Navteq 2013 Maps, hex parking brake bypass, hex nag screen bypass
By mrc00l88 · Mar 04, 2014in Hacks/Mods💬 20 posts👁️ 6,929 views
Posted Mar 04, 2014 · 00:35 UTC#1
for z130bt
has anyone tried the 2013 maps or are the 2012 the most current that work? and does anyone have the parking brake and nag screen bypass hex codes?
any help would be greatly appreciated
thanks!!
Posted Mar 15, 2014 · 19:32 UTC#2
nag screen "OK" bypass per  Pionara:
On 5.1 firmware (available for Z140 - but the application update portion can be applied to any unit upgraded to 2013/5.0 - I just applied to my Z130)
at offset BE9A4 (version 5.1):
change 05 00 00 0A to 00 00 A0 E1
update: just verified this is working
Posted Mar 17, 2014 · 22:20 UTC#3
Dang I don't remember how to do the nag screen patch. Is it done with testmode ? Seems like that was how but in which folder is the BE9A4?  also my unit is avic 920bt. Shure could use your help.   Thx
Edited Mar 17, 2014 by FreeTime
Posted Mar 17, 2014 · 22:46 UTC#4
Reposting here since it is pertinent.
I found a patch offset that works  with v5.0.
At offset BEBFC, change 05 00 00 0A -> 00 00 A0 E1
Edited Feb 05, 2015 by RonS
Posted Mar 18, 2014 · 20:14 UTC#5
what is the difference between firmware 5.0 or 5.1 - and where do i get it? I am just seeing the 2013 maps for download with 5.0.  i have a z130bt
Posted Mar 18, 2014 · 23:36 UTC#6
If u don't have a iphone 5 best bet is just use the 5.0 in the map download folder, As Rons says you only need the 5.1 if u have a iphone5 or else u can have ipod audio problems.I just installed the 2013 maps and then used a hex editor  after the map install to change the navi.exe at address BEBFC FROM 05 00 00 0A to 00 00 A0 E1  Then I used testmode to delete the navi.exe and replace it with the one I changed.
Edited Mar 18, 2014 by FreeTime
Posted Mar 18, 2014 · 23:43 UTC#7
Is 5.1 available to download here? I'm confused I only see the 2013 maps with 5.0 and thought that was the most recent version.
Posted Mar 18, 2014 · 23:46 UTC#8
Never mind, I think I got it after reading through a few threads. It seems people are doing the 2013 5.0 upgrade then doing the 5.1 patch upgrade on the Pioneer website. Correct?
Posted Mar 19, 2014 · 16:18 UTC#9
I am sorry but can someone please guide me a step by step to remove the OK screen?
I am 110 to 140 and updated to 2013 map a few days ago and now it's 5.0
thank you again.
Posted Mar 20, 2014 · 06:19 UTC#10
Hey anyone remember what the offset and change needed for Z120 with 3.00?  like a fool I updated to 5.1, nuked the VR navi feature hoping for better functionality and found that the update gave me the new maps alright, but for some reason VR commands were buggy.  Did the nag screen mod ages ago when Pionara first posted it and cant find the modded navi.exe file I saved in case I decided to update, or revert.  Navteq / Pioneer really blew it removing the VR Nav feature from the current updates, that was the whole reason I bought the AVIC-Z120BT! I reverted and managed to keep the 3.32 BT firmware which was somewhat worth the trouble
Edited Mar 20, 2014 by Thevil1
Posted Mar 21, 2014 · 03:08 UTC#11
Ha! Found my file!  mischief managed!
Posted Mar 21, 2014 · 14:15 UTC#12
Question - what did you have to do to revert back to 3.x? Since to get to 5.1, you needed to install 5.0 also - and I believe they each install  in different /USR/PRGx folders. So - to revert it wouldn't be just a matter of adding or deleting /USR/PRG.FLG as necessary.
I always thought (but never tried) that it wasn't possible to install (via the normal installation process) over a "higher" version. Is that not true?
I had played around in TestMode with the "forced program write" function, but never got it to find the necessary files on my SD. So I gave up on that method.  Since I was having issues w/5.1, and 5.0 was still in my /user/prg0, I just deleted /user/prg.flg and rebooted. But I don''t think that would work for you.
Posted Mar 21, 2014 · 17:57 UTC#13
I tried deleting the /USER/PRG.FLG and rebooting but it didn't work for me.  I deleted the USER file all together and replaced it with my back up file which brought me back to 2.00.  I then just did the update to 2.03 and then finally 3.01 and added the modified navi.exe in APL.  I've since backed up my current USER file and would think that if I ever do find an update that retains the VR NAV feature, I'll try again.
What I found when I updated directly to 5.00/5.01 was that I didn't get any of the features added in 4.6 in the 2012 map update, and my VR was buggy.  Cool thing is when I reverted it kept the BT firmware update.  I initially tried just to update the BT firmware but it would not recognize it.  BT is working fine.
Posted Jul 16, 2014 · 07:46 UTC#14
I modded the Navi.exe file for 5.0 for my 120, but I don't understand where to get the testmode.key files that let me into the file manager.  Can anyone help?
Posted Feb 04, 2015 · 20:01 UTC#16
I just went from 2.03 to 5.0. What features didn't you get by skipping over 3.0 - 4.6?  I've noticed I don't have Pandora or aha icons, but maybe you have to be connected before they appear.
Posted Jun 27, 2015 · 05:43 UTC#17
Hello, I did the update map 2013 usa./canada on my z110bt., but was unable to update Bluetooth. Can any1 help me?
Posted Jun 27, 2015 · 21:01 UTC#18
Once the map update is complete, you have to manually navigate the screen menu to the bluetooth section and select the update option from there.  it should find it on the sd card and update.
Posted Jul 05, 2015 · 18:41 UTC#20
Thank you, I had the tooth turn off
