Basic Reboot Loop Fix
By tail24 · Jun 01, 2012in Problems/Troubleshooting💬 186 posts👁️ 162,528 views
Page 1 of 8
Posted Jun 01, 2012 · 01:27 UTC#1
This is from a post I just did for another member I feel like I kind of give the short un orgainzed version to lots of people but here is a more organized version. This is not a fix all but it will often fix many reboot problems, some are more complicated which may not allow you in to test mode, or may even reboot after files have been replaced. This should be attempted before the Pinned MBR fix is tried.
go to this thread ; http://avic411.com/i...f-avic-f-files/ Its also pinned to the top here "Torrent Full of Avic F files" download the zip with a torrent file with in it. Use a torrent downloader (Azerus Vuze, Utorrent, Bittorrent, ect) to download the larger torrent to your computer (its 8.4 gb and should take much of the rest of the evening to download). Once these files have been downloaded
1. Format an SD card that is at least 2 gb big.
2. Unzip the file you have downloaded
3. Locate the File Testmode V 2.3. Open folder Copy the folder within entitled "testmode"
4. Paste that file into the root level of your SD card
5. Locate folder "My Flashdisk Back up" Open it then Open the folder 2.0 f700 Copy this folder
6. Paste that file/folder into Root level of your SD card along with "test mode"
7. Eject SD card and head to car
8. Put SD card in avic and turn it on
9. wait for avic to load into test mode (likes like windows 95 its called WindowsCE)
10. Click Start > Programs> Windows Explorer
11. Double Click SD card > Double Click f700 up top click edit>select all then Edit>Copy
12. Click Start > Programs > Windows Explorer (again) to open a second finder window
13. Double Click "My Flash Disk" that looks like a grey little icon
14. you will see a bunch of folders and icons it should look similar to when you opened F700 folder from SD card Click uptop Edit Paste
15. If you are given an error message about not enough room ignore or x it out ( i forget the exact step)
16. If asked if you want to replace file, select YES ALL
17. You will see that its gonna take upto 2 hrs but in reality it takes about 15 minutes to replace all files.
18. Once its finished turn off our car
19. eject SD card
20. Turn on Car hopefully at this point it loads perfectly like its a new avic... this may take a few momments and in initial menu it will say please wait system start up in process.
21. If its stuck in loop mode put SD card back in and re enter test mode go back to "My Flash Disk" delete all the files that say "gpspara(number).bin
If this doesnt work you need further help which is doable in most cases but its more indepth. This at least will give you a basic understanding of how to navigate inside WinCe
Glad to see/hear that this thread is helping lots of people, I hope it continues to do so. Also several people have asked for my paypal account for helping them out my email for paypal or further help if you are really stuck and for some reason i dont respond here quick enough (with in 3 days... please give me 3 days to respond) is [email protected] make subject Avic Help. Thanks to all that have donated and do in the future, but dont worry I will help without any donation what so ever some just feel like giving because they are saved lots of money.
Edited Jul 05, 2012 by tail24
Posted Jun 02, 2012 · 13:24 UTC#2
works like a charm - f700 bt.
Posted Jun 02, 2012 · 16:31 UTC#3
Welxone
Posted Jun 03, 2012 · 18:26 UTC#4
hi guys,
Do you know where I can find the same fix for my F900bt? I think this solution works for the F700 only, am I right?
Posted Jun 03, 2012 · 22:10 UTC#5
No all Avic Fs the file structure is all the same, especially now that nav traffic is 86ed
Posted Jun 06, 2012 · 15:05 UTC#6
That's what I thought but I tried several time to format and install different updates (from pioneer or the F700 backup) but I still have the very same problem : I can't get access to the audio/video setup or menu, can't synchronize my iphone, even listenning a cd is impossible. I can use the general menu but that all. And most important thing, my F900bt restarts evrey 3/4 minutes. I used to have a message telling about the restart but now it disapeared....only the message unfoortunately the device still restarts.
I bought an map and firmware update the cnsd- 300fm. I really hope it will work because I have no other idea...
Posted Jun 06, 2012 · 16:27 UTC#7
you need to follow my other thread that is pinned. FORMAT MBR one
Posted Jun 07, 2012 · 15:28 UTC#8
what do you mean? I do not get you.
