Basic Reboot Loop Fix
By tail24 · Jun 01, 2012in Problems/Troubleshooting💬 186 posts👁️ 162,528 views
Page 2 of 8
Posted Jun 16, 2012 · 15:50 UTC#26
Thanks got it!
Posted Jun 18, 2012 · 09:43 UTC#27
Hello,
I can contact you, I have a reboot problem with my avic F900 bt.
I have read the explanation of tail24 but as I am French, I n can not find the file for the European units.
Do you know where I can find them?
In expectation of an answer because it's been 2 months that I can use my avic.
Sincerely.
Posted Jun 18, 2012 · 09:55 UTC#28
I am hoping someone will send me euro files but they haven't. Any option is buying a Map upgrade or downloading a map upgrade from there I'd be able to help you.
Posted Jun 21, 2012 · 11:57 UTC#29
I am going to buy cn sd 300 fm for 199 €. That hurts but not the choice!!! Then I have to follow your procedure as indicate on the premiere page of this forum? Thank you still Tail24
Posted Jun 21, 2012 · 12:14 UTC#30
^^^^ You dont need to do that. PM for a possible fix before you buy these files. ^^^
Edited Jun 21, 2012 by tail24
Posted Jun 23, 2012 · 00:57 UTC#31
I have an AVIC F700BT and I have the issue with it stuck on the startup screen and it just reboots after a while. I have done what is shown above, but when I am pasting the files to the AVIC it gets an error and can not paste the file. I have downloaded the torrent multiple times to make sure its good. I also used 3 different SD cards to make sure that wasn't an issue, and did full format to each card prior to using them.
Any help?
Posted Jun 23, 2012 · 01:02 UTC#32
What is the error message? Are you pasting the files from within te folder "my flash disk" to the Avics my flash disk? Does it give you memory filled not enough room message?
Posted Jun 23, 2012 · 01:27 UTC#33
Here is the error when I paste the files from the SD card to the system. It will copy them over for about 5 minutes then this pops up
Here is the error I get when I try to use the update provided by Pioneer to update to Firmware 2.006000
Posted Jun 23, 2012 · 02:01 UTC#34
I deleted the file it was having problems with, now I get this error
Posted Jun 23, 2012 · 19:29 UTC#35
What country are you in?
Posted Jun 24, 2012 · 01:43 UTC#36
USA.
Posted Jun 24, 2012 · 20:34 UTC#37
Well I fixed the system. I had to unmount "My Flash Disk" format it and then delete it and make a new one. Then copy all the files from my SD card to the newly created My Flash Disk. Then I had to use the update found on Pioneers website (AVIC_F-Series_Firmware_Update_2.008000) and run the update.
My system starts up and works fine. Seems to be slower than it was before (I had 2.0 on it before). And now the USB works when it wants to is the only real issue I have found.
Is there a firmware update to 3.0 that is actually working for the F700BT
Posted Jun 24, 2012 · 22:21 UTC#38
Yes it's found within my torrent, it's not an update it's a backup of a 3.0 avic. You have to update the wince files then add 3.0 backup. You can read about how to do it on hacks mods thread
Posted Jul 02, 2012 · 22:26 UTC#39
I attempted to update to the 4.01 firmware that is in your folder. However, when I reboot the unit, I get an error message about failing to load the language.
Any ideas what that's about?
Posted Jul 02, 2012 · 23:47 UTC#40
What process did you take to update it? Are you in Europe? Some people have had that problem from the other 4.01 files
Posted Jul 10, 2012 · 07:28 UTC#41
I recovered the files you sent me but what do I do with because it's not the same manipulation.
thank you
Posted Aug 01, 2012 · 21:29 UTC#42
Thanks for this post! Like most here - my B700 just stopped - right when I left for a 700 mile trip! Boy was I discouraged - no music, no GPS and well smartphone is nice but really hard to hear through its little speaker!
