🔒 Locked
AppRadio Extensions 2.0 Beta - Full iPhone control
By mikedecaro · May 06, 2012in AppRadio, AppRadio 2, AppRadio 3💬 2,444 posts👁️ 945,070 views
Page 78 of 98
Posted Sep 25, 2013 · 21:52 UTC#1926
Did any of you install the recent update to AppRadio 2.5.0? I installed it on my iPhone 4S / iOS 6.1.1. / latest AppEx. Since then I haven't been able see ANY of my standard AppRadio apps like CarMediaPlayer, Waze, EC Touch, etc... My "unsupported" apps are showing, YouTube, Google Chrome, Netflix.
I've deleted and re-installed AppRadio 2.5.0 twice with the same result. After each install, I had to go into AppRadioExtension and turn ON each of those apps to "show." But they're not showing still.
If I want to downgrade to AppRadio 2.4.0, how would I do that? Halp!
Edited Sep 25, 2013 by BigDonVincenzo
Posted Sep 26, 2013 · 14:25 UTC#1927
I had the same problem. You need to start the app not connected to the radio and brows the apps available. Before it lets you do this you have to pick your region. Once you pick your region the next time you connect you can see all of your apps.
Posted Sep 26, 2013 · 16:29 UTC#1928
Thanks. I figured that out. What I didn't figure out until just now is that Location Services needed to be on. Otherwise it won't let you pick a region and thus show compatible apps. All fixed now. Happy AppEx-ing :)
Posted Sep 28, 2013 · 21:06 UTC#1929
My iPhone 4s is running iOS 6.1.2 with AppEx and Activator installed. I have an iPhone 5s and my 4s is just hooked up to my car and tucked away used for navigation & music. I almost never have to touch my phone. I achieve this using Activator with the following settings:
Activator > Connected to Power > Unlock & Launch AppRadio.app
Activator > Disconnected from Power > Pause Music & Lock Phone
Configured this way, as soon as my deck turns on, it starts charging the iPhone, which then Activator unlocks it and launches the AppRadio.app for me. I do give it a minute to ensure the AppRadio app has launched and initiated connection with the deck, then I press "OK" on the AppRadio deck screen and it's already at the AppRadio.app Launcher screen. I've also changed it to launch CarMediaPlayer.app instead, Stezza.app, Waze.app, and a few others. As long as they're officially support apps, it seems that they are automatically shown if I press "OK" after I wait a minute or so to allow everything to launch & connect in the background. This works really, *REALLY* well for me and, like I said, I barely ever have to touch my phone. I suppose if you left your car too long the iPhone battery could die and then you'd be forced to relaunch everything, (maybe? though if it boots from charging, Activator may still do the rest once it turns on and sees it's connected to power). I haven't experienced this yet because I shut off all of the extras I don't use, (like Bluetooth & such).
I hope this helps! Let me know how you make out.
ADDED: Forgot to mention; for this to work, you can't have a passcode set on your phone, or else Activator can't unlock it without you entering the passcode.
Great tip!!!!
Posted Oct 08, 2013 · 11:47 UTC#1930
Hi Mike!
Tell please, when You going to add support for the 3GS screen resolution?
Posted Oct 08, 2013 · 13:03 UTC#1931
Hi Mike!
No plans for anything 3GS related.
Posted Oct 08, 2013 · 13:50 UTC#1932
Mike, Is correcting the configuration file will solve my problem  (small screen) ?
I will be grateful for your response
thank you
Posted Oct 13, 2013 · 16:07 UTC#1933
Activator > Connected to Power > Unlock & Launch AppRadio.appActivator > Disconnected from Power > Pause Music & Lock Phone
Hi oneyozfest182 - i'm about to jb my iPod touch 4th gen, simply so i don't have to keep pressing "ALLOW" on the touch once it's connected! So once i have installed all of the necessary apps that are detailed on post 1, i also then find Activator in Cydia, and install that.
