Basic Reboot Loop Fix
By tail24 · Jun 01, 2012in Problems/Troubleshooting💬 186 posts👁️ 162,528 views
Page 8 of 8
Posted Nov 29, 2018 · 16:29 UTC#176
On 19-4-2014 at 14:50, guizmo said:
Hallo jouw land is VS Canada of Europese Unie? ik heb volledige back-up voor avic 900bt ik weet niet of hij op je apparaat kan werken, maar ik kan je alle bestanden geven die ik heb.
hoi,
mijn f900bt start ook niet kunt u mij ook helpen. [email protected]
alvast bedankt
Posted Nov 29, 2018 · 16:31 UTC#177
hallo,
mijn avic f900bt strart niet meer heeft iemand hier een oplossing voor.
alvast bedankt
groet, Tat
Posted Nov 29, 2018 · 16:45 UTC#178
waar kan ik de fix downloaden foor f900bt
groet, Tat
Posted Dec 07, 2018 · 14:35 UTC#179
Hi Everyone
I am new here.I just purchased a f900bt. It has some boot up problems. If I switched on the lights were flashed once, and after not happened nothing. When I step into the main menu after few second it was turned off by itself. I had try to refresh the software, but the problem is the installation is started and till 44% was alright everything, after it was turned off, and didn't continued the installation.
Please help me out, how can I fix it.
Toldi
Posted Dec 26, 2018 · 10:34 UTC#180
hola meti en la microsd los archivos avicz110 + testmode y empezo a instalar pero cuando termino se puso la pantalla negra y no enciende,  desenchufe la batería del coche y sigue igual
hello I put in the microsd files avicz110 + testmode and started to install but when I finish it turned on the black screen and it does not turn on, unplug the car battery and stay the same
Edited Dec 26, 2018 by kikasso
Posted Mar 01, 2021 · 14:50 UTC#181
Hi there, if anybody is still tracking this thread would it be possible to send me the files for the UK? I recently got my car back from the Ex and the F900bt is stuck in the startup loop. I have no idea where to start with the issue. Any help would be greatly appreciated. Thanks. Will.
[email protected]
Posted Jun 30, 2021 · 14:38 UTC#182
Alguém tem arquivo de imagem do avic f80tv?
Posted Jun 30, 2021 · 19:33 UTC#183
On 5/31/2012 at 10:27 PM, tail24 said:
This is from a post I just did for another member I feel like I kind of give the short un orgainzed version to lots of people but here is a more organized version. This is not a fix all but it will often fix many reboot problems, some are more complicated which may not allow you in to test mode, or may even reboot after files have been replaced. This should be attempted before the Pinned MBR fix is tried.
go to this thread ; http://avic411.com/i...f-avic-f-files/ Its also pinned to the top here "Torrent Full of Avic F files" download the zip with a torrent file with in it. Use a torrent downloader (Azerus Vuze, Utorrent, Bittorrent, ect) to download the larger torrent to your computer (its 8.4 gb and should take much of the rest of the evening to download). Once these files have been downloaded
1. Format an SD card that is at least 2 gb big.
2. Unzip the file you have downloaded
3. Locate the File Testmode V 2.3. Open folder Copy the folder within entitled "testmode"
4. Paste that file into the root level of your SD card
5. Locate folder "My Flashdisk Back up" Open it then Open the folder 2.0 f700 Copy this folder
6. Paste that file/folder into Root level of your SD card along with "test mode"
7. Eject SD card and head to car
8. Put SD card in avic and turn it on
9. wait for avic to load into test mode (likes like windows 95 its called WindowsCE)
10. Click Start > Programs> Windows Explorer
11. Double Click SD card > Double Click f700 up top click edit>select all then Edit>Copy
12. Click Start > Programs > Windows Explorer (again) to open a second finder window
13. Double Click "My Flash Disk" that looks like a grey little icon
14. you will see a bunch of folders and icons it should look similar to when you opened F700 folder from SD card Click uptop Edit Paste
15. If you are given an error message about not enough room ignore or x it out ( i forget the exact step)
16. If asked if you want to replace file, select YES ALL
17. You will see that its gonna take upto 2 hrs but in reality it takes about 15 minutes to replace all files.
18. Once its finished turn off our car
19. eject SD card
20. Turn on Car hopefully at this point it loads perfectly like its a new avic... this may take a few momments and in initial menu it will say please wait system start up in process.
21. If its stuck in loop mode put SD card back in and re enter test mode go back to "My Flash Disk" delete all the files that say "gpspara(number).bin
If this doesnt work you need further help which is doable in most cases but its more indepth. This at least will give you a basic understanding of how to navigate inside WinCe
Glad to see/hear that this thread is helping lots of people, I hope it continues to do so. Also several people have asked for my paypal account for helping them out my email for paypal or further help if you are really stuck and for some reason i dont respond here quick enough (with in 3 days... please give me 3 days to respond) is [email protected] make subject Avic Help. Thanks to all that have donated and do in the future, but dont worry I will help without any donation what so ever some just feel like giving because they are saved lots of money.
Link torrent não existe mais!
Posted Jun 14, 2022 · 11:48 UTC#184
Hello,
can you send me a link to torrent: "Torrent Full of Avic F files" files please?
I have a problem with my AVIC F980BT device which started to reboot on its own while running.
[email protected]
Thank you!
Posted Oct 02, 2022 · 18:50 UTC#185
Hello
I see this is a old treat but possible open for download again Torrent Full of Avic F files?
I have a AVIC F980DAB is stuck in boot, was a falure FW load from prev owner.
THX
Posted May 09, 2023 · 14:43 UTC#186
Hi all,
my f900bt (for Europe) worked very well for the last 10 years. 2 weeks ago it started with rebooting loop, too. May I also ask to the experts, to please provide all the files needed to fix this issue. All links provided in this treat unfortunately do not work anymore or I do not have access to them. Thanks a lot in advance. BR Daniel
Page 8 of 8
