NEX Problem Thread
By kelkin · May 23, 2014in NEX Series💬 68 posts👁️ 16,635 views
Page 3 of 3
Posted Jun 12, 2014 · 23:01 UTC#51
My month old Avic8000 Nex has started shutting down intermittently.The unit appears not to be powered. The only way to repower it is if I remove the electrical connector from the back of the radio, let it sit for an hour, hit the reset button and reinstall it.I then have to boot it it as a new install. Pioneer said the unit must be returned to them for three weeks and they'll have a look.....great! Yes...i believe it's wired correctly.
Posted Jun 12, 2014 · 23:15 UTC#52
The problem was not in the install, but in the phone. With the galaxy s4 I had to pair the units and then refresh the call audio setting in the device settings on the phone. All is good.
Posted Jun 12, 2014 · 23:22 UTC#53
What type of truck?
Posted Jun 13, 2014 · 13:29 UTC#54
What type of truck?
Posted Jun 13, 2014 · 13:30 UTC#55
Audi allroad 4.2
Posted Jun 13, 2014 · 13:45 UTC#56
I removed the 10 amp fuse from the back of the radio, reconnected electrical connector there is 12 volts at lower Fuse terminal & red and yellow power connections. After reinserting fuse unit still not responding....
After waiting an hour with everything disconnected I hit reset button, and reconnect electrical connector, Unit works
Posted Jun 13, 2014 · 20:03 UTC#57
I would use a multimeter to check power and ground. Also make sure all pins in harness are seated properly before sending off.
Posted Jun 15, 2014 · 07:00 UTC#58
is anyone having problems getting your day/night color scheme not staying put?  it always goes back to default after a long power cycle.
Posted Jun 19, 2014 · 00:55 UTC#59
Last week I put it back in the dash...it's been working perfectly.
I suspect the tight fit in the day had something to do with my problems and was not internal to the Avic 8000NEX unit...
Posted Jun 24, 2014 · 23:12 UTC#60
I have the 4000nex and if you have a ipod or iPad plugged into the USB ports the radio will not connect to my s5 via bluetooth audio, as soon as I disconnect the USB connection it connects and Pandora or aha work flawlessly ,, so stupid I keep my ipod in my glove box for a reason , now I have to constantly open the glove box and plug it in
Posted Jun 25, 2014 · 13:39 UTC#61
One of my pet peeves: unless I totally missed it, there is no way to mute the microphone (but not the speakers) while talking on the phone via Bluetooth except to pick up your phone and mute it there.
Edit: and another pet peeve... There is no decent way to zoom out on the Nav map while you're driving. You can set you zoom (kinda, the settings aren't very good) in the Settings area, but if you try to pinch to zoom in or out while driving, the Nav thinks you want to set a new destination.
Edited Jun 26, 2014 by ian351c
Posted Jun 28, 2014 · 05:49 UTC#62
My name is Daniel and I just installed the Avic 5000NEX I went to set up my navigation and every thing was ok till I got to the End User License Agreement. t will not let me click on the accept button neither the decline button. I tried resetting it twice but still got the same thing. Can someone please help me with this problem.
Thanks,
Daniel
Posted Jun 28, 2014 · 05:51 UTC#63
Pull the parking brake.
Posted Jun 29, 2014 · 00:50 UTC#64
I have a problem with my Aviv 5000NEX the speed control wire can someone please tell me where it goes and what it connects to on the factory wiring harness?
Thanks,
Daniel
Posted Jun 29, 2014 · 04:40 UTC#65
i have a 2013 Toyota Corolla & am still in the process of hooking all the wires up I should have mentioned that in my earlier post sorry for the confusion. I dont know how to hookup the speed control cable or what wire it goes to. Could someone help me with this please?
By the way I have an Avic 5000NEX
Thanks,
Daniel
Edited Jun 29, 2014 by scifihero
Posted Jun 29, 2014 · 14:57 UTC#66
Thanks,
Daniel
usually, you connect the speed control wire to the appropriate wire coming off of you dash gauge cluster. just google speed control wire for your car and you should be able to find a wiring diagram that will tell you where to find the wire and what colors it is.
Posted Jun 30, 2014 · 09:28 UTC#67
Thanks,
Daniel
So did ya get this fixed before going to another issue? I also see you created another thread asking the same question as what you started this thread for. That thread will be deleted.
Posted Jun 30, 2014 · 20:10 UTC#68
i have the Avic 8000NEX installed in a 2012 Toyota 4Runner. All is working well, might get a few Bluetooth issues but they resolve themselves eventually.
But my main concern is the unit randomly hangs and then restarts.
I have seen this happen at least 4 times when using SiriusXM, AppRadio, Navigation or Bluetooth streaming. Anybody experienced such issues yet?
I'm pretty sure the unit is not overheating because i have noticed it moments after starting the vehicle.
Page 3 of 3
