Finally got it installed! Bypass done in a minute. Brackets modified so cover fits flush. Ipod adapter works awesome and fast. I don't have bluetooth nor sirius/xm installed. Navigation works great and I leave dvd in drive since I only use my ipod as a source of music. Now to buy the avox jukebox ![]()
Pros
- Navigation is great but this is my first NAV
- Screen is bright and no problems with glare
- iPod is fast with really no delay
- Cheap?!
Cons
- Can't play xvid file (gotta modify them)
- Select iPod videos through iPod itself and not directly through headunit
Haven't had much time to really play with it but those are the first things I noticed. Again, this is my first aftermarket head unit/navigation so I can't compare it to other models in regards to features and navigation.
Straight outta the box
RCA cable for the bypass
Picked out wire with eyeglass screwdriver
Bypass finished
Stock head unit vs Avic D3
Modified Brackets
Modified Brackets with Metra kit screwed on
Most of the wiring done
Daytime Pictures
Nighttime Pictures
Tested it on "scene" xvid releases and it worked. Movies took a good minute to load off dvd. AC3 works as it loaded them off aXXo release but showed up as 2 channel on Avic. Here are some pictures.
Fearless AC3
Family guy, Rocky, and Top Gear
Customizable Wallpapers
Seems like D3 is picky as image resolutions. An image the size of 500x375 filled the screen up. While that image above is 1200x800 and had edges like fullscreen movie on a widescreen set. No option to expand of stretch either.
