Hi all. I've been a long time reader of the forum, but this is my first post.
I know a few of you guys have installed Z1s in newer F-250 super dutys. I'm installing a Z1 in a 2005 F-250 diesel and am having a problem finding a feed that works. The gray/black wire at the radio harness does not work. The gray/black wire from pin 21 of the ABS module didn't work, and the gray/orange wire at the PCM shows speed pulses when moving slowly, but at road speeds it reads grossly high showing thousands of pulses every couple seconds, and the Z1 gives a Vss error message in the hardware info screen.
What wire are you guys using? I'm about to pull out my hair.
