vfl you forget to change ezrider this is link take him and copy him and replace your ezrider in apl2 open and open igo and change
https://drive.google.com/file/d/0B4MAukIOceEXTnlMb3ZpOWwwRVU/view?usp=sharing
i did try still some but now i m did take ur file My Flash Disk MB
and copy map but not all Complet Map Europe installed becous memory full
what can be delete
their much file like car skin or thems whice not need
what can i delet some file to install all europe
My Radio working all fine now just map want to
how to enable speedcamre?
update
will it working that all map build poi over sd slot?
Hi use only map with extension .fbl , you can delete map with extention .hnr,fsp,fda and you have place in your avic
http://avic411.com/index.php?/topic/80834-speedcam-for-all-europe-east-and-west/ for update your speedcam
no it's not obligation to use sd slot delete the files you don't use or the files i tell you to delete and everything be ok
in my flash disk you have 2 folder with map delete folder map.nt and just let folder with map
Can u tell me what sould delete i no need themes. No need car skin
What mean Western Europe and East Europe it country Thier Luke UK France Spain ??
you have a folder inside igo nammed map-nt delete inside all files
after inside folder map you have older map delete them first just let basemap file
after copy all map you are sur to go one day exemple if you know you never go in russia or vatican or ukraine or germany you can delete this map
for the speedcam it's for all europeen country east and west include great britain and irland the place taken of speedcam in your avic is small
delete anything else it's can trouble work of avic
if you don't use car skin you can delete 3d cars folder but the place he use is small
do the same for building and poi delete all country you are sure never go and it's be ok
Thank now better how to enabled speed cam i saw the setting enabled Speer Warnung Ehen i change to. On after test cam speed. Nothing show then i go setting it off how to on ?
go in folder call user (he was inside igo) inside open folder nammed save inside delete PERMANENT_V1.sav, SETTINGS_LOWLEVEL_V1.sav, SETTINGS_V2.sav and system.ini"
and tell me result
and tell me result
when i delete all this 4 file and restart it come Navi in France Language and and i try in setting alert to enabled speed warning and when i go back it still off
update
when i turn Radio on it take bit longer until music start on befor wasnt how will be fast
will it work with FX 3.1 it some like ur ?
for FX3.1 it working speedcamere but TMC not their
on this from u r folder working tmc but speedcamera not working :-S
i have map now Eruope 2014 Q2
Hi copy the first link decompress him and instal on a sd card with testmode after copy all files inside your avic
after take the second link copy all files inside your avic (decompress first ) and the speedcam working after
where to put on?
overwriteh them?
need first install then start it or just first one then seconden?
when you decompress you have folder with name only copy and delete the same files you have inside your avic and copy
first you copy mod 4.01 after copy 4.07 replace all files who are the same
and delete PERMANENT_V1.sav, SETTINGS_LOWLEVEL_V1.sav, SETTINGS_V2.sav and system.ini"
now everything work peferkt new menu
just one more thing now the Voice of Germany not working it was working befor after update this all good just no voice of germany i try english it only speak france voice??
good news i give you files for english lang and voice
take this link and put the folder inside open igo and open content dans put the entire folder decompress first to have the folder ready to useif you want i give you folder to talk in english for speedcamdo u have for german language?
i got error after copy this file when start up
internal error
no voice file found on system
then i delet file and put old back still no navi working
need fresh copy again!!
hi take this folder in first you have a folder lang and in second folder voice decompress first and put the entire floder in apl2 open and open igo and open content and replace your folder of lang and voice
i did some whiche u told me then restart it come fatel error no voice file found in windwos expolore like that
take back french lang of my flash disk i give you and french voice inside folder voice maybe program work perfectly with this files inside if the problem won't be erase try to copy my flash disk and inside copy your lang and voice and delete anything to see if everything work fine
finaly working german voice
first i copy the my flash disk wiche u and then lang, voice copy, let start up and waiting change to to language to german it restaret. after that their lanugage setting for voice i change to german and try for navi if german and yet it. so after copy the mod 4.01 then after done copy. then mod 4.07 let start yes it working now german,
now how to automatic close for wiche their many symbole when i touch it it come pop up how to make automatic close when not touching anything
go in parameters of navigation open map screen and choice what you want to see and what you don't want to see exemple
automatic zoom click on no
it didnt worked then i did factory reset and then working now all fine best so far, but the music when start up take bit long then come, and some playback going back to first title
i use sd card sdhc 16g i have the same problem i don't find solution for this problem ,i try to do folder with every different singer the same problem no solution for this
Hello,
I just updated my Avic with the newest windows CE and copied the new agl etc. to my flashdisc, but when I start my nav it keeps the blue starting-screen... Maybe someone of you can share his flashdisc? Also the new europeen maps I missed... and a short instruction how to install the german language? Would be really nice!
Thanks a lot!
