🔒 Locked
AppRadio Extensions 2.0 Beta - Full iPhone control
By mikedecaro · May 06, 2012in AppRadio, AppRadio 2, AppRadio 3💬 2,444 posts👁️ 945,070 views
Page 60 of 98
Posted May 25, 2013 · 19:43 UTC#1476
Hey man good job, I think you should add a weather Icon that shows the temps to homescreen, would be boss shit
Posted May 25, 2013 · 20:38 UTC#1477
unsupported apps.  I dont really use the supported ones any more.  I use iOS instead of pioneers OS.  I like using the springboard
Posted May 25, 2013 · 22:08 UTC#1478
same behaviour for me. (resizing issue).the screen is scaled down a bit on some app.
4s  6.1.2
sphda-02 4.16
app 2.3.0
beta 12
+ Ios Keyboard calibration is loss with whatsapp
Posted May 26, 2013 · 00:30 UTC#1479
I am having problems getting any of the functions of AppRadio Extensions to work.
I have AppRadio SPH-DA02
AppRadio App Version 2.3.0
App EXT Version 2.0.1-1
AppRadio FW 4.16
Apple 4 -jailbroken running 5.1.1
I don't know if it has something else installed on my phone that is not making it possible to use AppRadio Extensions. I have read through several posts and found no help. I was wondering if anyone else is having/had issues similar to mine and if so what was done to resolve the issues?
Posted May 26, 2013 · 01:03 UTC#1480
AppRadio FW 4.16
You need version 1.8.2 of the AppRadio app. Check out the FAQ.
Posted May 26, 2013 · 01:14 UTC#1481
Thank you for the quick reply. What you are doing here is greatly appreciated. I tried 1.8.2 a couple of days ago with no success but I wasn't running the 4.16 FW update at the time. I will try again. Thank you
Posted May 26, 2013 · 02:46 UTC#1482
Works great, thank you Mike
Posted May 26, 2013 · 07:49 UTC#1483
So it looks like there is a new Backgrounder app in Cydia called Backgrounder Manager. Time to test it out with the app radio!!! Hopefully Mike can use this for his extension!  I've been playing with it for a little bit and it seems to work ok... sometimes I have to reconnect my cord for it to display on the app radio though..  Will do more testing tomorrow
Edited May 26, 2013 by evodris
Posted May 26, 2013 · 12:26 UTC#1484
i have a iphone 4S running 6.1.3 os.  Is there any way i can use app radio extensions? i have a pioneer app radio 2.
Posted May 26, 2013 · 15:49 UTC#1485
I know it's up and running now but wasn't sure if maybe this would help. There is background manager now in cydia that is a backgrounder for iOS 6
Edited May 26, 2013 by bear52885
Posted May 26, 2013 · 22:28 UTC#1486
Does the screen size issue happen all of the time? only when using unsupported apps?
I've got the same problem, i discybed it a vew posts ago...
With the last beta I had the problem only with unsupported apps but with the new beta I had it with waze...
so it happens with all apps...
Posted May 26, 2013 · 23:09 UTC#1487
Mike,
I haven't been keeping up with the forum lately but I remember unsupported apps stopped working in iOS 6 as Backgrounder is ios5 only. I just found a replacement for Backgrounder in Cydia called Background manager (http://forums.macrumors.com/showthread.php?p=17314781). It works beautifully. Maybe that would allow us to run any app on AppRadio screen with touch enabled, just like it was in ios5? Hope this helps you, thanks for you great amazing work!
Posted May 27, 2013 · 01:26 UTC#1488
We're way ahead of you here. AppEx has been working on iOS6 for a little while now.
Posted May 27, 2013 · 03:59 UTC#1489
I was hoping this backgrounder would resolve my issue with appradio crashing after 20 seconds of not touching the radio for unsupported apps. Unfortunately it did not. It was buggy for me. When appradio was enabled I had trouble getting the headunit into appradio mode.
Posted May 27, 2013 · 18:54 UTC#1490
But does it support touch gestures on the AppRadio for unsupported apps?
