agreed, restoring an ipod more than once is usually a waste of time. its as simple as its going to be one of five problem
1.software problem on the ipod
2.hardware problem on the ipod
3.the connection cable
4.software problem on the AVIC
or 5. a hardware problem on the AVIC
now identify, isolate and eliminate
you have now proved multiple times that it is not a software problem on the ipod
X1
you have tried a different cable so you know that's not it
X3
you where told days ago to swap out the ipod to rule out (or more likely confirm) that the problem is with ipod itself could be many internal issues with the ipod almost all needing the ipod to be replaced
?2
so now you can choose to rule out #4 and #5 by either replacing all of the software on the AVIC or by trying a different radio or easier yet, going to a store with your ipod and testing it on some displays, this will be a win win, because you will either confirm that your problem is with your ipod or you will confirm that your avic is the problem and then you will be able to replace it right there, i would also recommend trying a store that sells both nav systems and ipods
also not to get off on a rant here, but if you still cant find one of the 300,000,000 ipods that have been built to borrow for some testing, you either have the worst group of friends ever, or you are that friend that everybody has that just doesn't respect everybody elses shit and any time they do let you borrow stuff it comes back all jacked up.
this issue should have been solved in a day or two, not dragged out for three weeks.maybe its just me or the fact that every hour i waste trying to fix my own problems is just another fist full of cash im pissing away by not working on a paying job.
Regardless, all of the possible outcomes are now contained in this thread. Good luck!