Posted Jun 07, 2012 · 20:10 UTC#9
ok my bad. I found the topic, I followed every steps. The device restarts with the pioneer logo (it used to start with a personnal screen). Unfortunately, I still have the same problems. Reboot every 5minutes, impossible to get access to anything but the general settings, can't play cd (do not eject cd ), and my Iphone can't find the bluetooth. I might receive the official map update tomorrow...but I am not pretty sure my F900bt will work again
Posted Jun 08, 2012 · 02:05 UTC#10
Map update will not do anything for music side of things. Can you play music from FM/AM/? Will ipod play? What works within maps? Can you pull up GPS
Posted Jun 08, 2012 · 18:39 UTC#11
No I can't. But the pioneer sd card update includs map and firmware update, right? Any way, I need the device number but I can't get it. They said put the sd card and turn on the f900bt and you'll get the device number but all I get is an error message like it can't find the data... I am so....blocked. The tip you gave was for us device, right? Maybe it does not work because of my offical european update...
Posted Jun 09, 2012 · 01:38 UTC#12
oh yeah this is for US units... all my backups a for US only.... you will need to a backup of a euro model and maps which i dont have. Did you do the format mbr? what sdmlc files did you use?
find a torrent in the mods threads with euro maps and ill try and walk you through fixing unit
Posted Jun 09, 2012 · 07:55 UTC#13
Well thank you very much. I used the nn746uc_sdmlc_0_108009984.I haven't find a euro backup. Do I need mods threads with euro maps even if I have the cnsd-300fm? I never format mbr. Until now I just install wince (format) my device and then install the pioneer 1.900000 or 2.009000 update. But all I get are the problems I explained.
I gonna search for format mbr information. Do you think it could help? Does a euro sdmlc exist?
Posted Jun 09, 2012 · 08:32 UTC#14
Ok on your donwload files, there is SDMLC_NN746_EW_sn00aa0f. SO I was thinking about doing a a format mbr, then using the SDMLC_NN746_EW_sn00aa0f file with Open DiscRW and then, install the 1.900000 update from pioneer (no map inside) after that, I would try to install maps and firmware update from the cnsd 300fm. What do you think?
Posted Jun 09, 2012 · 20:22 UTC#15
it's done....and it's fixed! Everything works very well, audio, video and gps! thank you very much tail24 for your advice, support and for all the files you upload!! Back to business!
Thanks again
Posted Jun 10, 2012 · 03:14 UTC#16
Sorry just got back on busy day. Glad you found the SDMLC euro (EW) files that's what I was gonna point you to then have you install a back up with euro maps but you seemed to piece that all together yourself through learning about how the system works. Glad I could be of help in the process
Posted Jun 13, 2012 · 19:52 UTC#17
Thank you again! I amm enjoying my f900bt.
Posted Jun 13, 2012 · 19:58 UTC#18
I tried to re boot with the SD card after downloading the AVIC Fix using the testmode and F700 files but it dosen't work. The start up screen comes on then I see the windows screen for a second (icons are on the screen) too fast to click on anything then goes blank again.
Help I need my system back...
Posted Jun 13, 2012 · 20:49 UTC#19
I emailed you back earlier. Try uploading a firmware update first... This may stabilize you out long enough. If not gotta do formatMBR fix
Posted Jun 15, 2012 · 18:16 UTC#20
Hi,
i Have a Euro 910BT with the Boot UP Problem, whats the fastest Way to fix this - and where did i get the right Files for Euro? Cant find them here ...
greetz .pixxel
Posted Jun 15, 2012 · 19:31 UTC#21
You need to get a copy of Euro telenav maps... From there PM and I'll describe it to you
Posted Jun 15, 2012 · 19:52 UTC#22
Help! This is a strange one.... I upgraded up AVIC-F90 a couple years ago to Dafia`s mods.... All was great for some time. Nothing has changed except now my unit just goes to the splash screen for a short time and reboots. I can`t seem to find any live links to download what I need to get this thing back up. And what happend to have this start? Very Strange....
Posted Jun 15, 2012 · 21:39 UTC#23
Files Currupt every now and then: did you look in the link posted on first page? Download the torrent get into test mode and place my daftias backup copy
Posted Jun 15, 2012 · 22:14 UTC#24
I click the link on page 1 and it is a dead link.... :(
Posted Jun 16, 2012 · 14:30 UTC#25
it links to the thread pinned bellow this entitled Torrent Full of Avic F files
Page 1 of 8
