[GUIDE] [X930BT/X940BT] - Remove 'CAUTION - SCREEN IMAGE MAY BE REVERSED' text overlay on backup camera
By arizzle · May 13, 2012in Hacks/Mods💬 34 posts👁️ 41,934 views
Page 1 of 2
Posted May 13, 2012 · 23:03 UTC#1
UPDATE: Confirmed for X930BT running 4.0010 Z140 firmware (unconfirmed on pure X940BT).
Background: I am using the reverse camera as a video input for some digital gauges I've managed to get working via a long string of hacks. I originally had the video driving the AV2 input on the X930BT, but I realized that I am not able to listen to music and display the (video-only) gauges, so I decided to try using the input for the reverse camera since it is just an overlay on top of whatever source is driving the sound, and then use an external switch to toggle the 'reverse / gauge' mode.
Well, all went according to plan until I realized the X930BT unit overlays a text CAUTION message which is useless and annoying for my digital gauge display. Enter this hack.
Thanks to Ralpharn to pointing me to the right files in the X930BT filesystem.
Here is my version of a digital-gauge display on the X930BT, maintaining normal AV operation.
Removing the ‘CAUTION: SCREEN IMAGE MAY BE REVERSED’ message:
Thanks to:
condiczek, sebastian32, and Ralpharn, and the creator of WinHex
Head units and other electronics that have international markets will usually store text strings in separate files on a filesystem in order to look up different text-strings from different languages for the same message prompt. The idea is to find the English text string that drives the text for the backup camera CAUTION overlay, and replace the characters in that message with spaces.
Getting your original files:
  1. Enter Testmode, copy contents of your X930BT/X940BT USER directory to your SD and back this up on your computer
    1. Read the directions from Condi’s thread FYI, but all you're using is his compressed package (I used v1.4) during this procedure to enable Test Mode and gain access to the file system
      1. http://avic411.com/i...dated-13062011/
      [*]Copy the contents of the compressed file in Condi’s thread to the root of your SD CARD (need TESTMODE.KEY on the root of the SD)
      [*]Insert your SD CARD into the X930BT and turn it on, it should boot into Test Mode (IF NOT, STOP HERE AND REFERENCE CONDI’S THREAD)
      [*]Navigate to File Maintenance
      [*]Copy the USER directory to your SD to back it up (need to enter the USER directory, select all, copy, navigate to you SD, paste)
      [*]Turn off X930BT, remove SD card, copy USER contents from SD card to safe location on your computer (DON’T EVER LOSE THESE FILES, THIS IS THE ONLY ‘STOCK’ IMAGE YOU HAVE!)
      [*]From your backup of your USER directory, determine if the file PRG.FLG exists in the USER\ directory. The presence of this file indicates your system uses the USER\PRG1 directory instead of the USER\PRG0 (these can be considered backups of each other). In any below references to USER\PRG0, use instead USER\PRG1.
      1. navigate to USER\PRG0\Apl\LANGDATA\StringData\, verify there exists the following two files:
      USER\PRG0\Apl\LANGDATA\StringData\EUGBENG.LNG
      USER\PRG0\Apl\LANGDATA\StringData\UCUSENU.LNG
      Performing the mod:
    • Open these two files listed above in WinHex. Search for the ASCII code for CAU by pressing Ctrl+Alt+X (or Search, Find Hex Values). There will be two instances of the string we want to ‘space out’ per file. Text string: CAUTION: SCREEN IMAGE MAY APPEAR REVERSED
  1. See before: post-53130-0-24477800-1336949942_thumb.jpg
  2. And after: post-53130-0-06494900-1336949935_thumb.jpg
  3. Here are the hex blocks (the specific bytes you're looking for so you can do a ‘search and replace’:
    [*]Save these modified files somewhere on your SD CARD you can reference later
    [*]Go back to your X930BT, enter the SD CARD, and turn on the unit (SD should still contain TESTMODE.KEY and should boot into Test Mode).
