2012 Maps
By Kurto2021 · Aug 17, 2012in General💬 51 posts👁️ 17,649 views
Page 2 of 3
Posted Sep 03, 2012 · 15:11 UTC#26
I have 2 questions a friend asked me if i wanted to split the cost of the updradge with him so we could spend 60 each but i told him i don't think we could both use the same one
so i figured i would ask in here
can the upgrade only be used once ?
once its used is it erased
or does it only allow you to use it on one unit
does it somehow encode the SD card with the Serial number of your model ? on the card so it can't be used on other units of the same model ?
or can it be used on multiple units ?
also is there an actualy part number or serial number for the upgrade i wanted to see if i could try and find it on Amazon perhaps
Posted Sep 04, 2012 · 05:39 UTC#27
How the upgrade works is that you get a password from pioneer after entering your device id.
Posted Sep 04, 2012 · 22:33 UTC#28
Hi!
We received the SD card today. Not bad really, ordered last Thursday the 30th and received it today the 4th. Over a holiday and over a border (to Canada).
Cost $120US + $30US for cross border courier (Fed-X). They even had the Country of Origin form completed for customs. So the envelope cleared customs without even having to see the border customs people. Now there is a bonus!
You need the Device # from your Service Information Screen on the Pioneer, and the SD card came with the Media #. With that you just have to go to 'pioneernavigationupdate.ca (for Canada, probably .com for the US), enter both numbers and supposedly get a password that you'll need for the update. So it looks like the update is tieing the SD card to a specific nav unit. So sharing most likely won't work.
So will find out on the weekend how this all works.
Posted Sep 05, 2012 · 17:42 UTC#29
I know this is new, but any torrents for this yet? Thanks all !
Posted Sep 06, 2012 · 16:02 UTC#30
Hi!
On the 2011 Map update there was a modification that made it so the receiver would just accept any password (well, I think it was just 000000) so if you would share that would be pretty awesome and we can see if the previous system mod still allows the install.
Posted Sep 06, 2012 · 22:00 UTC#31
I bought the 2012 Navtek update and installed it about a week ago. I thought I'd post my impressions of its value for others to consider.
I live in Ottawa Canada and the previous maps were frankly lousy. Many area's of the city, built within the last 5 year were not accurate or even included. Rural areas close to the city were patchy including only major roads. POI were very thin with few restaurants and even the major museums and national sights missing.
I thought the 2012 upgrade would be a dramatic improvement. It was a disappointment. Urban maps and near by country side is marginally improved but still lacking (see below), rural Quebec is still non existent. POI's are better but a free app on my phone is far more comprehensive.
For comparison I have a Garmin Nuvi 50 I bought for my wife's car. It cost about the same as the upgrade $120. It is far more accurate and complete and includes an astonishing database of POI. On a recent trip from Ottawa to Washington virtually everything I could find on yelp or tripAdvisor or Google was already in the POI. If I had to guess I'd say map wise the navtek upgrade is not more than 80% of the garmin and poi wise not even 30% of th Garmin.
At $20 the Navtek upgrade might be worth it at $120 it's a cruel joke.
Posted Sep 06, 2012 · 22:30 UTC#32
Hi!
Well that's disappointing! Oh well, I'll install mine on Saturday.
Posted Sep 07, 2012 · 04:05 UTC#33
Update should be on two SD cards, first card has map update and it will ask you to get password, second card should be software update and it should not ask you anything.
As advice: Try to update map first, and after update have finished, go in to testmode (if you have't updated software it will have copy/paste option) and copy contains of NDATA forlder -it will have new map on it. Than you will have chance to put new map in to other unit using testmode. Make backup of second unit's NDATA folder before making any changes.
Only then update software and you will have X940BT with limited testmode without copy/paste function.
It would be great if you share software update (second SD card) and NDATA folder with new maps.
