🔒 Locked
AppRadio Extensions 2.0 Beta - Full iPhone control
By mikedecaro · May 06, 2012in AppRadio, AppRadio 2, AppRadio 3💬 2,444 posts👁️ 945,070 views
Page 72 of 98
Posted Jul 21, 2013 · 11:40 UTC#1776
Greetings,
After reading through the posts using the search term "bypass", I am a little confused about what I need regarding the parking brake bypass. I have a iPhone 5, App Radio 3, with AppEx beta 17 installed. I purchased a 4 wire relay from Ebay, but no car audio shop will install it as "that would be illegal and I could get fired"--which I realize is unfortunately true, but frankly I have no desire to take out the head unit (again). So one car audio shop suggested purchasing a toggle switch at Radio Shack. So today I purchased a toggle switch and "cut" the green wire to my parking brake which was easily accessible on my FJ in the center console. So currently I have "green wire coming from head unit, then attached to the toggle switch, then remaining green wire from toggle switch to parking brake". Is this correct? So I toggle it "on"--what should happen? I still seem to get some of the app radio 3's annoying warning screens. On the AppEx settings, I have the App Radio and Pandora Bypass Settings to "accept"--is this correct w/ my set up? I saw where some folks in older posts had their green wires going to "ground" and not to the parking brake at all--I didn't think I could do that on an App Radio 3. Just looking for some clarification.
thanks,
D
And why would you post a bypass related question in a thread about AppEx? You need go back and search again for threads pertaining to the bypass.
Posted Jul 21, 2013 · 11:40 UTC#1777
Overall I'm impressed to see that I can now use Safari as Car Browser won't even load on the AVIC units.
Car Browser works fine for me.
Posted Jul 21, 2013 · 13:01 UTC#1778
Hey what's up everyone mike I haves question I have a iPhone 4s w iOS 5.1.1 jailbroken not sure what appradio ext version I have !
My question is did you ever get any newer versions
Of ios
To work properly w app radio extensions??
I was
Wondering of its
Possible for me to ever upgrade o an iPhone 5 ??? Or I have an iPhone 4s that's a spare that's on the newest iOS ??
Not sure if I can jail brake or not ????
Posted Jul 21, 2013 · 15:22 UTC#1779
Of ios
I was
Wondering of its
AppEx runs on both the iPhone 4S and 5, iOS 6.
You can't jailbreak certain versions of the OS though.
Edited Jul 21, 2013 by mikedecaro
Posted Jul 21, 2013 · 17:49 UTC#1780
But you're using an actual AppRadio (SPH Series) if I recall.  As we have discovered, it appears that the NAV AVIC units were not designed the same so what may work on the SPH series is not working on the AVIC series.  It seems that Pioneer has developed and tested these apps with the SPH series in mind but they didn't do enough R&D to get the other head units up to par with them.
What a lousy company.  Now they added more data mining junk into AppRadio v.2.40 so they can acquire stats from the company Flurry.  They say it's to help improve the app - we'll see.
Posted Jul 22, 2013 · 00:41 UTC#1781
Rorger. Some of that likely needed to be in the pure Bypass threads, but I also was curious about the appEX settings once a bypass of some sort (in my case a toggle switch) has been installed. Any help would be appreciated.
thanks,
d
Posted Jul 22, 2013 · 11:29 UTC#1782
AppEx has nothing to do with the bypass.
Posted Jul 22, 2013 · 18:18 UTC#1783
That's so weird.  I have an iPhone 5 and a Z150 (and latest official release of appext)...the left side of my screen is a little off while the right side is spot on (in landscape).  I can actually fully use it except for any button presses needed on the extreme left side of the screen.
I have noticed the same issue with my X950BH.  I need to touch just slightly to the left of the Q, A, SHIFT, 123 buttons and I also need to touch just slightly above the space bar.  If I hit the space bar dead on, it reboots to the home menu.  All the other keys, however, are spot on for me too.  If I try and adjust the X and Y adjustments in AppEx, it throws the whole thing way off.  Even using small increments like setting X from 1.0 > 1.25.  So for now, I just leave X and Y at 1.0 and try to remember to adjust my typing for the left and the bottom.
Posted Jul 22, 2013 · 20:49 UTC#1784
 Touch sensitivity works perfect now on my AVIC  X940BT since the last AppEX upgrade...
Posted Jul 22, 2013 · 20:58 UTC#1785
Works ace on my F940BT here too. I just have an issue with the app radio connection prompt sometimes not working. Otherwise, best release yet for me!
Posted Jul 23, 2013 · 12:23 UTC#1786
I think I've got to the bottom of why my phone kept crashing when I pressed the home button. It seems it was down to me using PluggedIn to autolaunch Waze. I tried launching other AppRadio apps like ECTouch, CarMediaPlayer etc. and had the same problems. If I disabled PluggedIn and launched those apps manually, the crashing stopped.
So instead, now I'm using Activator to unlock the phone and launch Waze when the phone is plugged in (the new Activator allows more than one action). However, I've also had to disable FlipSwitch (which the latest versions of Activator install automatically) otherwise I still get the crashing.