    [*]Enter File Maintenance
    [*]Navigate to USER\PRG0\Apl\LANGDATA\StringData\ and delete EUGBENG.LNG and UCUSENU.LNG (must delete, will copy identical (but hacked) files from SD CARD)
    [*]Navigate to your SD card and copy the 'hacked' EUGBENG.LNG and UCUSENU.LNG to USER\PRG0\Apl\LANGDATA\StringData\ (NAVIGATE, SELECT, COPY, NAVIGATE, PASTE)
    Voila. No more CAUTION message overlaid on your screen.
    Assumptions:
    I'm assuming these files are different for each unit, and thus you need to use WinHex to modify your own versions of the file. In case these are just generic files, I have attached my 'hacked' versions of the LNG files which would allow you to skip step 3. We can disprove my assumption and thus skip step three permanently if someone sends me their LNG files to compare.
    Download:
    Below - password is avic411
    CamCautionMod.zip
HEX BLOCK for which you’re looking: 430041005500540049004F004E003A002000530043005200450045004E00200049004D0041004700450020004D004100590020004100500050004500410052002000520045005600450052005300450044
HEX BLOCK you want to replace it with:
200020002000200020002000200020002000200020002000200020002000200020002000200020002000200020002000200020002000200020002000200020002000200020002000200020002000200020
Edited Dec 28, 2012 by arizzle
Posted May 14, 2012 · 00:25 UTC#2
Two thigs you need to know:
1. If you have updated unit your working directory can be USER\PRG1\Apl\LANGDATA\StringData\... instead.
2. Apl\LANGDATA\StringData\... contains few language files, you can read them using any text viewer like notepad. So if you need to modify other language- just use right file.
EUGBENG.LNG is EUropean unit with Great Britan ENGlish . LaNGuage.
You also can add interface language by replacing unused file that visible from your unit with one you need.
Posted May 22, 2012 · 19:57 UTC#3
Screw the warning message, can you tell us how to get the gauges?? Lol.
'04 WRX here and would love that...
What else did it take besides hacking the unit itself? How is it getting all the readings?
Posted May 29, 2012 · 16:40 UTC#4
Does this remove the bluriness when then input hits the video driver as opposed to the pre startup direct feed??? I'm using a backup cam and just wanted to know before I try it
Posted May 29, 2012 · 17:00 UTC#5
Looks like torque running and outputting video to the HU. Is this through a tablet or a phone that you've got this set up?
Posted Jun 03, 2012 · 18:50 UTC#6
Heh, thanks :)
Ya it is torque running on an Android device. I found out the original Samsung Galaxy S phones can output video through the headphone jack; a perfect 1-for-1 of what is on the screen is piped out an RCA-headphone cable (see for yourself: www.youtube.com/watch?v=GTQBAx_BDfk). So I grabbed a scratched, used Galaxy S off Craiglist, and found the headphone-RCA cable off the internets. The hardest part has been getting the automation correct in Android to power down / go into airplane mode when the power is disconnected, and then bring everything back online when the power is back on. I'm using the app 'Tasker' to achieve this.
Torque, the app running on the Android phone, connects to the car using a standard OBDII to bluetooth adapter. Just search 'ELM327' on ebay and you'll find a bunch of different types that all serve the same function, to allow your android device to connect to your OBDII port over bluetooth. Having torque there is awesome for the logging capabilities, if you haven't used it yet PLEASE download it, grab an adapter off ebay, and support the author. It's probably the best app I've ever seen for android.
So far no negatives with the whole setup besides a lot of learning, and it definitely gets a good 'wow' factor from anyone that looks. I'm looking forward to using it on a track-day so that in-car recording shows a bit more of what's actually going on in the engine.
Edited Jun 03, 2012 by arizzle
Posted Jun 19, 2012 · 18:42 UTC#7
I changed mine to ‘EXTRA POINTS FOR SHOPPING CARTS and GARBAGE CANS’
Posted Jun 21, 2012 · 15:05 UTC#8
Just checked, yea it still goes blurry.
