🔒 Locked
AppRadio Extensions 2.0 Beta - Full iPhone control
By mikedecaro · May 06, 2012in AppRadio, AppRadio 2, AppRadio 3💬 2,444 posts👁️ 945,070 views
Page 35 of 98
Posted Feb 22, 2013 · 16:53 UTC#851
Can you see if Beta 6 fixes the issue?
Found out that the tweak "NoAccSplash" which disables the "Accessory Attached" splash screen that shows disabling the iPod app when you plug your iPhone into certain audio accessories. With this tweak enabled you just get a black screen on the AppRadio deck when the AppRadio.app is running. Other apps like Pandora worked fine but not the AppRadio App Home Screen.
Edited Feb 22, 2013 by oneyozfest182
Posted Feb 22, 2013 · 16:55 UTC#852
SPH-DA02
iPhone 4S 6.1 Jailbroken
Did anyone else lose the ability to scroll in CarMediaPlayer after upgrading past beta2?  beta2 worked with the usual bugs, but every version after that prohibits me from scrolling vertically.
Sorry for double-posting; idk if that's still looked down on like it was on forums 10 years ago.   :-P
I can kinda scroll but it's not very smooth & fluid. I don't know how smooth it's supposed to be though because I just got my first AppRadio last night. Definitely tough to scroll even there and nearly impossible on the main apps screen.
Posted Feb 22, 2013 · 19:05 UTC#853
So I'm wondering if anyone else experiences lag scrolling in the app screen. Everything responds just fine on the main screen, within apps, etc. but when I'm on the apps screen it's so hard to swipe between pages. I can tap icons okay and everything else just swiping through pages of apps it almost seems like it's not recognizing swipes... Like I said swipe gestures seem to work fine everywhere else just not on the apps page on the radio.
I lost the ability to scroll smoothly a while ago.
With this Beta6 I can't even get apps to load on the screen.  I have unistalled Appradio and Beta6 and reinstalled them both to no avail.
Posted Feb 22, 2013 · 19:11 UTC#854
I've been reading all of the posts but haven't had time to look into/reply to them yet. I'll follow up later today.
Edit: Can everyone who is having problems post their iPhone model, AppRadio model, and AppRadio firmware version?
Edited Feb 22, 2013 by mikedecaro
Posted Feb 22, 2013 · 20:31 UTC#855
Thank you from Italy Mike for your incredible work! Great!!
Posted Feb 22, 2013 · 21:19 UTC#856
Installed beta 6 and if i select the app using appradio app then it is still the small screen.  But if I home button after opening appradio app and select music or say spotify from the phone, then it will go full screen.  Just not when using app ext. to open it.
iPhone 5 64 gig Firmware 6.1.2 ATT
Appradio 2 (SPH-DA100)
Appradio 2 FW- 8.30
Edited Feb 22, 2013 by bear52885
Posted Feb 22, 2013 · 22:01 UTC#859
Hey, Tom, Change Your Engine Oil Soon!
 I know its about due ha ha.  That truck bitches at me for everything it needs.
Posted Feb 22, 2013 · 22:03 UTC#860
No fluid displacement icons, and errors up to several pioneer native aplicacione example: Ec Touch ....
iphone 4
IOS 6.1.2
AppRadio v 2.0.1
AppExt Beta6
Fire AppRadio 2 (SPH-DA100, not where or how you look) someone could tell me.
Greetings and thank you very much ...
Posted Feb 22, 2013 · 22:49 UTC#861
ok now I feel retarded too...I have the issue where I want to run Navigon but theres a message saying a licensing issue prevents navigon from displaying on the appradio.
Do I need a cracked version of Appradio or something?
Thanks guys,
Posted Feb 22, 2013 · 22:51 UTC#862
And I still cant find the firmware I am running on appradio 2. Anyone able to tell me where it is? Apparently its not under settings...no option for that.
Posted Feb 22, 2013 · 23:03 UTC#863
you will not know until you stick the usb drive in with the update.  I bout my appradio 2 in july and it had 2.11 on it.   There is no way to find out with out trying to upgrade.  Stupid.  Also use Windows not mac and format USB to FAT not FAT32 or NTFS. Dosent work when format with mac.
Parallels with windows works though. Virtual Machine
Edited Feb 22, 2013 by Tomfoolery82
Posted Feb 22, 2013 · 23:22 UTC#864
ok Thats why its not finding my update file.
