🔒 Locked
AppRadio Extensions 2.0 Beta - Full iPhone control
By mikedecaro · May 06, 2012in AppRadio, AppRadio 2, AppRadio 3💬 2,444 posts👁️ 945,070 views
Page 74 of 98
Posted Aug 19, 2013 · 02:33 UTC#1826
My AppRadio 3 and parking bypass system is on order via Amazon.  I should be able to start the install next week.
In preparation for this I went ahead and installed SBRotater 6 (BigBoss official/paid) and AppRadio Extensions (via mikedecaro.com repo)  ((which I'd gladly donate too once I'm an official user!))
iPhone 5,  Firmware 6.1.2
Since installing these two new apps, It seems my iPhone 5 crashes every 1-4 hours and comes up in SafeMode now.  (when I just let it sit)  I woke up with it in Safemode for example.
Since it's happened 4 times, I finally installed Crash Reporter & Syslog.   I'd like help reporting what the conflict might be once I have good logs to share.       I've been running solid all year until I added both these apps.   So until I get a good crash log to share, I'll start with the basics.
Do my apps have any potential conflicts?  I don't have TV Out or Dimmer installed (the two conflicts listed on page 1)
I used PKGBackup to generate a list of installed packages
https://www.dropbox.com/s/wdk3ukwt99w8bh3/List%20of%20installed%20packages.txt
I'll follow-up with logs when I get them.   I'll probably have to contact SBRotator dev too but thought I'd start here.
List of installed packages.txt
Edited Aug 19, 2013 by JazJon
Posted Aug 19, 2013 · 02:36 UTC#1827
I was having the same problem with SBRotator installed. I think it had something to do with rotating the lock screen, possibly only if an alert is shown. I couldn't figure out what the problem was.
I think AppEx and SBRotator overrides the same built in methods for rotation, causing a conflict/crash.
Posted Aug 19, 2013 · 02:41 UTC#1828
I noticed that I can't always use the "swipe down" gesture to see weather/notifications now either.
Let me try turning OFF rotate on lock screen for starters.    Did you give up and uninstall SBRotator?
Posted Aug 19, 2013 · 04:15 UTC#1829
SBRotator is the problem.
Posted Aug 19, 2013 · 04:46 UTC#1830
Bummer
SBRotator hasn't come out with an update since March.  (nearly half a year ago)  6.4-5
I hope the dev is still looking to improve things at some point.
I'll do my best to see if I can make it through 24 hours.  (I removed several packages I don't "need" as a test)
I'll reach out and send him my logs if not and uninstall it for now then. (oh well)
Posted Aug 20, 2013 · 01:18 UTC#1831
Woke up today to another safe mode, crash reporter says Primary suspect = _iPhoneRotator.dylib
I went ahead and contacted the Elias (the SBRotator Dev) with the logs.   I hope he's still active.  A lot of these dev's get bored and stop innovating or get too busy with their real job etc.  I can only hope he's ready to improve the app so our AppRadio will be a complete experience.
If any experts come across this, feel free to take a look at the attached logs here as well.
Ok, so now I wait for my new AppRadio 3 so I can join in on the fun!  (Amazon says shipping soon)
SpringBoard Crash Log.txt
SpringBoard Syslog.txt
Edited Aug 20, 2013 by JazJon
Posted Aug 20, 2013 · 12:20 UTC#1832
Hi! Some questions:
I have appradio2 with original firmware and iphone 4s (my wife) and 4 (me), and all work ok!
Recently I change my iphone 4 to samsung Galaxy 4. I want to only use ipod fuctions for play music. What options I have?
- No A2DP Support?? (appradio3 have it. grrrrr)
- some 30pin adaptor to microusb (only for ipod function) ?
- Buy and old ipod touch 4g and always plugged?
- The original hdmi cable from pioneer. It's posible coexist iphone 4s and galaxy4? 2 cables conected at same time?
any other "simply" and economy ideas?
Thanks for your answers
You should probably start a new thread for that complex non extension related question.
If you want to use the AppRadio for both you and your Wife at the same time, you should probably get some kind of HDMI splitter.
This one works great, and is self powered  (and is automatic, it changes to last sorce detected)
http://www.amazon.com/HDMI-3-In-1-Out-Switch-Cable/dp/B0018DQYQ2/ref=sr_1_1?ie=UTF8&qid=1377001013&sr=8-1&keywords=HDMI+splitter
I wonder if you can find a USB switch that will auto sense the last input used as well.  (or maybe a simple manual switched one)
There are several on amazon after doing a quick search. (maybe try ebay too)
http://www.amazon.com/s/ref=a9_asi_1?rh=i%3Aaps%2Ck%3Ausb+automatic+switch&keywords=usb+automatic+switch&ie=UTF8&qid=1377001097
This way you can have both cables ready to go!
Add the lightening to hdmi adapter too if you want video for iPhone 5 and you'll have a better solution since the 4S uses that extra funky analog cable.  (so you might want to get your wife the iPhone 5 so the above solution works!)
Posted Aug 20, 2013 · 19:31 UTC#1833
This is off topic and has nothing to do with App Ex. The original post has been deleted. Please remain on topic.
