Well..Im done. Pioneer are liars plain and simple.
By GHII · Mar 26, 2014in NEX Series💬 45 posts👁️ 23,867 views
Page 2 of 2
Posted Apr 09, 2014 · 02:41 UTC#26
How did you change your background to look like fire, I can't figure that out, I have two floating balls of light, would like to see what other options there are
go to settings, background, select AV instead of HOME and scroll through the background pics. it should be the 1st animation. I like the EQ better
Posted Apr 09, 2014 · 18:46 UTC#27
So why is that? Is there a hardware limitation? I ask because if the hardware is there, why could they not implement this through a firmware update? Especially sense they have claimed they will support this.
That was Pioneers choice. It is a feature that they chose not to support.
Posted Apr 09, 2014 · 19:07 UTC#28
well I guess its good I am not putting this into a car that has these additional features :)
Posted Apr 09, 2014 · 19:32 UTC#29
I have been in talk with ADS (They are a Canadian based company) engineer and after purchasing the iDatalink Maestro and CHR02 adapter specific to my car (2007 Dodge Charger R/T) the shop was not able to install. Ended up going with the standard PAC harness.
They (ADS) are very quick to assist and while at the shop, they created 3 firmware updates on the fly to try and resolve my issue. But they were unable to resolve it. Here is a few excerpts...
Will pass along your comments and contact you again when we have software
for you to use.
Regarding the radio, I am not sure what OBDC (I meant OBD2) is, but we use a connection to
the OBD2 connector to implement the gauges and check engine code reading.
The 2013/2014 Kenwood DNX and DNN models all have this integrated already.
In your car, we don't know what gauges would be supported (but there will be
some) and likely we are not able to read your tire pressures if you even
have a Tire Pressure Monitoring System at all.   We can also read and reset
check engine codes and detect open doors (on Vehicle info screen).
The Alpine 7,8 and 9 inch navigation radios for 2014 (shipping May/June)
will also have these features.
We try to be as proactive as we can with consumers, but at the same time, we
have an obligation to present our partner's products as favorably as we can.
We are thrilled to have a partnership with Pioneer and I am sure over time
they will have all the features implemented.
Best regards,
Mark
Hi Patrick,
Got your email.  See my comments below.
Also, you need to be 100% clear about what the Pioneer radio will do/not
do.
The digital firmware for the NEX radios is not available yet.  So,
when you flash the MRR for your car and NEX radio, you will get the AS
firmware.
This firmware will let you retain and configure your steering wheel
controls (if you have them), turn on the amp (when it is fixed), and
provide all the outputs you need to wire up the radio (accessory, reverse
wire, etc).
When the DS firmware update from Pioneer is available (will require
you to download onto USB and update the radio) you can reflash the MRR
and you will get DS solution.  This solution will add:
Ability to fade the factory amplifier
Ability to retain uConnect (if you have it/want to do so)
It will not add any of the other things you seemed excited about.
Pioneer does not plan to add screens to the 2014 NEX radios for:
- Gauges
- Vehicle info (tire pressure, open doors, read/reset check engine
light)
- Visual parking assist (if car equipped with ultrasonic parking
sensors)
- Climate Control (not applicable in your vehicle)
Pioneer may support these features next year, but likely only in the
new model radios.  It's a major undertaking to add these features so the
entire radio software might need to be re-written.
I am not sure if this helps, but you need to know the scoop.
Best,
Mark
Posted Apr 11, 2014 · 22:47 UTC#30
Dose pioneer know about this fourm? If so, Why haven't they chimed in to set the record straight? I have the 8000 and this was one the features along with a couple more that's not working that cought my interest in spend the type of money I did for this unit. I have been a pioneer fan for a long time and I am very disappointed with them at this point.
Posted Apr 13, 2014 · 11:46 UTC#31
Check out the product user review on the Crutchfield site for the 8000. This guy says the iDatalink worked in his 2013 Jeep........Bogus?
http://www.crutchfield.com/p_1308000NEX/Pioneer-AVIC-8000NEX.html?tp=20222#customer-reviews-tab
Funny thing is in the product description, Crutchfield says the iDatalink will not work until a firmware update is released this summer.....
Edited Apr 13, 2014 by rtpjunior
Posted Apr 13, 2014 · 12:03 UTC#32
Well if you pull up I datalink website and select 2013 jeep grand Cherokee, it shows the info it will show, quite a bit of data. So maybe his works because firmware was already written
Posted Apr 13, 2014 · 12:04 UTC#33
Because there are only a few of you discussing this. Pioneer is a company that sells products to thousands, maybe even millions of people. And believe it or not, with the many thousands of members on this forum, we are only a very small fraction of Pioneer's customer base to the point that we really don't matter. The fact is, most people that buy these units will not even be aware of this feature and won't miss it. Most people that buy these units walk into a store not knowing what they will buy and walk out with these units and that is what Pioneer cares about. And they certainly know about this site. I have been on this forum sense 2006 and have owned every high end unit up until now and there have always been people that have asked that same question every year I have been here. Until they start getting tens of thousands of emails about the same issue nothing is going to change. And they won't be getting enough emails to address this issue even if they could or wanted to.
