CNSD-310FM EU 2012 update
By radeonorama · Nov 17, 2012in Hacks/Mods💬 282 posts👁️ 116,695 views
Page 10 of 12
Posted Jun 24, 2013 · 16:12 UTC#226
Copying is no problem in supertestmode.
Normally you can add  voices by installing them in the setup menu, however this fails on a "file not found" error.
Posted Jun 24, 2013 · 16:15 UTC#227
Ah, right, i see! so you have basically tried both ways, installing via the ui and copying them manuually and neither worked right? let me see what my friend has available and ill hopefully be able to get the whole tsdata to you
Posted Jun 24, 2013 · 16:18 UTC#228
Posted Jun 24, 2013 · 16:40 UTC#229
Peter, try the new file on the drive now. Its called TSData_2.rar. That is from another hu and is the entire tsdata folder and includes the dun dir's. I checked it against the other dun folder you have just tried and its file size is different so fingers crossed!
Let me know how you get on.
Posted Jun 24, 2013 · 17:05 UTC#230
Downloading now, I will install it tomorrow.
Let you now the result
Thanks again
Posted Jun 24, 2013 · 18:01 UTC#231
Thanks again
I would suggest you put the entire TTSData folder in place rather than picking bits out of it.
Obviously take a copy of your existing one first!
Posted Jun 25, 2013 · 06:06 UTC#232
Just finished copying the complete TTSData folder to my unit and TTS Dutch is working again.
Thanks Radeonorama for your help.
Posted Jun 25, 2013 · 06:36 UTC#233
Sweet! Glad to hear it worked! :-D
Posted Jun 29, 2013 · 08:22 UTC#234
Pioneer T1000-20494
The new Update Europa 2013 for Pioneer AVIC-F10BT, F20BT, F920BT, F9210BT, F9220BT
Is there anything in use?
Greetings Nitram
Info:
(Update Europa 2013 for Pioneer AVIC-F30BT, F930BT, F9310BT, F40BT, F940BT, F840BT, F8430BT is this one T1000-20496)
Edited Jun 29, 2013 by nitram2012
Posted Jun 29, 2013 · 21:16 UTC#235
thx pionara  :neutral: !!! is a bad request , but i try for one time and f20 don't recognize the sd, is just show me 3 music files  :shock:  :shock:  :shock:
Ciao, aggiornato oggi F930BT Italiano.....nessun problema se segui attentamente le istruzioni del post originario...ti mantiene pure le impostazioni bluetooth...
Posted Jun 29, 2013 · 21:18 UTC#236
Google translation: Hello, today updated F930BT Italian ..... no problem if you follow the instructions of the original post ... keeps you well bluetooth settings ...
However, this is an English thread so please post in english. Thanks! :-D
Edited Jul 10, 2013 by radeonorama
Posted Jul 16, 2013 · 21:07 UTC#237
Hi all
Perfect working on French F930BT :-P
tested without handbrake and also while driving. You can turn off your engine but not turn on it during the update
Under is an "How to do" for French people :
(Pour les français qui ont du mal avec l'anglais, vous demandez l'accès aux fichiers sur le 1er post, vous faites un don de 5/6€ via paypal pour y accéder, vous charger le fichier "CNSD-310FM EU 2012 Pioneer Update" que vous décompressez sur une carte micro SD. Vous chargez le fichier sur le 2nd poste(verinfo.dat) et vous remplacez celui qui est dans votre carte dans le répertoire "Update".
Vous avez donc sur votre carte SD 2 répertoires et le fichier cardinfo.cif. Mettez la carte dans le poste, mettez le contact et attendez le message de mise à jour. La mise à jour dure environ 30 minutes.
Vous pouvez me contacter en cas de problèmes.
