🔒 Locked
AppRadio Extensions 2.0 Beta - Full iPhone control
By mikedecaro · May 06, 2012in AppRadio, AppRadio 2, AppRadio 3💬 2,444 posts👁️ 945,070 views
Page 30 of 98
Posted Feb 17, 2013 · 10:26 UTC#726
It can be "Requires parking brake bypass to view unsupported apps" ? i can see unsoported app only with hand break On.
I tried it with the parking break on and without... still the same... black screen when launching unsupported apps, and working normal when launching the supported apps.
Posted Feb 17, 2013 · 13:17 UTC#727
Hey Atlawson,
I used just:
AppRadio 1.8.2 and AppExt - from Cydia (ONLY)
Works great.
Mooooch
Appradio2, iPhone 4s (iOS 5.1.1), App Radio App 1.8.2, AppExt (Cydia Version)
I just don't see what I am doing wrong I have the exact same setup you have. The only thing I have extra is the icon that looks like a phone that I click on that mirrors my phone display and I can use it to access the phone apps and run them that way. I just can't get the actual app shortcut to show on the radio home screen. Would other apps or themes from winter board be a problem. That is the only thing I haven't tried was to disable all my addons but the appradio ext to see if it works.
Tracy
Posted Feb 17, 2013 · 16:02 UTC#728
Updated the first post with a beta for iOS 5. It should fix the disappearing icons in the latest AppRadio app update. Please don't try installing this on iOS 6. It doesn't work yet.
Scrolling through the apps lags for me. Does anyone else experience this?
I haven't been on here in awhile.  I upgraded my iPhone 4 to the iPhone 5 and haven't been able to use the iPhone 5 with my AppRadio.  My AppRadio has been downgraded to a radio and iTunes using my old phone.  I couldn't use any other functions.  With the release of the latest Jailbreak, I broke my iPhone 5 (very slick program). There is an app called MyWi.  They've updated it and now it has the ability to turn on data sharing and off when your other device (the non-data) sends a signal.  This is done through bluetooth.  This is avery cool feature.  Now when I get in my car, the old iPhone 4 automatically connects to my iPhone 5 and uses the iPhone 5 as a Hotspot. Now my AppRadio is a functioning unit again using my old iPhone 4 and grabbing data from my iPhone, wirelessly.  To make this all work though I had to update my old phone to IOS 6.1 and then jailbreak again.  I hadn't been following this so I didn't realize, AppRadioExt was not working with 6.1.  Actually though with the latest Beta is does work to a certain extent.  For example I can use Spotify through my old iPhone 4, I just can't have it displayed on the AppRadio. You have to bring it up on your iPhone.  All of the supported apps seem to be working fine.  So Mike you are actually quite close on this.  I have all the unsupported apps displayed.  When I choose one it comes up initially in portrait mode, then I get a warning message that does not go away.  If I go to my iPhone 4 and hide the AppRadio App (Pioneer), I can then bring up whatever unsupported app I was using and it works over the radio speakers, just not the display.  So you are very close to making this work with IOS 6.1.  Keep up the good work.  PS, I'm looking into fitting an iPad Mini into my car as a head unit.
Posted Feb 17, 2013 · 17:17 UTC#729
Working on it.
The e-brake bypass is required.
I'll downgrade one of my devices to iOS 5 this weekend so I can do some testing.
Thank you... this is great... hope you can fix it... i will follow avic411.com to get it work soon...
Posted Feb 17, 2013 · 22:33 UTC#730
Tracy
Hey Tracey,
I'm a noob to all this.
I read your post on page 47, seems you have downloaded everything and tried all combinations.
Try; go into ifile, uninstall (all appradio and app ext) all the source folders for App radio app and app ext. then (re start phone) reinstall 1.8.2 and app ext from Cydia.
That's what I did.
Posted Feb 17, 2013 · 22:37 UTC#731
Hey Tracey,
That's what I did.
Mooooch
Posted Feb 18, 2013 · 02:34 UTC#732
I have to uninstall and reinstall App Ex after every time i kill appradio app otherwise I get just a black screen and the app on the phone doesnt show it is connected.  Also sometimes the siri button does not work.  it recognizes that I touched the button but nothing happens.  Even after i do a new install.  I did have it working for a bit.  Also will Insomnia work to replace backgrounder.  It is iOS 6 compatible.