Edited Sep 07, 2012 by Ralpharn
Posted Sep 07, 2012 · 04:41 UTC#34
uhh... the people that already got it said its just one sd card
Posted Sep 07, 2012 · 04:51 UTC#35
That complicate it a bit. But you need to know- after you update software you will loose ability to do something via testmode. And fresh map sits in NDATA oflder. %)
Posted Sep 10, 2012 · 06:31 UTC#36
I just received the Pioneer update. How long did the update take to install? The Pioneer Help section mentions 3 hours but for a different update.
Posted Sep 10, 2012 · 23:18 UTC#37
Hi!
Good question! I haven't done our update yet either. I did see the comment about 3 hrs, and that you should connect the battery to a charger. Was Sargasso's or your nav unit the 9310bt?
Posted Sep 11, 2012 · 18:28 UTC#38
Hi!
My unit is the 9310bt installed in a 2012 Outback. I'm hoping it doesn't really require 3h to install.
Posted Sep 13, 2012 · 00:05 UTC#39
I found it on page 20 of the T1000-19328 manual, "The upgrade takes approximately 30 minutes in total".
Posted Sep 13, 2012 · 01:25 UTC#40
Yes mine was the 9310bt OEM from Subaru. Upgrade took 30-40 min.
Posted Sep 13, 2012 · 11:17 UTC#41
Hi Sargasso!
30-49 minutes, that's a relief. Did you connect your car to a charger .... or just put the ignition in 'ACC' and do the update?
Posted Sep 14, 2012 · 18:11 UTC#42
Hi!
I updated the maps today in our x9310bt. The process wasn't near as bad as was described in the instruction guide. Nor did it take as long.
The instruction guide described how it would take 3 hours to do the install & update.
Nonsense!
From start to finish, maybe it was 25 minutes. After the updates the Version number changed from 3.00 to 4.00 . Haven't noticed anything else yet. (its only been an hour.)
Also, when you get the password, Pioneer states how getting the password you can only do once, and that the nav nunit and the media are linked together. So copying .... don't think that will work.
Looking forward to see what the update has brought forth.
Posted Sep 14, 2012 · 18:58 UTC#43
this has been the case for prior updates (as it is with many stand-alone navs like tomtom and garmin units) but the files are hacked so that they can update any unit. just waiting for someone to upload the files and hopefully whoever hacked the files before can do it again. seems like the same passcode procedure so hopefully who ever hacked the files before doesn't have to do too much work.
Posted Sep 21, 2012 · 21:39 UTC#44
Hi!
We've had the 2012 map update (new maps) going for our x9310 for a week.
We have noted that there is more detail in the maps for our area (Halifax Nova Scotia Canada). Paths, roads, rail lines ... all more detail. Way more shading too.
Haven't got the blue tooth audio to work yet, the phone works fine.
Certainly worth the money for us.
Posted Sep 27, 2012 · 05:31 UTC#45
Hi!
Nonsense!
so you took a 910 all the way to a 940? did you lose anything?
Posted Sep 29, 2012 · 14:30 UTC#46
No. Seems the same, but better. BTW; our nav unit is a x9310bt, so a 930 not a 910.
Still haven't got the android thing to work with our Galaxy S1 & S2 phones. The rest is great.
Posted Sep 29, 2012 · 16:32 UTC#47
There is no way to take a 910 to a 940.
Posted Sep 30, 2012 · 11:55 UTC#48
Huh!
Posted Oct 29, 2012 · 16:09 UTC#49
I upgraded my 2012 Subaru Outback x9310bt with the new 2012 map update. Generally better maps and POIs. However, there was an unexpected side effect of applying the map upgrade. Since my car was new and had the factory installed x9310bt, it came with a free 3 month Sirius Satellite radio trial with all the stations unlocked. After the map upgrade, I lost all the Sirius Satellite stations except for the Preview station. Now I must register with Sirius using a credit card to get the 3 month trial, after which I must cancel or they continue debiting the credit card. :(
Posted Nov 05, 2012 · 20:38 UTC#50
I just picked up a used X910BT and installed it this weekend. I am contimplating the update, but not sure if it's worth it on the 910. What changes will I see (besides 2012 maps)?
Currently, on the Service Information screen it says
Map version: 02.000500
Version: 3.020100
The maps say 2008.10 on them
Thanks.
Page 2 of 3
