AppRadio 4 with CarPlay just announced - finally...
By meall · Oct 02, 2014in AppRadio, AppRadio 2, AppRadio 3💬 159 posts👁️ 36,472 views
Page 4 of 7
Posted Nov 03, 2014 · 21:25 UTC#76
You can check the AV adapter by changing the source to HDMI - It should then mirror your screen, although you'll obviously get no touch.
Sometimes you need to force quit the app and relaunch. I find if I launch with Waze rather than the official app, it always works.
Posted Nov 03, 2014 · 22:15 UTC#77
Then I definately have a problem as I now get the mirrored screen with no touch. I've tried connecting with the app booted and without and the results still the same.
As said earlier, I think appradio has a limited life so I'll stick with it as CarPlay works great and hopefully there'll be be compatible nav apps soon.
Grant.
Posted Nov 04, 2014 · 01:02 UTC#79
Grant.
I guess you can use Apple's Map application to do turn by turn directions.
But I you said, it is likely more Car Play enabled applications are on the way...
Posted Nov 04, 2014 · 01:21 UTC#81
Not sure if this helps but in order to use Appradio, dont you also need to install the Appradio app on your phone aswell?
Posted Nov 04, 2014 · 02:01 UTC#82
Technically no. All Appradio apps run appradio mode independent from each other. So for example if the only appradio app you had any interest in was Waze, you could download waze and nothing else, and every time you open the Waze app it will display in appradio mode on the display, while nothing else will unless you are mirroring the display.
Now if you want to go in with Appradio, the Appradio app is your center hub that the phone will go back to when you press the home button on the head unit.
Personally I find Carplay to be what Appradio wishes it could have been.
Posted Nov 04, 2014 · 12:32 UTC#83
I just tried out Appradio mode on my Appradio 4...  Its pretty shit to be honest.  Its laggy, slow, apps take forever to launch and the display seems to be very low quality?  Worst thing is you have to use a big ass lightning to HDMI cable.
I'll stick with CarPlay.
Posted Nov 04, 2014 · 13:44 UTC#84
Is there a bug in messages?
If you look at this video from about 8:00, you'll see that he clearly wants to check the message from his girlfriend, but it seems to start a new message using the previous text. I get this every time as well.
Posted Nov 04, 2014 · 15:24 UTC#85
Sam it. Weird!
And Siri have her misses as well.
Posted Nov 07, 2014 · 05:50 UTC#86
Can someone please tell us how long the AR4 takes to boot up? Much appreciated.
Posted Nov 07, 2014 · 10:04 UTC#87
12 seconds
Posted Nov 08, 2014 · 06:09 UTC#88
Thanks fruitbat! I had a couple more questions hoping someone could help out with.
When powered up can the radio automatically pick up Bluetooth to stream audio or do you always have to select it?
Anyone utilizing steering controls? Does it only work with a specific control unit or can you retrofit with exiting original manufacturer steering wheel controls?
Thanks again for the time. Finally getting ready to pull the trigger on buying an AR since the 1st on was announced.
Posted Nov 08, 2014 · 08:00 UTC#89
Hey Mate,
Yes, the unit will automatically play bluetooth audio at the last song position before you turned the car off.  No need to press anything, it will connect and auto-play.
Regarding steering wheel controls, i am using Axxess ASWC-1.  Im pretty sure you can use any but i read that Axxess was one of the easiest to install/program so thats why im using it.
Edited Nov 08, 2014 by JJJones
Posted Nov 08, 2014 · 17:02 UTC#90
Much thanks JJJones! I am going to pull the trigger finally. Now if only carplay would utilize Waze instead of Apple map crap!
Posted Nov 08, 2014 · 23:18 UTC#91
I think it is just a matter of the developer making an update to his code to support Car Play. Contact them and ask the question.
Posted Nov 09, 2014 · 04:20 UTC#92
Highly unlikely as Google owns Waze.
Posted Nov 09, 2014 · 12:08 UTC#93
I don't see it being that unlikely, they want users, if they thought like that they wouldnt release Waze in the app store at all
Posted Nov 09, 2014 · 14:47 UTC#94
Agreed. And they did it for App Radio, so why not Car Play?
Maybe the turn around time is more due to the limited hardware to test on, the limited number of users, hence the limited number if request for it..
Posted Nov 09, 2014 · 22:45 UTC#95
Yeah it's a tough one to call but doubt it will happen. Just like you can't utilize any other app aside from Apple maps if you were to ask Siri for directions. Not sure if possible with a jailbreak though.
Posted Nov 10, 2014 · 14:43 UTC#96
Would love to see a jailbreak tweak for Carplay that would allow more apps to work.  Anyone jailbroken on iOS8 yet and see any tweaks being developed?
Posted Nov 10, 2014 · 14:53 UTC#97
Even if a jailbreak would exist, the best you could expect will be a screen mirroring. Not an optimize view.
The solution is for the developers to update their apps...
Posted Nov 10, 2014 · 15:28 UTC#98
LOL.  Not the case bud.  Apple will decide what apps can be "optimized" not the developers.  It will take a jailbreak tweak to get into the guts of the carplay code and "trick" it to show on screen.
Posted Nov 12, 2014 · 10:03 UTC#99
There'so already a few apps supporting Car Play without jailbreak:
http://appadvice.com/appnn/2014/10/carplay-enabled-car-owners-will-heart-the-new-version-of-iheartradio
http://appleinsider.com/articles/14/10/23/iheartradio-rdio-are-latest-ios-apps-to-add-support-for-apples-carplay
By the way for Canadian buyers, Futureshop and BestBuy are now offering the App Radio 4 online:
http://www.bestbuy.ca/fr-CA/product/pioneer-pioneer-appradio-4-6-2-bluetooth-double-din-smartphone-receiver-sph-da120-sph-da120/10327763.aspx?path=e861ade425676888b27dd8e53045fd9dfr02
http://www.futureshop.ca/en-CA/product/pioneer-pioneer-appradio-4-6-2-bluetooth-double-din-smartphone-receiver-sph-da120-sph-da120/10327763.aspx?path=afb75bb53ae2d376212ac8cac9d64c7den02
Posted Nov 12, 2014 · 19:04 UTC#100
meall, I didn't say non apple apps would not be able to work with Carplay...I said for more apps (especially one's Apple will NEVER approve like Google Maps) to work, likely a jailbreak tweak would have to be developed.  A developer cannot have their app CarPlay compatible without Apple authorizing it to do so.
Page 4 of 7