I've tried so many different permutations/combinations of disabling Substrate addons so I can't remember for sure but I think the crashes were also eliminated if I disabled the AppRadio extensions. I know Mike has little time on his hands but this might be a bug worth looking into if other people can replicate it.
Posted Jul 23, 2013 · 22:51 UTC#1787
I've done the same. Have just made sure to press slightly left of most buttons on the left half of the screen. Have only seen a couple buttons here and there that I can't press at all…only because they have been on the extreme left side of the screen.
Posted Jul 24, 2013 · 01:50 UTC#1788
Yep...the new Google Maps v.2.x has the button on the lower left hand side for traffic, satellite, etc. and I can't get it to register at all.  Can only do it on the phone.  Thinking about downgrading back to Google Maps 1.x.  Anyway, I think it would be quite challenging for Mike to keep up with all the variations from model to model as they obviously were not designed the same way.
Edited Jul 24, 2013 by Preroll
Posted Jul 24, 2013 · 03:12 UTC#1789
Hi all. I received the AVH-X3500BHS for Christmas and have used it almost exclusively via bluetooth from my iPhone 5. I just now updated the firmware and have been trying to use the guide here to no avail. When I click the home button my "Apps" button is greyed out and I cannot press it. Am I missing a cable, or is this a result of something else? No extra wires were purchased, and the receipt I received showed only the AVH-X3500BHS, Metra 95-7895 and Metra 70-1721. Do I need anything else for App mirroring to work here? I downloaded AppRadioExtensions for my iPhone 5 (jailbroken), but that seems like it's useless for now. I just ordered this parking brake bypass since I'm almost positive that it is necessary. So what can you tell me?
I accidentally posted this in the FAQ because the opening posts looked so similar and I wasn't paying attention. D'oh.
Posted Jul 24, 2013 · 03:19 UTC#1790
Go to the the Pioneer web site and look for details pertaining to your unit involving the i5.
Edited Jul 25, 2013 by VBLUE42
Posted Jul 24, 2013 · 23:11 UTC#1791
On my i5 (AR2) in the middle the calibration is perfect, but on the left hand side you have to press slightly to the left and on the right hand side you have to press slightly to the right. I can press all buttons though. I have set the calibration to 1.007 on the y axis which improves it very slightly (the increments do have to be very small otherwise it does go way off!)
Posted Jul 25, 2013 · 20:02 UTC#1792
That is a small adjustment and what I may need to try.  Did you adjust X as well or just leave it at 1.0?  I would think the Y axis would help the bottom issue instead of left and right.
Posted Jul 25, 2013 · 22:22 UTC#1793
Well no coz as Mike said, when in landscape, x is up/down and y is left/right (counter-intuitively). Also, the up/down for me is spot on, no need for calibration
Posted Jul 26, 2013 · 00:21 UTC#1794
Good to know.  I was unaware of that.
As for me, I'm using an AVIC-X950BH which was designed a bit different (apparently) than the SPH series (in your case the AR2) so the bottom issue only applies to that series as that was confirmed with a Z150 user a few posts back.
Thanks.
Posted Jul 26, 2013 · 14:07 UTC#1795
i have troubles with the following feature:
  • Force apps that natively support the head unit/external displays to mirror instead
my setup: iPod 4 with iOS 6.1.3, Appradio App 2.40, EppEx Beta 17 und Firmware 8.17 on my appradio 2
when forcing an app to mirror the app it does not fully start. 1st the device seems to start the app, but getting reeaaaaaallly slow, after some time the app closes and i´m on the ipod startscreen again
Can please someone help with this problem?
Posted Jul 29, 2013 · 04:54 UTC#1796
Hello, I have been looking for the Appradio extension version 2.0 1-1 in BigBoss repo but I cannot find it for the life of me. Can anyone point me in the right direction to get this older version of the appradio extension?
Posted Jul 29, 2013 · 12:06 UTC#1797
Make sure you remove the beta repo from Cydia first.
Posted Aug 05, 2013 · 11:17 UTC#1798
Hello EveryBody,
In a first time thanks Mike for you very good work about your project ! (Sorry for my english, i'm a French)
I have a Iphone 4 (IOS 6.1) , AppEXT 2.0.1-450 and AppRadio 2.4.0 but it works half the time.
Non-supported applications crash almost all the time after 20-30sec (Return in the SpringBoard) yet they are enabled in the settings.
I just noticed that the version of the AppRadio is greater than that required on the first page.
Could you upload the 2.3.0 version because it is not found?
thank you very much
Posted Aug 05, 2013 · 12:16 UTC#1799
I have been excited to get an appradio 3 ever since i watched Pioneerguys video on youtube with the appradio 2
I wish i would have joined the jailbreak club sooner, but i never really had a reason, till now.
I am screwed because my 4S is on 6.1.3, with no previous blobs saved, and the evad3rs dont plan on releasing another jailbreak till ios7 releases, and it took them 137days to crack ios6, i am hoping they have a head start with ios7 beta being out for the i5.
BTW im new here, so hello as well.
Posted Aug 05, 2013 · 12:19 UTC#1800
Ive seen info about a tethered jailbreak for 6.1.3
Page 72 of 98