Phone still crashes sometimes also.  No unsupported apps work for me. Also when I arrange the app and then close the appradio app it doesnt save their positions.  Auto accept is not working neither is the ignore.
iPhone 4s iOS 6.1 appradio 2.0.1
Posted Feb 18, 2013 · 04:04 UTC#733
today i jailbroke my phone using evasi0n. i checked to see if backrounder was installed and it wasnt so i went ahead and made sure the dependencies were installed. after getting that correct i downloaded 2.1.0 beta2 file in the first post and installed it using ifile installer. i restarted my phone and then went to my car and started the appradio app. it was just like before with no unsupported apps.
my setup: sphda02, jailbroken iphone4, appradio version 2.0.1, firmware version 2.63
after i tried deleting the appradio app, reinstalling the beta file using ifile, downloading appradio 2.0.1 from itunes but no luck.
any help is appreciated. for some reason i think it may be as easy as downgrading the appradio version or the firmware version.
thanks in advance. i also want to send mike a thanks in advanced because from what ive seen i think im going to be very happy and making a donation.
Posted Feb 18, 2013 · 07:46 UTC#734
Are you on iOS 6.1???
Posted Feb 18, 2013 · 10:04 UTC#735
bonjour lien pour ios 5.1.1 mort :?
Posted Feb 18, 2013 · 12:04 UTC#736
I was like you. I follow your steps, but:
Delete Appradio App: reboot
Reinstal the beta using ifile: Reboot
Reinstal Appradio 2.0.1 from Appstore and it work for me with 4S Ios 6.1 and 4.16 Appradio firm
Only Unsoported App run in a smaller resolution with landscape Lock on.
Posted Feb 18, 2013 · 15:31 UTC#737
 yes. sorry i forgot to mention this.
i will try this. thanks for your help.
Posted Feb 18, 2013 · 16:55 UTC#738
Hi everyone,
Has any one got the beta 2 deb as the link isn't working thanks
Posted Feb 18, 2013 · 17:07 UTC#739
Hi everyone,
Do you need beta for Ios5 or Ios6???
This link contain two betas (1 & 2) for Ios6.1:
http://www.4shared.com/rar/OYVSK02w/AppradioExt_IOS61_Beta12.html
I also Have Beta 1 for Ios5, think beta2 Ios5 is in cydia:
http://www.4shared.com/rar/rXnfu_8c/appradioext_ios5_beta_1.html
Mike, there is something that we can do for help????
Edited Feb 18, 2013 by Jab
Posted Feb 18, 2013 · 17:32 UTC#741
Hi Jab,
Thanks for that but its beta 2 for ios5, thanks for the quick reply in trying to help.
Fixed the link.
Posted Feb 18, 2013 · 17:51 UTC#742
It did not work. Did everything and appradio showed as it normally would with only supported apps. Any other ideas?
Posted Feb 18, 2013 · 18:11 UTC#743
You´ve got  sphda02 firmware 2.63?? What about upgrade to 4.16??
I really dont know if 2.63 is better than 4.16 for some reasons, but  4.16 it´s ok for me with Ios6.1
Posted Feb 18, 2013 · 19:36 UTC#744
guys how do i identify what firmware my appradio is on? also how do i find the cersion of the appradio app?
really want to contribute.
thanks all
Posted Feb 18, 2013 · 19:46 UTC#745
Fixed the link.
Thanks Mike
Posted Feb 18, 2013 · 21:19 UTC#746
More bugs.  Every time I kill AppRadio app i have to remove and reinstall app ex.  If i don't, I can't even see the music under the ipod app, my phone contacts dont import.  AppRadio app will not launch, it just says connect the device.  Sometimes the device acts like its not connected. Also if I don't not reboot after each install separately, then siri sometimes doesnt show up or if it does when i select it nothing happens.  Sometimes unsupported apps show up and no siri.  Still cannot launch unsupported apps.  Sometimes if I launch apps from my phone they show up on the radio.  Also auto accepts doesnt work for me at all.
iPhone 4s iOS 6.1 AppRadio 2.0.1, AppRadio 2 not sure if it is the latest firmware.
Posted Feb 18, 2013 · 21:24 UTC#747
Does anyone else with an AppRadio 2 see the same behavior? I'm running an iPhone 4S, iOS 6.1, AppRadio 2.0.1, on an AppRadio 1. Not seeing any of these issues
Posted Feb 18, 2013 · 22:06 UTC#748
im sorry i dont know where i got 2.63. it is firmware 4.16
thanks all
it says the firmware somewhere in the settings. i cant really remember where. i may be able to take a look in a bit when i go home.
Posted Feb 18, 2013 · 23:10 UTC#749
i have an appradio 2 and i am not seeing that behaviour.
Posted Feb 18, 2013 · 23:13 UTC#750
And i have IOS 6.1 but not sure which version of firmware.
Page 30 of 98