Edited Jul 17, 2013 by 20cils
Posted Jul 27, 2013 · 19:52 UTC#238
sd card %99 eror :(
Posted Jul 28, 2013 · 10:08 UTC#241
radio does not work you want to sd card :(((((((((
Posted Jul 28, 2013 · 10:10 UTC#242
I'm sorry, I'm not sure what that means. Have you read this entire thread as pretty much every issue found has been resolved. And have you tried the sd card I recommended?
Edited Jul 28, 2013 by radeonorama
Posted Jul 28, 2013 · 11:01 UTC#243
I've tried 4 different sd card
Posted Jul 28, 2013 · 11:02 UTC#244
And make sure you're FAT32 Formatting your SD Card using the windows utility and make sure its a Complete format
Posted Jul 28, 2013 · 15:26 UTC#245
try to take 8 gb kingston
Posted Jul 28, 2013 · 18:23 UTC#246
Hello all, I have access to the CNSD-310FM EU 2012 update and have the CARDINFO.cif and VERINFO.DAT files for us EU users!!
I have now added a download for the CNSD-310FM US 2012 Pioneer Update too. :-D
Just PM me and ill send you the link for a donation of £10 and ill invite you to download the update. :-)
This will also give you access to the TSData backup for those who lost them when updating and the CNSD-310FM US 2012 Pioneer Update too.
I have the following languages available: CZC, DUN, ENG, FIF, FRF, GED, GRG, HUH, ITI, PLP, ROR, SPE, TRT
The link for the full update and files is here :-P
http://goo.gl/P0LG6
FEEDBACK:
"Hi all Perfect working on French F930BT :-P"
"I have upgraded my F930BT using the information in this thread, thanks! It's working great"
"F9220BT Upgraded fine to version 4 and 2012 maps.With out this web site it would of not been possible. A big thanks to all"
"It works on F930BT Thanks a lot, radeonorama"
"hi all, worked for me on my f930bt :-P"
"Just updated my 930BT yesterday. Worked flawlessly without any issues. Thanks a lot!"
INSTRUCTIONS
To do the update on an F930BT you just have to:
01) Download the rar from the link above above.
02) Extract it to a safe place.
03) Open the extracted folders and go into the Update folder
04) Replace the VERINFO.DAT with the one in pionara's second post on this thread.
05) Copy everything you extracted onto a clean 4GB+ SD Card which has been FAT32 Complete Formated
(make sure that the files and folders on the route of the SD card are:
FIRMWARE (folder)
Update (folder)
CARDINFO.cif (file))
06) Put it in your Car (with the engine running or on a charger etc)
07) The Pioneer should reboot and start the update.
08) Follow the on screen prompts
09) Once completed, it may ask you to update again, if so, select no.
10) Enter Bluetooth settings and update the bluetooth firmware. (This seemed to take longer than i expected but dont worry, it does eventually get there! :-)
The above files are not a hack to do the upgrade, they are the official Pioneer Update Files. The only hack is with the VERINFO.DAT which I believe all it does is bypass the passcode request when the update starts. There shouldnt really be any reason for this to fail.
As always, with anything like this, I would always advise you backup first!
Cheers, Radeonorama
cards, even though I tried once again, not too wore photos
http://resimyukle.net/0]a>
Edited Jul 28, 2013 by garabatak
Posted Jul 28, 2013 · 20:49 UTC#247
1. 4 gb sandisk class4 error
2. 4 gb trasdata class3 error
3. 8 gb sandsk ultra class10 error
I've tried this 3-card into the correct error is 99% remains sd card
Posted Jul 28, 2013 · 20:53 UTC#248
As I said, Others with that problem have succeeded with the update using a Kingston MicroSDHC 8GB class 4 memory card. I have not had any problems doing the update with a SanDisk and a Nokia but the most frequently used with success is the Kingston above. Failing that, perhaps your download was corrupt. And did you perform a full format to fat 32
Posted Jul 29, 2013 · 05:47 UTC#249
8gb sd card kingston take today to try it.
If you would like to donate thee again, whether the files again
Posted Jul 29, 2013 · 06:02 UTC#250
Page 10 of 12
