hybrid 4.0 avic-f900bt
By adamleerusse · Mar 13, 2013in Hacks/Mods💬 55 posts👁️ 68,462 views
Page 3 of 3
Posted May 02, 2016 · 13:04 UTC#51
I got stuck at Reading 100%,  I then used a Smaller memory card (1gb) and the wince upgrade worked.
Posted Jul 09, 2017 · 11:14 UTC#52
Hi All,
When I try to open the guide from google I get the message error topic does not exist..
Is there a reason for this?
I've found what I think is the correct software if this helps anyone..
Can someone help me with the correct method?
http://www.mediafire.com/?fk177j7sk65d5pd
http://www.mediafire.com/?j4agh9jemp2ml0c
http://www.mediafire.com/?dhsy1fe8m50vaks
Hi,
Can you check these files, because in the second and  third link zip files is damaged. If it's possible can you renew it?
Thank you very much.
Posted Jul 14, 2017 · 12:47 UTC#53
Hello,
Can I use this Hybrid on a F960BT with installed version 1.14 and what could be done for a prior back-up? I've seen that Testmode only works from 3.0 and up. I already have the latest 2017 maps for EU, but I like to try a newer and smoother version too :)
Thanks guys!
Posted Nov 03, 2018 · 01:49 UTC#54
any resolution to this problem.  I am having the same issue
Posted Dec 15, 2019 · 19:40 UTC#55
On 26/05/2015 at 14:03, dws said:
téléchargé toutes les cartes de ce post et tout fonctionne bien! merci beaucoup
merci le fichier n'existe pas
Page 3 of 3