Thanks alot Tom.
I read back about the Navigon items and found the repo. I updated and its all good now.
Mike I cant use Siri to send a text message however....is this coming?
iPhone 4S
Appradio 2
iOS ver 6.1
Appradio version ??? No idea.
Posted Feb 22, 2013 · 23:32 UTC#865
siri does work for text. i had an issue where I tap the siri button nothing happens but thats fixed now, siri will also play music and more.  I found that installing app radio first then app ex second works best for me
Posted Feb 23, 2013 · 00:26 UTC#866
Hi,Just thought i would share iam also having scrolling through app's lagging issues as well as when i open a unsupported app i have to press the home (app radio) button which takes me back to the main screeen out of app's.
Iphone 4s
Ios 6.1
appradio 1
app radio version 2.0.1
app ex beta 6
Thanks,
Keep up the great work Mike!
Edited Feb 23, 2013 by dannn
Posted Feb 23, 2013 · 03:11 UTC#867
SPH-DA02 (4.16)(ebrake bypass)
iPhone 4 6.1.2 Jailbroken
Beta 6  (2.0.1-28)
Wont allow me to see any unsupported apps at all.... it will show the battery percentage in the top left corner but thats it :( Any suggestions?
Thanks for all your work Mike!
Edited Feb 23, 2013 by Loogah
Posted Feb 23, 2013 · 05:16 UTC#868
For now you will have to use the home button to back out of unsupported apps.  This is because there is no backgrounder to run appradio in the background.  That is what allowed the touch screen on supported apps in iOS 5.  The original AppRadio app needs to run in the background to use touch on unsupported apps and it does not. When this gets figured out then the black bars will bring you back to the Advanced app mode.  I used it with iOS 5 and it worked great. Backgrounder did that for us in the past but it is not compatible with iOS 6.  The developer abandoned it.  Someone needs to use his source code and update it for iOS 6.
Posted Feb 23, 2013 · 06:16 UTC#869
Hopefully somewhere in the near future fingers crossed!
Posted Feb 23, 2013 · 22:51 UTC#870
He guys. I'm on my phone so searching is a bit of a pain. Sorry if this is a repeat.
I have the latest beta of appradioex on 6.1 on an i
Posted Feb 23, 2013 · 22:58 UTC#871
Sorry about the premature post ^^
Hey guys. I'm on my phone so searching is a bit of a pain. Sorry if this is a repeat.
I have the latest beta of appradioex on 6.1 on an iPhone 4. I have the unsupported apps showing up. When I tap on one it launches, shows a bit then gives me that video watching warning. I don't have a bypass installed, but if I do the following, the apps will display.
Launch appradio app
Tap on unsupported app
Wait for warning
Tap home button on appradio
Tap apps on Appradio
Then press okay for the compatible apps warning.
You should now see the unsupported app
A bit of a pain, but it works(no touch support) :)
Edited Feb 23, 2013 by Suave
Posted Feb 24, 2013 · 03:17 UTC#872
iPhone 4
iOS 5.1.1
AppRadioEx 2.0.1-1
AppRadio 2 with bypass installed
I have no unsupported apps showing up and can't access them. Any ideas?
Posted Feb 24, 2013 · 19:51 UTC#873
Iphone 4 ios 5.1
Appradio 1.8.2
Appradio 1 2.63
App ex cydia version
Just can get the notifications work on the supported apps ec touch
And still very slow im out of ideas
Can somebody help me.
Edited Feb 24, 2013 by funkystyles
Posted Feb 24, 2013 · 21:57 UTC#874
ive had the beta 6 installed since it came out and i have to say that over time the scrolling through pages of apps has gotten smoother over time. i think that it may had something to do with it loading all the unsupported app icons. i also found that it scrolls better if you swipe above the battery percentage or time.
keep up the work Mike. if theres anything i could do to help out let me know.
iphone4 jailbroken ios6
appradio 2.0.1
sphda02 4.16
appex beta6
Posted Feb 25, 2013 · 04:06 UTC#875
iPhone 5 jailbroken 6.1
Appradio 2 (FW 8.30)
app ex beta 6
Any app that is selected in the "unsupported apps" list will show up on the display in a small windowbox.
Removing the apps from the list or torning "unsupported apps" to off fixes this.
(Also, google maps has a spinning circle of dots instead of it's normal icon.)
Edited Feb 25, 2013 by glitch77
Page 35 of 98