Posted May 27, 2013 · 19:17 UTC#1491
Yes
Edited May 27, 2013 by Tomfoolery82
Posted May 27, 2013 · 19:17 UTC#1492
Yes, main issues at the moment are crashing after 30 seconds for a handful of users (mine has been fine), landscape lock not working for some unsupported apps, and calibration for iPhone 5's isn't quite perfect yet. Other than that its all working with touch support perfectly :)
Posted May 27, 2013 · 19:33 UTC#1493
That is not quite true iPhone 4 has a major lag problem, large apps will not open just hang and then return to the springboard but small things like calculator work fine - at least on my set-up.
Posted May 27, 2013 · 21:06 UTC#1494
Yep sorry that's true, there is a lag issue with iPhone 4. Not heard of the other issue you mentioned though.
Posted May 28, 2013 · 02:36 UTC#1495
Yes
Tomfoolery82 use the QUOTE button.
Edited May 28, 2013 by VBLUE42
Posted May 28, 2013 · 12:42 UTC#1496
In beta 10, I had no screen resizing issue, in 11, it was always the small screen with the triangles in the corner and in 12, it is intermittent (sometimes bigger, sometimes smaller). And yes, it is only in unsupported apps (iphone 5 btw). I am also still getting the landscape lock issue where apps stay in landscape even when unplugged
Posted May 28, 2013 · 13:02 UTC#1497
Works good but sometimes the screen is smaller with the triangles on the side. Makes the the keyboard calibration off for me. Also music widget app used to work now it crashes the phone only when connect to app radio. Anybody know how to put a Siri icon on their home screen.
4s 6.1.2 app radio 2 fw 8.17 app 2.3.0 beta 12
Beta 10 had no screen resizing issues. I use sbrotator to rotate spring board and apps works well but when springboard launches the phone rotates (activator when plugged in) but on the app radio it's rotated but vertical. I have to launch the music app to rotate the springboard to landscape.
4s  6.1.2
sphda-02 4.16
app 2.3.0
beta 12
Same issue here as well. If I touch the black bars to go back to the AppRadio Apps screen then relaunch the unsupported app, that sometimes fixes it, but I get the little triangles & the slightly resized screen *A LOT.*
Posted May 28, 2013 · 15:30 UTC#1498
beta 10 was last best configuration for me.
4s 6.1.2
sph-da02 4.16
app 2.2.0
there was no resizing issue and the touch calibration was perfect.
after updating to app 2.3.0, and obviously beta 12 (thanks again mike), the touch calibration is lost.
going back to 2.2.0, beta 10, touch calibration is lost, too! :(
i think the uninstalling process in cydia left some system file 'in'....
i reinstalled beta 10 with ifile.
anybody experienced the same?
Edited May 28, 2013 by Aleraco
Posted May 29, 2013 · 20:45 UTC#1499
I have an iPhone 4s with appex beta 11. I have experienced the slightly resized screen with triangles a few times. It has only ever been on unsupported apps, but not all the time. I use Navigon frequently and sometimes it is slightly smaller with triangles on the sides and sometimes it is normal sized with black bars on the sides. I don't know exactly what I did to fix it, but I think it was either closing Navigon on the phone and reopening it or maybe I unplugged the phone and plugged it back in. It might have to do with whether the unsupported app was already running on the phone in the background when the phone is plugged into the radio. I'll try to be more conscious of what I do to resolve it the next time it happens, or even purposely try to see if I can recreate the issue.
Posted May 30, 2013 · 21:24 UTC#1500
After upgrading Background Manager to 0.9-9 (and also 0.9-10) the 20 second crash issue is gone! Unsupported apps now stay active with touch support.
One issue I'm having (didnt recall anyone else mention this) is that when I play a video, it plays correctly in landscape mode but when the video finishes and goes back to video list, it's now portrait and the video list is small and embedding inside the video player. Hard to describe but I can post a picture when I have time. When this happens I just need to exit and reopen appradio. So no big deal. Just wondering if anyone has this problem.
Some apps like Safari do not go to landscape mode for me automatically. Others do fine like espn. If anyone has this problem, try using UI Rotation for Activator. Works great and you can manually rotate the app to landscape using Activator methods. I rotate by double tapping status bar. This works great because you can do this on the phone and also on the headunit.
Page 60 of 98
