Is it possible to Listen Radio FM and use the appradio Mode?
Yes but that has nothing to do with AppEx.
How it Works?
When i use navigon the Radio doesnt work.
Anyone know if the appradio/car media play apps are safe to update?
I just updated them and checked in car, everything is still good here, using i4s 6.1.2 + da100
not working in my car.
iphone 5, 6.1.2, with the latest update released a few days ago.
Works for me.
Hey Mike,
Love what you've done so far, your work has been absolutely essential in fully realizing AppRadio's capabilities. I'd like to confirm another vote for, "yes" in removing the black bars on each side of the screen when using an unofficial app and going full screen.
Thanks again!
So here's the problem I'm dealing with. Hopefully someone can help me out.
My appradio 3 looks normal and doesn't have the "more apps" setting. Where can I find this?
Setup:
APPRADIO 3
iphone 5 with installed package found at mike's cydia depository
6.1.2 jb, latest pioneer software on the appradio and app
Instructions:
Install all of the dependencies.
Install the beta version of AppRadio Extensions.
Start the AppRadio app.
Launch an unsupported app from the menu. These can be added via the 'More Apps' setting.
The unsupported app should show on the phone screen and the radio.
Control the iPhone app from the radio.
Press on the black bars to the left or right of the app window to go back to the AppRadio app menu.
More apps is found on the phone settings for AppEx.
Working fine for me.
Anyone know of a fix for SBRotator crashing the phone or another program that will rotate the home screen/ other apps that don't rotate.
I sent the developer my crash logs, never heard back yet. I uninstalled and gave up for now. I probably don't even wan't need it the way I use my AppRadio now.
He isn't going to care about an issue that 90% of his user base doesn't experience because they don't use his app for this purpose.
FOUND IT!
THANK you so much!
just gotta go into settings (on the iphone) and go into the Appradio extensions settings.
I sent mine also, nada.
It crashes my phone just being installed/enabled. It actually works when I need it but sitting charging my phone resprings frequently into safe mode which I then have
to fix.
It is off the phone now but I'd like to be able to turn screens that don't rorate.
Hello,
I've got an iphone 4S jb with the repo of mikedecaro (appradio extensions) in ios 6.1.1.
Is compatible the appradio extensions with the new ios 7?
Thanks,
No. Especially sense there is no jailbreak for iOS7.
Cosmo what is the reason for reporting the post from e30cab?
Sorry, I registered yesterday and I was wrong. I forgot to activate the account and did not appear the reply button.
Maybe I was wrong the question. I know there is no jailbreak for ios 7, the question is if it will be compatible when jb available.
We wont know that until an iOS7 jailbreak is available.
Hello I have an extra iPhone 4 running iOS 7. I also have an avhx5500. I plan on throwing my iPhone4 in the glovebox and do not plan on touching it. OK now what version of iOS should I downgrade to? Can some some please layout the sequence of events for me to accomplish this, I know how to downgrade and jailbreak. I just don't want to downgrade to the wrong version of iOS. Like I said I want to try and access as much of my iphone from the radio, without having to grab the phone out of the glovebox. Thanks.
Unfortunately you have to touch your phone once in a while even with the right ios and Appext installed, remember that the blobs in cydia for ios 6.x.x do not work, if you saved them manually then your are good to go, if not you won't be able to downgrade from ios 7.
I'm using 6.1.2 with the latest appext installed and it works like a charm.
My iPhone 4s is running iOS 6.1.2 with AppEx and Activator installed. I have an iPhone 5s and my 4s is just hooked up to my car and tucked away used for navigation & music. I almost never have to touch my phone. I achieve this using Activator with the following settings:
Activator > Connected to Power > Unlock & Launch AppRadio.app Activator > Disconnected from Power > Pause Music & Lock Phone
Configured this way, as soon as my deck turns on, it starts charging the iPhone, which then Activator unlocks it and launches the AppRadio.app for me. I do give it a minute to ensure the AppRadio app has launched and initiated connection with the deck, then I press "OK" on the AppRadio deck screen and it's already at the AppRadio.app Launcher screen. I've also changed it to launch CarMediaPlayer.app instead, Stezza.app, Waze.app, and a few others. As long as they're officially support apps, it seems that they are automatically shown if I press "OK" after I wait a minute or so to allow everything to launch & connect in the background. This works really, *REALLY* well for me and, like I said, I barely ever have to touch my phone. I suppose if you left your car too long the iPhone battery could die and then you'd be forced to relaunch everything, (maybe? though if it boots from charging, Activator may still do the rest once it turns on and sees it's connected to power). I haven't experienced this yet because I shut off all of the extras I don't use, (like Bluetooth & such).
I hope this helps! Let me know how you make out.
ADDED: Forgot to mention; for this to work, you can't have a passcode set on your phone, or else Activator can't unlock it without you entering the passcode.
So this extra phone you have also 3g/4g data?
No it has no service at all. I just use apps that don't require data such as Stezza, CarMediaPlayer, Sygic, NavFree, Navigon, etc.
ADDED: If you have hot spot on your main phone, you can connect via WiFi using the extra phone. I did that before using an iPod Touch on the AppRadio and MyWi on my iPhone 4s. Only reason I didn't keep the iPod Touch instead was it ran like crap with AppEx.