Edited Apr 13, 2014 by VBLUE42
Posted Apr 13, 2014 · 14:35 UTC#34
All of that is true.
What is also true is that there aren't many forums where end product users can post their likes, dislikes, workarounds and ideas, particularly for fairly niche products such as higher end car audio equipment. You'd think that in an era of survey driven customer satisfaction, a forum such as this would be a gold mine for a company such as Pioneer.
I wouldn't think they'd need to take it to the level of Cadillac, who seemingly have customer service representatives actively monitoring the forum and stand ready to assist with just about any issue, but I think Pioneer is missing the boat by ignoring their customers, too.
Then again, Kenwood either couldn't get it right or simply ignored their customers for years about how slow their high end head units were, so this might be an industry wide problem.
Posted Apr 13, 2014 · 14:45 UTC#35
These two companies have one thing in common, they're both Japanese companies and that is the problem. This is all to common among companies like this.
Posted Apr 22, 2014 · 21:11 UTC#36
Huh? ADS is a Canadian compnay. Piuoneer put an update on their website.
IDATALINK MAESTRO
Keep your factory features and expand your level of in-vehicle connectivity with Pioneer NEX and iDatalink Maestro RR. When the AVIC-8000NEX receiver is installed into a compatible vehicle using the iDatalink Maestro RR (sold separately), you’ll be able to enjoy the performance and features of the AVIC-8000NEX plus touchscreen control over key factory audio features. The AVIC-8000NEX supports factory functions via the iDatalink Maestro RR including: Steering Wheel Controls, Media Player (including the factory aux-in and USB ports), Hands-Free Telephone, Voice Commands, Satellite Radio, Premium Audio, and Secondary Display Support.
The AVIC-8000NEX will need to have a firmware update (available early summer) applied to provide compatibility with Maestro RR.
Posted Apr 22, 2014 · 23:23 UTC#37
Not to beat a dead horse here.  Pioneer may be having problems working with idatalink but they are light years ahead of Alpine and Kenwood with smart phone connectivity.  If Idatalink really intends on keeping up with PAC and Metra they will get a solution to the problem.  Be patient, they will figure it out.
Posted Apr 22, 2014 · 23:31 UTC#38
I agree, I can get vehicle info from the vehicle so this is a nice option to have but not a deal breaker for me with everything else the 8000 offer
Posted Apr 23, 2014 · 16:53 UTC#39
Well said.
Posted Apr 23, 2014 · 16:58 UTC#40
Exactly. The 8000 does more than enough.... Very satisfied with the unit. In addition I've looked a several consumer responses from the Alpine units and they're mostly negative.... The features lacking on their Alpine units are readily accessible with the 8000... I'd rather have navi, great sound quality, iPod/iPhone video functionality over vehicle info any day of the week.....
Posted Apr 23, 2014 · 19:33 UTC#41
My factory vehicle nav cam with vehicle info on the unit. But i had to manually enter the oil changes and stuff. real annoying. Dont care much for it besides theres also Dash Command that does pretty much the same except climate control.
Posted Apr 24, 2014 · 06:45 UTC#42
I wasn't referring to ADS.
Posted Apr 24, 2014 · 06:46 UTC#43
IDATALINK MAESTRO
So up until now you have made claims that this will never happen. So how do you explain this in reference to your previous claims?
Posted Apr 24, 2014 · 19:07 UTC#44
Guys I owe you an apology. Pioneer will not have the full features like Alpine and Kenwood.
2014 NEX models – AVIC-8000NEX,  AVIC-7000NEX, AVIC-6000NEX, AVIC-5000NEX, AVH-4000NEX.  These units will be compatible with all of our solutions to retain factory systems (except our Mustang dash kit), but they do not have gauges, climate control (this is why you can’t use the MUS1), vehicle info or parking assist screens.
Brian Murphy
As I said here. Pioneer does not intend on covering Gauges with the new NEX radios. What I have said has not changed. As of right now the only thing you can do with a Rr and a NEX radio is analog steering wheel controls. No sync retention. The update that is coming from Pioneer will allow the 4 pin idatalink cable to do steering wheel controls and other data commounication between the Rr and the Pioneer radio. IT STILL WILL NOT DO GAUGES. As I have said multiple times, Pioneer choose dot to support gauges.
Edited Apr 24, 2014 by Iammurph
Posted Apr 24, 2014 · 19:32 UTC#45
Well your a buzzkill ROFL. ThAnks for the info though
Page 2 of 2