Posted Aug 21, 2013 · 05:38 UTC#1834
The iOS YouTube app was just updated to version 2.0 today.   Can someone see if it works well via AppRadio Extension?
http://modmyi.com/content/11918-youtube-2-0-launched-ios.html
Also just saw:
http://modmyi.com/content/11916-google-announces-google-maps-users-can-now-take-advantage-waze-incident-reports.html
Google Announces That Google Maps Users Can Now Take Advantage of Waze Incident Reports
Edited Aug 21, 2013 by JazJon
Posted Aug 21, 2013 · 10:09 UTC#1835
Thanks, I investigate it and sorry for my off-topic, but always follow this post for my iphone configurations.
Posted Aug 22, 2013 · 03:58 UTC#1836
Is the SPH-DA100 or SPH-DA02 the appradio 2 everyone mentions on here?
How does the SPH-DA02 work with an iphone 5 and extentions? (is it even compatible since sph-da02 hasn't been updated in over a year)
Posted Aug 22, 2013 · 04:03 UTC#1837
The DA100, 110, and 210 are the only units compatible with the i5. The 02 is part of the AR1 series.
Posted Aug 22, 2013 · 10:15 UTC#1838
HI Mike, I have iphone 4S with iOS 6.1 and i read through plenty of the posts, tried installing what you said, failed. I then tried to get an ipad going with iOS 5.1.1 jailbroken, AppSync'd 5.0 and cracked appradio 1.8.2 via itunes, and its just not loading onto the ipad when i sync. whats my next move? I have a house full of iOS devices and AVH-X5550BT direct from Thailand. everything about it rocks except what i bought it for... Help!
Posted Aug 22, 2013 · 10:39 UTC#1839
Ok just reread the FAQ for the iphone 4S with iOS 6 and went through the procedure, and so far its not crashing every time I add an app. So thats cool. I get the car back tomorrow and if this works then i dont need the ipad to work, although it would be cool to have them both working as i just bought the ram mount for the ipad... so gonna put that in the back seat centre and have ipad head unit mounts behind both seats... hopefully it all goes according to plan...
Posted Aug 23, 2013 · 00:33 UTC#1840
How can i make it to Full Screen Mode when i use an app?
Posted Aug 23, 2013 · 19:23 UTC#1841
Is there anyone out there using this AppEX with an iPhone 3gs that cares to share experiences? I really dont want to go buy an iPhone 4s just to use GPS on my head unit...x5500bhs by the way. Thanks in advance.
Posted Aug 23, 2013 · 19:31 UTC#1842
If you are referring to the black bars on either side of the screen while using unsupported apps the answer is no.
Posted Aug 23, 2013 · 22:00 UTC#1843
I use Navigon.
Posted Aug 24, 2013 · 09:26 UTC#1844
I use Navigon.
There is still a bug in appex for navigon, Mike told he will look at it, but thats already a few months back unfortunately.
Posted Aug 24, 2013 · 20:26 UTC#1845
@Mike give it away to use Navigon in Full screen Mode?
Posted Aug 25, 2013 · 07:49 UTC#1846
Very cool, just plugged in the 4S on iOS 6.1 & it all works, full screen control, from home button, running Tom Tom & TuneIn Radio same time, got full functionality :) Mike you are a star, I just might do this for the iPad too as I am struggling to get 1.8.2 working with it
Posted Aug 25, 2013 · 09:43 UTC#1847
My new AppRadio 3 was installed Friday.  I've been playing around, so far so good.  Thanks to AppRadio Extensions things like Google Maps are touch enabled :-D
I didn't expect to like MixTrax so much.   It's breathed new life into my music mixes, and I love the short attention span mode track to track all matching beats.
It really sucks that you can't have MixTrax running in the background.  When you hit the home button, music STOPS!  WTF?    CarMediaPlay, Pandora, Aupeo, or non supported apps like TuneIn Radio keep the music going in all modes.
Is there a trick to force MixTrax to continue playing when I'm ready to use Google Maps etc?  (like maybe intercept the calls handing it off to AppRadio, leave it in iPhone only mode)
That's my only complaint so far, Pioneer's flag ship MixTrax music app won't play music in the background!  Is it because the auto-mixing is too CPU intensive?   There has to be a jailbreak around that limit.  (Ideas?)    it's also pretty slow to start with the long animation, and then doesn't even bother resuming. (have to click no playing, then play)
I'll post a mini video review in the near future once I dial things in more.
Edited Aug 25, 2013 by JazJon
Posted Aug 27, 2013 · 12:50 UTC#1848
Any news on full screen support yet?
Refresh cydia every morning hoping for an update
Posted Aug 27, 2013 · 13:06 UTC#1849
I'll take a look at it this week, but I can't guarantee it working correctly on all devices. It's going to mess with the calibration (when enabled).
Does everyone just want the screen stretched to fill?
Posted Aug 27, 2013 · 13:11 UTC#1850
I would prefer it just stretched. Or would it be possible to create "skip forward" & "skip back" buttons in the areas to each side? So when we have GPS or something running, we can still skip music using those areas on each side. It would be nice if they could actually show skip buttons that way too instead of just black bars, if that's at all possible...
Page 74 of 98
