hybrid 4.0 avic-f900bt
By adamleerusse · Mar 13, 2013in Hacks/Mods💬 55 posts👁️ 68,462 views
Page 2 of 3
Posted Feb 25, 2015 · 15:30 UTC#26
Hy Guys i have a question
My Build was v3.
Now i have updated to the posted Version 4. But not the regular way i think: I have replace all the files in the APL Folders with the newer ones.
I have not Update the Win CE image. Is this ok? Cause my win ce image is Version 5 is this the version 6? Because the date modified on the files are not the same. I have taken my old ezrider to use my old maps and my sys.txt for the Settings. My Unit works but im not shure that was the right way to update. In system Settings i have now a DebugMode with a few features is this correct? Thank you very much.
Edited Feb 25, 2015 by simon2k2
Posted Mar 01, 2015 · 12:22 UTC#27
Hi. How can I use Sygic navigation under the Hybrid 4.0?
Posted Mar 17, 2015 · 22:13 UTC#28
thank you finally solved my rebooting problem
Posted May 26, 2015 · 07:02 UTC#29
Hi All,
When I try to open the guide from google I get the message error topic does not exist..
Is there a reason for this?
I've found what I think is the correct software if this helps anyone..
Can someone help me with the correct method?
http://www.mediafire.com/?fk177j7sk65d5pd
http://www.mediafire.com/?j4agh9jemp2ml0c
http://www.mediafire.com/?dhsy1fe8m50vaks
thank you, followed instructions included in the archive and successfully updated f910bt to v4.001. 8)
Posted May 26, 2015 · 10:58 UTC#30
Same here, files work and recovered a bricked f900bt! trying to get some maps in them now
Posted May 26, 2015 · 12:03 UTC#31
uploaded all maps from this post and all works fine! thanks a bunch
it 's work with your version so your avic be slow to use upgrade him in version 3 first  don't buy any cnsd fm version it's losing money for nothing
do this upgrade before
https://drive.google.com/file/d/0B4MAukIOceEXbTFCZURPRWR1ZFU/view?usp=sharing
take this folder decompress him take inside the folder nammed plt  and do this
1)put the 2 winces inside a sd card do this after you put sd card inside your avic
with your fingers press 3 touch (menu,map,eject) in the same time and with stylet press reset
you 'll have a black screen retire stylet of reset you'll have a blue screen take off your fingers
2)avic try a code do this with joystick (up,up,down,press menu,left,right) and press in center of joystick to valid
3) you'll be in menu of wince select 0 and upgrade with sd card (no format) the avic read your sd card and you'll be upgrade your avic
4) in the folder nammed lpue080 you have a files (4) lpue080apl , lpue080apl.ver , lpue080data ,lpue080data.ver
copy them inside your flash disk replace your older files
and the folder nammed apl replace your older apl  all things with total commander and upgrade your map,and all
Posted May 27, 2015 · 04:58 UTC#32
Thanks to this my unit no longer stuck on splash screen :)
Thnx!
No have to look for double din conversion kit for my peugeot 206 xD
Posted Jun 13, 2015 · 23:17 UTC#33
This ressurected our bootlooping F900BT - many thanks for creating this image and process.  Unfortunately, despite my best efforts, I failed to save the map data prior to reformatting.  Time to buy new maps - the previous ones were quite old anyway.  Suggestions welcome for the best place to buy them.
Edited Jun 13, 2015 by tigerdog
Posted Jul 24, 2015 · 05:09 UTC#35
Just wanted to say thank you. This fixed my unit.
Posted Oct 11, 2015 · 21:42 UTC#36
What the fuck good are these 7zip files? The extensions are .001 .002 & .003. & 7zip doesn't recognize them nor does anything else. I edited the file name of them to have a proper .7z extension and low and behold, errors when trying to extract. Unable to extract. Why the fuck can't people just stick to the standards? What a waste of fucking time.
Posted Nov 06, 2015 · 16:47 UTC#37
^^^ummm this is a standard....its the standard when you split large zip files into many smaller files. WinRar & 7z are both able to open these types of files....you have to make sure you grab the first in the series.
Posted Jan 03, 2016 · 10:40 UTC#38
Hello
I have an AVIC-F900BT with
version map 01.000800
version 1.900000
I can update it with hybrid 4.0?
Posted Jan 04, 2016 · 21:00 UTC#39
Hi yes you can only don't forgot to take the folder license
Posted Jan 05, 2016 · 19:16 UTC#40
where I take the folder license?
Posted Jan 06, 2016 · 08:22 UTC#43
:mrgreen:
Posted Jan 13, 2016 · 00:07 UTC#44
Hi,
I had done the update to hybrid 4.0 but maps are not working.
I´m from Brazil and I tried the old map that i was using before and a another one new(here brazil 2015 q2).
Have this new firmware the same layout as the old one?
Can someone help me?
Posted Feb 03, 2016 · 16:20 UTC#45
hi i want to upgrade my maps to 2015 Q3 and import speedcam on my unit avic-f70DAB, do i need to use this methode to do that?
thanks
Posted Mar 08, 2016 · 04:11 UTC#46
not sure if I'm trying to do the right thing or not my avic f700bt keeps rebooting it works fine for about 3 minutes then shuts down and starts rebooting again... I'm looking up information on how to update the system but I'm not sure if its gonna work if you guy think it will work please post links to the updates Ive called pioneer but they want 230 dollars to fix it... really hoping I can get the help I'm looking for on here be I don't want to spend that kind of money..... tia....
Posted Apr 07, 2016 · 21:37 UTC#48
Isn't the shut down and rebooting after a period of time usually a sign that the cooler fan is dead or not working properly?
Posted Apr 12, 2016 · 07:13 UTC#49
Hello,
tried to make an upgrade on an Avic F900 BT. Got the bluescreen and tried option 0.
But then I get the message 100% immediately and when I restart I still got the old firmware on it. Any suggestions?
What is that "license" folder for?
Thanks,
Mike from Germany
Posted Apr 27, 2016 · 20:04 UTC#50
Thanks need to try this.
Page 2 of 3
