F700BT F710BT F900BT F70BT F90BT 2014 Q1 EU Maps
By terrorhawk · Oct 11, 2014in Hacks/Mods💬 168 posts👁️ 81,113 views
Page 3 of 7
Posted Feb 14, 2015 · 16:48 UTC#51
the link i give you is with all files copy all files inside my flash disk you missed apl3 etc....
the link is bigger  keep all files of my flash disk
Edited Feb 14, 2015 by guizmo
Posted Feb 14, 2015 · 20:06 UTC#52
Should I open the APL and APL2 on the right side and then copy each file over to my flash drive.
This is what APL looks like when I open it.  Thanks again and sorry we won the rugby  :-P
Posted Feb 15, 2015 · 07:44 UTC#53
post-86442-0-89884300-1423986174_thumb.jpgHi no let the folder whole and copy inside your flash disk
this is what you must have inside your avic use 7zip  to extract my flash disk
Posted Feb 15, 2015 · 14:09 UTC#55
Ok that seems to work, I had to do it on a PC as my Imac was blocking some files. I just have to update the maps and I should be sorted. Thanks again guizmo.
Posted Feb 15, 2015 · 14:58 UTC#56
yes very nice i forget to tell no use imac he don't keep all files  :mrgreen:
you can delete chromeimage it's only if you wan't to change color of menu nice trip
Edited Feb 15, 2015 by guizmo
Posted Feb 16, 2015 · 13:17 UTC#57
Ok I got my Irish maps in but my settings are still in french do I change this on my flash disc or on the avic.
Edited Feb 16, 2015 by fergalb
Posted Feb 16, 2015 · 18:55 UTC#58
hi guizmo sry. but my english is very bad.will it works on my
F920BT ?
Posted Feb 17, 2015 · 06:31 UTC#59
Hi fergalb   ok are you copy the files who i said to you the english lang folder inside folder lang of avic (take a sd card put the folder english lang inside  with testmode  and the folder voices ) i give you the link for files
put your sd card inside your avic turn on your avic  you are in windows open total commander
at the left side open storage card  and at the right side open your flash disk
at the right side after you are open flash disk click on apl2 open him and click on igo open him and click on content open him and click on folder lang and copy the folder lang inside the folder lang of your avic and do the same for the folder of voices
let the lang folder whole don't decompress him for the voices do the same whole  and after you do the copy
turn of the avic retire the sd card  turn avic on and select  parametres  and lang and voices and it's be ok
Posted Feb 17, 2015 · 06:31 UTC#60
Hi adelhaid  no it's not the same for your avic this program can't work for you
Posted Feb 18, 2015 · 08:47 UTC#61
Hi everyone,
Is this program gonna work on a F30BT?
Thanks.
Posted Feb 18, 2015 · 12:53 UTC#62
Hi no  only  f700 bt ,710 bt,900 bt,910 bt,500 bt
Edited Feb 18, 2015 by guizmo
Posted Feb 18, 2015 · 14:46 UTC#63
Too bad!
Thanks for the answer!
Posted Feb 20, 2015 · 14:59 UTC#64
Dear Guizmo,
Thanks for your good and clear SUPPORT.
I put today in one hour the update on my Pioneer F500BT and it works very good and fast.
All the answers and questions helped me well !!!
Now i can in May/june  on Holiday by car to Spain through France ( Route du Soleil) with the new 2014 Maps !
Thanks and kind regards from the Netherlands !
Rob
Posted Feb 20, 2015 · 15:14 UTC#65
I would be lost without him he has the patience of a saint  :-P  I'm still not there yet my Lang and voices are not working for me but I did these on my imac,  my daughter will be back from college at the weekend so I'll have another go with her laptop.
Posted Feb 21, 2015 · 09:48 UTC#67
hi robsel  good news have a nice trip  :mrgreen:
Posted Feb 21, 2015 · 17:54 UTC#68
Is it possible to run maps from SD card instead of flash disc?
Posted Feb 21, 2015 · 20:25 UTC#69
yes it's possible to run a complete program from sd card you can run primo ,you have no reason to read map outside flash disk take only map do you want ,with ezrider patched. you  have on site the primo of ryar he work fine .
Posted Feb 21, 2015 · 20:51 UTC#70
I want to use original igo prog on my pioneer but I need alot of maps on vacation. I can't fit them all on my flash disc.
Is there some way to put the maps on my SD? Edit the sys file?
Posted Feb 23, 2015 · 20:56 UTC#71
Hi h4d3z   take this link one is testmode  and another is  nav mod  copy testmode and nav mod on sd card  and copy new map and poi and building  to refresh inside the flash disk in your sd card  to work  use only primo  to work insert  the sd card on your avic and turn on your device .avic boot on windows screen  press on storage card and after on flash disk and on apl2 and on primo and he start if you don't want to use retire only sd card after using and you be on your normally avic .use a sd card of 8 g
Edited Feb 23, 2015 by guizmo
Posted Feb 23, 2015 · 21:37 UTC#72
Please the password for zip file thanks
Posted Feb 24, 2015 · 06:32 UTC#73
the password  is   www.avic411.com   sorry i forgot to write him   it's chuck 88 program  a member
Edited Feb 24, 2015 by guizmo
Posted Mar 02, 2015 · 19:30 UTC#74
i have problem navi wont start after  i cope the file BUILDER MAP  AND POI then restart it stay longer systemstart waiting!!
i have F9110BT
Posted Mar 03, 2015 · 04:03 UTC#75
So its not possible to use original navi with maps on sd card ? I have to use this version, but i cant listen to radio/cd etc ?
Grts
Page 3 of 7
