Can someone PM me the torrent? I'm eager to try this, I had been looking regularly wondering why they didn't do a 2011 update. Glad to see a new update is avail!
CarpelDMK
It's in post #67 in this thread...
CarpelDMK
Thanks. I'll leave it seed for a while. Much appreciated guys!
Successfully updated my maps. Thanks for the help.
fyi... I used XP virtual machine on my Windows 7/64B desktop to run Acronis version 10 included in the file in post #67..
From what i see on pioneer's site there is only one product that's named CNDV-1100HD. Is this version the same all around the world or do i need a different version for europe?
I'm going to switch to a avic-f940 tonight but this would make my hd3 easier to sell or use in a different car!
Same part number, but different software depending on your region.
Ok... Does anybody have the europe maps available for download?
Hi, i am new to this form,
can someone PM me the link where i can download the entire 2012 map TOMTOM for AVICZ-3
Zain
Zain
It's in post #67 of this thread..Link below.
Thank you whoever is seeding! I cant wait to try this. Will post my results and of course I will continue to seed as well!
Thanks Gerrett,
I sent my drive to you the last two times and was actually looking to see if there were new maps yet to send you my drive again when I stumbled on this thread. I was able to get everything going on the new maps, it was a bit of a pain, couldn't get any of my Windows7 laptops to work with Acronis10, even in XP mode on my Win7Pro laptop. I ended up getting one of my old laptops out that was still running XPsp3 and used a USB-IDE adapter and it worked great.
I created a backup of my drive before i did it. Could I simply retore that image to a larger drive if I wanted to go bigger or would it still need to be unlocked before install?
Thanks again.
The larger drive has to be Toshiba and you would have to increase the size of the MSV partition if you wanted the extra space for music. You would want to disable the security feature on the new drive using a program called MHDD.
Or seed this one, that would be even better! I posted in the 2010 thread before finding this one.
I can go from stock z1 to this correct?
hello
I have some questions
i have downloaded file 2012-1100HD HDD IMAGE cndv also have created a hdd following the steps according to the manual that was inside.
The problem is that when we shove hdd car system recognizes it not as hdd.
So first I need to do an update of the pioneer firmwire then to put the hdd with the new image that you recognize?
Second, this hdd has already received a password which is the way to delete this password?
If is possible can tell me how to do that hdd not receive the password and you can send a manual in pm to explain the procedure to create the image
Thank you
Does anybody have a link for european version ?
you find EU version?
am downloading and will seed indefinitely have a 50 mbit landline so will not be a problem for you guys to take it
BUT if you download you MUST seed minimum of 2 times the incoming data that way there will be more seeders and others will have a faster download
Could some others please seed this; only have 1 at the moment and shows about 3 Days
Hello Garretoomey,
I got a hard drive from you way back when with updated maps.. You supplied the HD and all..
What do I need to check to see if I can do an update with out a lot of hassle.. I like to update before my Vacation.. BTW, last time I was here was 2009.. Its a Z2
Old
A Little note of what I have:
Platform Version: 3.000100
GPS Program Version: 1.200000
HDD Application Version: 3.100200
Version: 03.0000
CDDB Version: 08-01-0010
I skipped the Device #..
Off screen of Z2
It is a drive I got fro you Garretoomey way back, poss 2009
I wonder if the drive is unlocked.. If not I will use the CD to unlock.
Old
All updated. Was my USB to IDE adapter. I used an older computer with Arconis True Image 2013 and did the upgrade. Works fine.
TY you all.
Old
I have a 40 gb HD with the 2012 Europe maps on for 45€ if anyone is interested, PM me.
I run a seed box out of my house, pulling the torrent down to it now. When it finishes I will leave it seeding indefinitely.
Hey what happened?
nobody is seeding =(
I guess the 2013 maps are due out soon, so nobody wants to bother with this...
Can any of you guys seed it again?
Thank You
I want to thank whoever is seeding. There is only one and I'm at 43%
Hey what happened?
Many apologies, I moved from California to Arizona and my seedbox was offline during the time you posted this. You should be good now.
Someone is actually downloading from me right now and is getting 650 KB per second! Nice!
