it 's work with your version so your avic be slow to use upgrade him in version 3 first don't buy any cnsd fm version it's losing money for nothing
do this upgrade before
https://drive.google.com/file/d/0B4MAukIOceEXbTFCZURPRWR1ZFU/view?usp=sharing
take this folder decompress him take inside the folder nammed plt and do this
1)put the 2 winces inside a sd card do this after you put sd card inside your avic
with your fingers press 3 touch (menu,map,eject) in the same time and with stylet press reset
you 'll have a black screen retire stylet of reset you'll have a blue screen take off your fingers
2)avic try a code do this with joystick (up,up,down,press menu,left,right) and press in center of joystick to valid
3) you'll be in menu of wince select 0 and upgrade with sd card (no format) the avic read your sd card and you'll be upgrade your avic
4) in the folder nammed lpue080 you have a files (4) lpue080apl , lpue080apl.ver , lpue080data ,lpue080data.ver
copy them inside your flash disk replace your older files
and the folder nammed apl replace your older apl all things with total commander and upgrade your map,and all
