted Feb 05, 2013 · 19:56 UTC#669
Hey Mike, a while back you mentioned that you were going to open source this extension. Has that been done yet? If so, where is the code hosted?
Posted Feb 05, 2013 · 19:59 UTC#670
Hey does anyone know of a tweak in cydia that can make your springboard rotate and display in landscape mode through the appradio?
I've tried SB Rotator but it only rotates rarely to appear in landscape mode on the radio. All the other times it will appear rotated but in portrait mode on the radio. Mike Decaro has done some amazing work with App Radio Extensions. Just want to know if anyone knows how I can get my springboard and all the other unsupported apps that only allow portrait mode to appear wider and not pixelated on the radio? Or are there any futures plans for App Radio Extensions 2.0 to have unsupported apps like the home app that displays the iDevice's springboard appear in a bigger resolution? I'm currently on App Radio 1.8.2, Downgraded after finding out unsupported apps weren't functioning..
Edited Feb 05, 2013 by R0n
Posted Feb 05, 2013 · 23:01 UTC#671
Does anything work for iOS6.1? Im mostly interested in the Siri function for texting and driving. I used it with iOS 5.
Posted Feb 06, 2013 · 03:17 UTC#672
If I update my 4th gen iTouch to ios 6.1 jailbreak, will Appradio Extensions be more responsive/less laggy?  Also will the unsupported apps still function?  I'm currently on Appradio 1.8.2, so wasnt sure whether it was just the appradio app firmware or the ios firmware that affected appradio extensions functionality.
Posted Feb 07, 2013 · 19:43 UTC#673
I never got around to posting it. It's still on the list, I've just been really busy so it got bumped down behind iOS6 and the AppRadio app update.
Everything should work except for controlling unsupported apps. You will just be able to display them until I find another workaround. The Siri functionality is still buggy but I'm definitely working on it. I use Siri a lot in the car.
Not sure about the lag (my iPhone 4 is a bit laggy, it's on the todo list). Unsupported apps will just be viewable for now (see the first post). It's a limitation in iOS 6. The latest AppRadio app and firmware will be supported.
Edited Feb 07, 2013 by mikedecaro
Posted Feb 07, 2013 · 20:08 UTC#674
Updated the first post with a beta for iOS 5. It should fix the disappearing icons in the latest AppRadio app update. Please don't try installing this on iOS 6. It doesn't work yet.
Scrolling through the apps lags for me. Does anyone else experience this?
Posted Feb 07, 2013 · 23:38 UTC#675
IOS 6.1 AppRadio 2.0.1  I can only get the time and the battery percentage to work no Siri button.  Also every time I exit the AppRadio app the phone crashes and goes to safe mode.  Also I tried using AppRadio 1.8.2 but I only get a black screen on the AppRadio.  I do not have backgrounder installed.
Page 27 of 98