I installed it and while I still have to look through the threads and posts, I still have a problem...the system shows my mod screen when t boots then it goes black. I have to keep pushing the map, menu buttons several times before I get the menu screen. I'm thinking I should update to 3.0 but I think I should find and fix this problem first. As long as the system works for the ride back, I am more than happy with doing this for one trip!
Again - a million thanks! I love my system and so happy it is somewhat repaired! 8)
BTW - with a hotel connection - it took almost 24 hours to download this file through utorrent but worth it! All the firmware and updates are now downloaded
Posted Aug 02, 2012 · 00:40 UTC#43
Does it let you load maps from the menu screen? Does it now reboot after 3 mins?
Posted Aug 02, 2012 · 02:15 UTC#44
well I took a chance and installed the firmware 2.008....maybe I should have done the 2.006 first....anyway - still didn't work. I reverted back to the downloaded F700 2.0 files from your download. I thought it was odd that I could get my av to work, cd, phone ( I do have the 290 version...just found out), bluetooth and maps would come up but getting to this was a hassle because of the black screen Each time I started the car or pressed the reset button, it would boot showing the splash screen then black. I would wait like 30 seconds and press the map button. The navi disclaimer would come up and the "system start-up..." message. then things were fine.
For a system that gave me no problems (outside the xm module) for almost 4 years until about 3 days ago, I found it hard to believe my files were "corrupt". So I continued to dig back in these threads and saw a post in 2009 about the back-up camera. I do not have one but when I read it, I figured - hey it is worth a try! (and it was easier than chancing the format MBR thing!)
So for the millionth time today, I went out to the car (I started taking the hotel elevator since the stairs were killing me! LOL) and started the unit. When I went through the usual splash t black and wait routine, but when I got the menu, I did the following: Settings>System Settings>Backup Camera. Both buttons were illuminated and I selected OFF. I then restarted my car and YES - I got the splash screen until the navi disclaimer. Granted it does not go directly to menu but I can click the menu button from the maps and get there and there s no more back screen!. I also saw an issue with voice commands when this happens. I will check this when I leave but for those wondering - you may have to set the language too. Why did this happen? From what I read, it appears to be constant extreme hot weather. Call it a quirk.
Tail24-, I think this post on the back-up camera had your "fingerprints" all over it (or a member who began with a "T").... THANK YOU!!! I saw ALL the problems you have helped others with and well I just think you should be CEO of Pioneer! :-P
Now...should I install the 2.6 firmware...then the 2.08 followed by the F700 3.0 or just leave well enough alone even though it is not perfect?
Edited Aug 02, 2012 by dlwarr
Posted Aug 02, 2012 · 02:21 UTC#45
one more thing - for those that had perfectly running units prior to the black screen - you might want to try checking the back up camera before re-installing files. It just might fix the problem.
Posted Aug 05, 2012 · 03:51 UTC#46
http://www.enkrypted.com/4.01.zip
Hey guys instead of using 2.0 or 3.0 use this to fix your rebooting issues........ 4.01 is so much better than 2.0! this also includes the latest maps & 3d buildings... for North America. THX! :) Enjoy
EcoCav, when booted into WinCE mode, go to start > control Panel > storage > and format the first partition. Then copy the contents from your SD card to "my flash disK" under "My device"....
Edited Aug 05, 2012 by enkrypt3d
Posted Aug 05, 2012 · 13:02 UTC#47
FYI going to 4.01 will not initially work for all. Many need to fix current then go.
Posted Aug 05, 2012 · 21:17 UTC#48
I was on 2.0 when the rebooting problem happened... then I copied 3.0 over 2.0 and it worked so I went and updated winCE for 4.0 then updated to 4.0..... works great!
http://www.enkrypted.com/Avic_Files.zip
Here is a mirror for the torrent file that I posted for everyone to share. Hope this helps thx
Edited Aug 06, 2012 by enkrypt3d
Posted Aug 06, 2012 · 00:45 UTC#49
Glad all worked. Thanks for helping share
Posted Aug 07, 2012 · 16:40 UTC#50
Feel free to post my link in your original post thanks!
Page 2 of 8