TopCoder... effin awesome :)
Posted Aug 22, 2012 · 10:43 UTC#9
Will this work on the x-940 HU?
Jimbo
Posted Aug 23, 2012 · 01:09 UTC#10
Jimbo
If your testmode allows you to replace files- yes. as far as I konw new X940's testmode- does not support copy/past features.
If by some wild chance your unit is not locked, make backup first! (and share it! please!)
Posted Aug 28, 2012 · 10:16 UTC#11
You are right. I cannot copy and paste. Just have to wait to see who can crack this open!
JImbo
Posted Sep 26, 2012 · 23:48 UTC#12
Which files or folders do I backup?
Jimbo
Posted Oct 04, 2012 · 19:44 UTC#13
Jimbo
your USER\ directory
Edited Oct 04, 2012 by arizzle
Posted Oct 04, 2012 · 23:55 UTC#15
I could not find the user folde so I copied the Nana folder. Would that work?
Jimbo
Posted Oct 05, 2012 · 00:12 UTC#16
developer (aka super) testmode has copy enabled in filemanager. should work fine on 40 series as well.
http://avic411.com/i...re/#entry256194
Will I copy this into Prg0 or into Prg1?
Jimbo
Posted Oct 08, 2012 · 17:45 UTC#17
Jimbo
1. do you have USER\PRG.FLG file present on your system?
(if so your unit boots from PRG1 folder, otherwise it boots from PRG0 folder)
Posted Nov 04, 2012 · 08:55 UTC#18
I am a software engineer and have (nearly) figured out all of the file format for the Avic devices.I made a utility to edit the language files. I have totally customized my stereo including the Caution reverse message. Would anybody else be interested in this utility? It is written as a Windows Utility..
Posted Nov 04, 2012 · 08:57 UTC#19
There are 2 bytes at the end of the file and I thought they might be a checksum, but apparently they are not. Everything else I have figured out.
Edited Nov 04, 2012 by edog85
Posted Nov 04, 2012 · 09:40 UTC#20
hi edog, i wrote a simple perl script for dumping the strings and indexes.. came in handy for trying to figure out which parts of code.
I have figure out several things about these units. Figured out today how to bypass nag screen, and also how to get into mainteannce menu. Interesting for logging and other fun.
The next big challenge i think is to work on skinning. You might be able to help us there.
The big issue was extracting the Image.img (i think somebody already did this) but biggest challenge is to be able to repack after doing custom mod to icons/etc
Posted Nov 04, 2012 · 13:00 UTC#21
I would like to try this.
Jimbo
Posted Nov 12, 2012 · 07:31 UTC#22
Have you all noticed that when you just start your car and HU is still boots- reverse picture is much higher quality and refresh rate is higher (direct commutation?), but after a few seconds it flickers and now on it is low quality and luggy- looks like it was heavily processed and we have this text above?... so it would be great if someone can figure it out how to prevent it to switch to this mode completely.
Edited Nov 12, 2012 by Ralpharn
Posted Nov 12, 2012 · 14:25 UTC#23
That's great! Have you found a way to get rid of the "Caution Agreement Screen" when the NAV is accessed? I would be interested is your utility; can you send a link/file?
x940bt here...
Thanks Glenn
Edited Nov 12, 2012 by OldStyle
Posted Nov 12, 2012 · 19:03 UTC#25
Thanks I've been reading but worried about making a mistake I can't afford. Had to save quite a while for this X940bt. So I have to start-up the unit with the proper file, testmode.key, that will allow copy / paste function. Then backup the user folder (at a minuium) or more. Then edit menu items and/or upload a new file.
Basicily I think that is approx. right but, and I'm not doing this right now, I'll study before the attempt. I have a few issues with this system but mainly I want to get rid of this screen aggrement; clickable image below.
I guess I also need to find some hex editting software.
Thanks for the help!
Page 1 of 2
