🔒 Locked
AppRadio Extensions 2.0 Beta - Full iPhone control
By mikedecaro · May 06, 2012in AppRadio, AppRadio 2, AppRadio 3💬 2,444 posts👁️ 945,070 views
Page 47 of 98
Posted Apr 18, 2013 · 16:12 UTC#1151
iOS automatically kills applications that run in the background for too long. I tried implementing some code that bypasses this restriction but it sounds like it's not holding on your devices.
Can you try opening Info.plist inside of the AppRadio app bundle and add audio to UIBackgroundModes? You can use iFile to modify the file on your device.
It should look like this:
<key>UIBackgroundModes</key>
<array>
    <string>external-accessory</string>
    <string>audio</string>
</array>
Posted Apr 18, 2013 · 16:21 UTC#1152
Mike Fyi
I've reinstalled the music controls pro 6 app from cydia and have selected the appradio app for video backgrounding and it stays open in the background without closing after 30 seconds like it was doing before I reinstalled the mc pro 6 app.
Hope this helps..
Posted Apr 18, 2013 · 16:24 UTC#1153
I cant get it to function on my iPhone 5 anymore. No touch and I can't get into mirror mode unless I go into the car media player and exit. Only works once then a black screen.
Can I go back to beta 8. Worked pretty well before.
Posted Apr 18, 2013 · 16:29 UTC#1154
Mike can you point me in the right direction to get to the appradio app bundle in ifile?
I'm not to familiar with using ifile.
Posted Apr 18, 2013 · 16:30 UTC#1155
Mike Fyi
Hope this helps..
I'm adding proper support for MCP in the next release (so they don't conflict). If it see's MCP, it will disable my backgrounding.
Use the link in the first post and change Beta9 to Beta8.
Posted Apr 18, 2013 · 16:43 UTC#1156
In the iFile settings, turn on Application Names.
Navigate to /var/mobile/Applications and find AppRadio.
Open the AppRadio.app folder and look for Info.plist.
Posted Apr 18, 2013 · 16:45 UTC#1157
So Mike should I leave MCP installed until you come up with a solution for the issue so that I can continue to use appexstensions without the appradio app closing after 30 seconds?
Posted Apr 18, 2013 · 16:48 UTC#1158
Yes.
Posted Apr 18, 2013 · 17:03 UTC#1159
Ok Mike I added audio to UIBackgroundModes like you said through ifile, what should I do next?
Posted Apr 18, 2013 · 17:05 UTC#1160
Reboot and test. If this doesn't help, I'll have to see what I can do in the code.
Posted Apr 18, 2013 · 17:13 UTC#1161
So remove MCP first then reboot and test?
Posted Apr 18, 2013 · 17:23 UTC#1162
Yes.
Is the AppRadio app crashing after 30 seconds for anyone else? I'm trying to figure out if the results are mixed or if everyone is seeing the issue.
Posted Apr 18, 2013 · 17:28 UTC#1163
Yes.
Seemed to work fine for me on the ride into work this morning, for probably 10 minutes. Most of my weekly trips are under 15 minutes though so that's gonna be the extent of my testing for a while. :P
Posted Apr 18, 2013 · 17:37 UTC#1164
Touch support works now (iPhone 5 in combination with AVH-X8500BT) but only the first 20 seconds after starting an app.
If I touch the screen, the touch point on the iPhone is different.
Like tomtom, if i touch Navigate to ... (1st option) then i select Route options (2nd option).
Is there a possibility to synchronizing this?
Apologies for my (bad) english
Posted Apr 18, 2013 · 19:52 UTC#1165
Yes.
yes it is crashing for me.
4s
6.12
Posted Apr 18, 2013 · 20:45 UTC#1166
Mike after trying the changes through ifile that you recommended I'm still getting the same results. Appradio crashes after 30 seconds.
Posted Apr 18, 2013 · 21:27 UTC#1167
Worked perfectly for me Mike! Tested for about 30 min.  Scrolling is a little slow, but does work.  Tapping the bars brings me back to the app radio screen.  I have SBrotator 6 and it rotates the springboard for me on appradio. When it open the springboard rotates but not the pic orientation on appradio.  If I open the messages app then close it with the black bars, it goes back to the springboard and it is rotated and looking perfectly like an iPad on the appradio screen.  Notification banners couldn't be tapped on while in other apps.  This is amazing work.  Thank you.
Posted Apr 18, 2013 · 21:40 UTC#1168
<array>
</array>
Hey mike should we also try adding this code to the appradio info.plist file???
<key>UIApplicationExitsOnSuspend</key>
</false>
Posted Apr 18, 2013 · 23:18 UTC#1169
Thanks a lot for your great work! It's like dickwildernes said before like kids on christmas ;)
Yes. Is the AppRadio app crashing after 30 seconds for anyone else? I'm trying to figure out if the results are mixed or if everyone is seeing the issue.
I've got the issue too. Scrolling also does not really work.
iPhone 4s iOS 6.1.1
AVH-8500bt
Posted Apr 19, 2013 · 00:29 UTC#1170
I have the pioneer 1500dvd with jailbroken 4 with the Pioneer CD-1u50V cable. I also have app radio ext 1.82 on my phone and I have the latest app radio est on ym phone as well how do I go about getting this on my screen? Do I need a special cable or somethign to be able to see my unsupported apps and how can i control them from my indash any help will be appriciated.
Posted Apr 19, 2013 · 00:47 UTC#1171
Yes.
Posted Apr 19, 2013 · 01:07 UTC#1172
Unsupported apps show up on AppRadio 2 and does open, but will not allow gestures on the head unit, only on the iPhone.  Any solutions?
AppRadio Extensions v2.0.1-42
iPhone 4 v6.1.3 (jailbroken)
Posted Apr 19, 2013 · 02:11 UTC#1173
It's anyone with an iPhone 4S having the problem with iOS killing the appradio app after like 30 seconds of being inactive or is this a problem with iPhone 4 users only?
Posted Apr 19, 2013 · 02:14 UTC#1174
Mike can I download this file on iPhone an open it in ifile?
I have my auto lock set to off I wonder if I can get over 30 secs of app time.
iPhone 5
Edited Apr 19, 2013 by Jas0n
Posted Apr 19, 2013 · 02:18 UTC#1175
I have no issue at all but i have insomnia and infinity task dont know if thats making a difference.  But used an app for like 20 min with no problem.  also have UIBackgroundModes in plist.  Works great.
Does any body know how to add apps to sbrotator to turn on or off or then the ones that are already there.
Mike thanks for the iPad in my car.
Page 47 of 98
