F700BT F710BT F900BT F70BT F90BT 2014 Q1 EU Maps
By terrorhawk · Oct 11, 2014in Hacks/Mods💬 168 posts👁️ 81,113 views
Page 2 of 7
Posted Feb 11, 2015 · 08:07 UTC#26
the license.zip folder where I put ? thanks
Posted Feb 11, 2015 · 09:36 UTC#27
hi open apl2 and igo and you have a folder nammed license
Posted Feb 11, 2015 · 12:23 UTC#28
Hello, i have a Problem.
I come frome Germany ,my english is not so perfekt.
I don`t understand this:
"4) in the folder nammed lpue080 you have a files (4) lpue080apl , lpue080apl.ver , lpue080data ,lpue080data.ver
copy them inside your flash disk replace your older files
and the folder nammed apl replace your older apl  all things with total commander and upgrade your map,and all "
My Avic is Upgraded with the SD Card but my Avic say`s : System in progress and thar restart.
What have i to do ?
Posted Feb 11, 2015 · 15:39 UTC#29
it 's work with your version so your avic be slow to use upgrade him in version 3 first  don't buy any cnsd fm version it's losing money for nothing
are you do this  before?
do this upgrade before
https://drive.google...iew?usp=sharing
take this folder decompress him take inside the folder nammed plt  and do this
1)put the 2 winces inside a sd card do this after you put sd card inside your avic
Posted Feb 11, 2015 · 15:41 UTC#30
Posted Yesterday, 09:04 PM
DO THIS THING FIRST
with your fingers press 3 touch (menu,map,eject) in the same time and with stylet press reset
you 'll have a black screen retire stylet of reset you'll have a blue screen take off your fingers
2)avic try a code do this with joystick (up,up,down,press menu,left,right) and press in center of joystick to valid
3) you'll be in menu of wince select 0 and upgrade with sd card (no format) the avic read your sd card and you'll be upgrade your avic
Posted Feb 11, 2015 · 21:48 UTC#31
Ok I think I have the first part done   :-P
My next SD card is looking like this "I think thats right" I'll try it tomorrow and fingers crossed it will work. Thanks again for your help guizmo I owe you a pint.
Edited Feb 11, 2015 by fergalb
Posted Feb 12, 2015 · 06:38 UTC#32
Hi yes it's the good way  :mrgreen:
after copy your map,poi,building  with total commander and it's be ok
Posted Feb 12, 2015 · 10:05 UTC#33
I think I have a problem I cant seem to be able to find  apl2 or igo in my flash disk, any ideas where it could be. Thanks
Posted Feb 12, 2015 · 17:19 UTC#36
Ok after another day in the car  :-P  I'm nearly there and it's looking good.
But after a few min's the system startup came on and it went back to the blue screen switching on and off between the two  I thought this was just updating so I left it for an hour and a half and still no change, I had to turn off the car then as I was getting low on fuel :?  should I leave it run longer tomorrow or is this a problem. Thanks again hopefully I can leave you alone soon.
Posted Feb 12, 2015 · 19:18 UTC#37
hi take this link  is 2  different voices in uk  put them in a sd card with testmode and copy them inside your flash disk open apl2 and igo content and the folder voices and copy inside
after this take this link and copy them inside your avic with testmode  open apl2 and after igo and content and lang and copy inside
i use only french voice it's the reason for the avic don't have the files
Edited Feb 12, 2015 by guizmo
Posted Feb 12, 2015 · 19:21 UTC#38
take the 2 winces files inside the folder lpue080  copy them alone in your sd card  and do the blue screen and choice 1  read sd card  and after reading it's gone be ok
Posted Feb 13, 2015 · 07:21 UTC#39
Thank you guizmo works perfect   :mrgreen:
One last question where I can find the updated files speed cam spain? thanks
Edited Feb 13, 2015 by pacomasi
Posted Feb 13, 2015 · 08:47 UTC#40
Hi it's easy  register in site poiplaza  choice speedcam and igo text format and copy the files inside your avic on folder speedcam
Posted Feb 13, 2015 · 14:08 UTC#41
Hello I registered in poiplaza page and have gotten the file in txt format with copy TestMode disappears palicación but rather leaves me no speedcam.
is that what I'm doing wrong the spedcam who had jobs were in SPdb format thanks
Posted Feb 13, 2015 · 20:06 UTC#42
delete spdb  file inside your folder of speedcam  when the avic restart he create new spdb file and he integrate your new speedcam
Posted Feb 14, 2015 · 07:47 UTC#43
the avic did not create any spdb file.
I just get a file named SpeedcamUpdates.spud
Posted Feb 14, 2015 · 09:28 UTC#44
try to poiplaza in another format  try igo8 text
Posted Feb 14, 2015 · 13:23 UTC#45
I'm still having problems  :neutral: this is my flash drive and igo folder am I missing something here. I'm not great with computers and this is melting my brain  :-P plus my calibration is off making things very tricky.
Posted Feb 14, 2015 · 13:52 UTC#46
you are do the copy in wrong way delete all things inside your flash disk with stylet press on every line and choice delete
after this copy my flash disk open folder and copy all files inside my flash disk  to your flash disk
to copy the map open folder apl2 and igo and content and folder map delete old map and copy new
this is the reason for not working of your avic you don't copy in good way
Edited Feb 14, 2015 by guizmo
Posted Feb 14, 2015 · 13:55 UTC#47
testmode stay in your storage card not in your flash disk and open folder ezrider and copy the file inside (do this open apl2 and open igo  and copy ezrider file only when the avic tell replace say yes )
Posted Feb 14, 2015 · 13:58 UTC#48
using total commander at left side open storage card and at  right side open your fash disk  and after copy my flash disk (open my folder flash disk at left side  and copy the files who are inside all files)  do this and post pictures
Posted Feb 14, 2015 · 14:01 UTC#49
Ok I'll give it a go, thanks.
Posted Feb 14, 2015 · 16:03 UTC#50
Ok I opened "My flash disk" on the left side and the files APL and APL2 came up so I copied them over to my flash disk after dealing everything else.
Page 2 of 7
