CNSD-310FM EU 2012 update
By radeonorama · Nov 17, 2012in Hacks/Mods💬 282 posts👁️ 116,695 views
Page 11 of 12
Posted Jul 29, 2013 · 06:09 UTC#251
The total size of the files are downloaded
Do you have a file that is missing?
Posted Jul 29, 2013 · 18:00 UTC#252
kigston sd card worked flawlessly thanks
pionara's thanks
Posted Aug 02, 2013 · 17:25 UTC#253
how can download firmware for avic f930bt.
I destroy this device and need to repair (reflash).
Any opinion and help is good.
Thanx!
Posted Aug 09, 2013 · 23:29 UTC#254
follow general instructions here:
http://avic411.com/i...asymethod-beta/
looks like verinfo.dat is same as us update so you can use this one which is same as on that thread:
The existing cardinfo.cif should work with EU versions of F930 & F30, but if you have F10, F20, or F920, you can do this mod to cardinfo.cif - just open in text editor, search and replace exactly:
KMQ1S8PF5CUQE7LKUX with
X07EURX27EURX30EUR
for the model f 9310bt is valid?
thanks
Posted Aug 09, 2013 · 23:30 UTC#255
thanks
yep, its exactly the same hardware at the f930bt with just a different plastic surround
Posted Aug 11, 2013 · 00:50 UTC#256
Thanks for your reply
Posted Aug 19, 2013 · 05:01 UTC#257
everything works perfect here, German language.
Thx so much and waiting for Version 2003 :)
Thx!!
Posted Aug 20, 2013 · 08:29 UTC#258
Pioneer T1000-20494
The new Update Europa 2013 for Pioneer AVIC-F10BT, F20BT, F920BT, F9210BT, F9220BT
Is there anything in use?
Greetings Nitram
Info:
(Update Europa 2013 for Pioneer AVIC-F30BT, F930BT, F9310BT, F40BT, F940BT, F840BT, F8430BT is this one T1000-20496)
is there something possible?
Posted Aug 25, 2013 · 15:07 UTC#259
Hi,
Just wanted to express my thanks to pionara and radeonorama for making this available. I successfully updated my UK AVIC-F9210BT, using a cheap Tanscend 4GB SDHC card I bought from Maplin. It took around 25 minutes for the main update and 5 minutes for the Bluetooth update. I did the tweak to the VERINFO.DAT file too.
You don't often find a full and easy to follow solution to this type of thing on the web so how easy this was, was very refreshing.
Cheers,
Paul
Posted Sep 02, 2013 · 16:59 UTC#260
Isn`t this possible on the x940bt?
I have tried many ways now, and nothing happens.
I recently updated the firmware with a USB drive, so i am using one now, is that the problem?
Hope someone have got this to work on a 940bt!
Posted Sep 04, 2013 · 21:45 UTC#261
Anybody with new update 2013 maps?
Posted Sep 06, 2013 · 19:32 UTC#262
Got this working on my F-30BT, first time (32gb card).
One weird thing though, when it rebooted after installing,  it didn't seem to offer me English!? DId I mis something?  Anyway I picked french, then it gave me the option of English TTS, which I then selected.
The unit rebooted in French, went into settings and chose English, Rebooted in English this time, and all good. Just a little strange!
Also quick question on the radio update. I updated it with the official Pioneer Radio update to 8.06, do I now need to update to the F-40's 8.03? (I note it saved all my radio stations, so perhaps this is different firmware and is ok?
Posted Sep 09, 2013 · 20:05 UTC#263
Got this working on my Avic F20BT. The first three times got the famous error, Wrong Sd-Card after that searched for a solution and found it. If you edit the file ALLDATA.VER you'll find the structure of the files on the SD-Card and at the end of the file, you'll find OPENING.FLG.
This file must be under Update\USER\SYSTEM\BG\OPENING.FLG
Just create OPENING.FLG with 0 Bytes.
Did that on the same SD-Card without reformating or something else, just created this file plugged in ran the update and 100% succeeded.
Edited Sep 09, 2013 by Travolta
Posted Sep 11, 2013 · 15:49 UTC#264
Tried now with SD-card on my 940BT but can`t get it to work. I have google`d for a couple of hours, but haven`t find anything useful.
Have anyone done this with a 940bt?
Posted Sep 13, 2013 · 21:28 UTC#265
The software updates to 40bt and 940bt level..
Posted Sep 20, 2013 · 11:13 UTC#266
I need CNSD-310FM Europe for F920bt and F930bt. What should I do?
Posted Sep 23, 2013 · 22:42 UTC#267
help avic f930bt          message*******inser sd card correct  ********  help
Posted Sep 24, 2013 · 18:44 UTC#268
EU 2013 update is out, go over to F-series hack/mod forums
Posted Oct 06, 2013 · 02:00 UTC#269
i need the CNSD-310FM EU 2012 UPDATE tried the first page sent a request for the google drive. no replies.
Posted Oct 21, 2013 · 01:12 UTC#270
guys i need help. i tried doing the condi hack coz i forgot my password. but now all i get is "error, installer files not found. is the sd inside?" i dont know what else to do. can someone help me asap? please!
Posted Oct 25, 2013 · 00:07 UTC#271
does anyone know where the CNSD-310FM US 2012 Pioneer  maps can be found. I get no reply from the link in this thread.
Posted Nov 03, 2013 · 20:19 UTC#272
Hi, i'm french sorry for my english !
I performed the update and everything works perfectly on my F10BT. But every time I reboot it asks me "begin update" how to remove this message at boot ?
Posted Nov 08, 2013 · 21:19 UTC#273
is there any way to check wich map versions are being installed with the 2013 update ?
I've done the update on my 920bt with succes, and my language and speech file's are still dutch, the version has changed from 2.00 to 5.00 on my unit...
but somehow I have the feeling that there are old maps being installed (not 2013) version, because a lot of new build roads (from 2011 / 2012) are not on the map??
so: how can you check wich map version is currently on the device ?
Posted Nov 08, 2013 · 22:08 UTC#274
Have you removed the sd card where the update is installed on ?
If you don't remove the sd card, or delete the update files on it, each time you start up the device, it will ask to update...
Posted Nov 17, 2013 · 13:18 UTC#275
Hi
Thanks for making the upgrade available. Everthing working on my 930bt except for app radio which displays a black screen only. Any suggestions? Has this got something to do with IOS 7?
Page 11 of 12