I assume i then boot up Activator on the ipod, and it's within the Activator settings that i ensure the above 2 instructions are set? Is that right?
Many thanks - i only use my touch for music and sat nav (have igo primo installed).
Ta :)
Edited Oct 13, 2013 by delboymel
Posted Oct 13, 2013 · 17:42 UTC#1934
Yes.
Posted Oct 14, 2013 · 12:56 UTC#1935
Ta :)
Yessir. You can also find the "Activator" settings in your default settings app once it's installed via Cydia.
iGo Primo GPS works on the iPod Touch? I didn't think the iPod Touch had GPS.
Posted Oct 15, 2013 · 21:38 UTC#1936
I see software updates are out for the older AVIC Units.
Anyone installed it to see if it affects use of Iphone or Ipod 4 and App Extensions or otherwise?
Thanks.
Posted Oct 16, 2013 · 01:34 UTC#1937
Is there a way to get Spotify to rotate & go full screen?
Posted Oct 16, 2013 · 02:29 UTC#1938
Spotify doesn't support landscape last I checked.
Posted Oct 16, 2013 · 02:34 UTC#1939
Bummer.
Posted Oct 17, 2013 · 19:37 UTC#1940
use flex to rotate spotify works for me
Posted Oct 17, 2013 · 20:37 UTC#1941
Perfect!
Posted Oct 17, 2013 · 22:09 UTC#1942
Sorry for the dumb question but where can I find Flex?  Will this fix apps that don't "auto rotate" to lanscape like Safari?
Posted Oct 18, 2013 · 10:34 UTC#1943
Search Cydia.
Posted Oct 18, 2013 · 18:48 UTC#1944
Search Cydia.
Found it thanks.
I guess I should now compare it to Zephyr.
Posted Oct 19, 2013 · 14:51 UTC#1945
So i have to delete any TV Out package (DisplayOut, Landscape TV Out, TVOut2, etc.) in order to use appradio extensions tweak on my jailbroken I5? I have the the avhx4500. Thanx!!
Posted Oct 19, 2013 · 16:17 UTC#1946
Thats what it says in the first post.
Posted Oct 22, 2013 · 07:44 UTC#1947
Hello, new user here. I've been following this forum for some time and finally bought an appradio2 (awaiting parcel atm).
I've read all this thread but maybe i forgot/missed some posts, so forgive me if it has already been asked:
I've an ipod touch 4g which i kept on ios5 on purpose for the appradio. Today news is jailbreak for 6.1.3 coming in few days therefore i'm wondering if current state of the beta appradio extensions is stable enough to upgrade the ios, any advice?
Posted Oct 23, 2013 · 00:00 UTC#1948
Hello, new user here TO
tks  for the good job
my  dumb question
cant i make works and iphone 5  jailbreak 6.1 whit the appradio 1 ?
tks
sorry for mii inglish
Posted Oct 23, 2013 · 23:33 UTC#1949
hi mike new firmware has just been released for sph-da02 (fw 4.17). they say to make it ios7 compatible.
i'm still on ios 6.1.2, and i have no intention to upgrade mi iphone 4s.
the unit, on the other side, really needs some better coding.
do you think i'll get any advantage in stability and overall perfomance of the unit itself making an upgrade to fw 4.17?
do you think they just fixed the ios7 compatibility?
Posted Oct 24, 2013 · 11:58 UTC#1950
I have not resolved the problem with my iphone 4 IOS5.1 and AppRadio sph-da01.
I have just read all topics (more than 63 pages).
More test I have execute: New AppRadio + AppRadio Extension (IOS6 version and IOS5 version), AppRadio1.8xx cracked and so on.
The unsuported app and the IPhone screen is not available in the sph-da01.
Can ou help me?
-What is the AppRadio that I have to install?....The version that I can install from the AppStore?
-What is the correct version of the AppRadio extension that I have to install?...where I can download it?
-What is the step to install and test that it works fine?
-All additional information and resource to resolve this problems are welcome.
Thanks a lot for the support.
Page 78 of 98
