CD-BTB200 & Bluetooth Phone Compatibility Guide
By Itchy · Apr 04, 2007in General💬 311 posts👁️ 131,434 views
Page 11 of 13
Posted Aug 07, 2008 · 03:13 UTC#251
hi,
has anyone tried the sprint samsun ace?? sph-i325 i believe.........
i know some on here have gotten the at&t blackjack to work....but i cant seem to get the ace to work..
-j
Posted Aug 28, 2008 · 06:08 UTC#252
Stop me if this has been covered, but im stumped.
I have the AVIC-D3 and the CD-BTB200 Bluetooth set-up and a Blackberry Curve 8310.
Ok here is what I have working. Great voice activated phone calls, a little echo but still good, hang up and pickup options on the AVIC.
What I dont have is call from the AVIC available, I cant register the phone and I cant transfer the phonebook (blackberry says "Unable to locate push server, consult CD-BTB200 bluetooth hands free manual" ok the Bluetooth set-up doesnt mention these problems.
It does say register it would help in other threads.
Options i have under phone FUNCTION (NONE) the button isnt even lite, so I cant register since thats where the manual says you do it from. I have a function button lite under the MUSIC from the Blackberry but no option really to do with the phone or registration.
PLEASE HELP ME!
Posted Aug 28, 2008 · 06:12 UTC#253
Service Provider: Rogers Wireless
Phone: Blackberry Bold
Auto-Connect: Yes
Basic Function: Yes
Phone Book Transfer: Yes
Voice Calling: Did Not try yet
Call History Log: Yes
Signal & Battery Strength Indicator: Yes to both
BT Audio Capable: Yes
Posted Aug 28, 2008 · 16:50 UTC#254
PLEASE HELP ME!
Im a dork, all my problems were because my ebrake wasnt on. DOUH....
Posted Sep 02, 2008 · 23:17 UTC#255
I have a D3 and a Samsung SGH-A707 (Sync). I read someone had gotten theirs to work and I was wondering if you did anything special. I can get mine to auto connect and pair just fine. I can make and recieve calls, but the problem is that I have no sound outgoing or incoming, just static. I know Samsung phones seem to be problematic just from reading thru these boards, but someone got it to work so is there any trick I'm missing?
Posted Sep 04, 2008 · 03:04 UTC#256
Has anyone gotten the LG VU (AT&T) to pair with the D3? I'm looking to buy the VU on Saturday and would like to know in advance how compatible it is with the D3. Thanks.
(LG and VU don't give any results due to the length of the search terms)
Posted Sep 10, 2008 · 20:18 UTC#257
Service Provider: AT&T Wireless
Phone: LG VU CU920 (aka CU915, TU915)
Auto-Connect: Yes
Basic Function: Yes
Phone Book Transfer: One-by-one
Voice Calling: Yes
Call History Log: Did not attempt - will later
Signal/Battery Strength Indicator: No/No
BT Audio Capable: No success to date
Well, no thanks to you all :wink: I bought the LG VU (CU920) anyway. I messed with it multiple times yesterday to no avail. About an hour ago, I took my lunch and tried it again. I deleted all of the old BT settings in both the VU & D3, then tried it again.
I turned the VU's BT on and set the D3 to search for BT devices...It found the phone. I selected the VU on the D3's screen, it said "connecting," and the VU prompted me to input the password (0000). Then a beautiful thing happened...it connected! Registered the phone in the D3/BTB200 and all is well.
In order to transfer phonebook entries, you need to disconnect the BT link (you can select "Phonebook Transfer" under the D3 Function menu and it will disco the two). Go to the VU's phonebook, select [Contact] > [Options] > [send vCard Via] > [bluetooth] > [Pioneer BT unit].
Much to my surprise, it autoconnects/disco's upon entering/exiting the car, without any extra settings. My V3xx needed a few BT settings changed to allow it to do that on its own.
I'll edit this to include my success with the BT Audio, and the other issues.
Posted Sep 25, 2008 · 06:33 UTC#258
SPrint releases the Treo 800w (Windows Mobile 6.1). It has Bluetooth 2.0. Anyone using bluetooth 2.0 able to connect to a D3 without using Jetware?
IGO
Update..
I installed Jerware but never paid or registered it. I was able to connect and using all bluetooth functions except Voice and Phonebook tranfer. After the trial period ended on Jetware..I have been still able to connect flawlessly. Plus I have a solid connection with bt audio also....able to advance and repeat via the D3 screen. Im able to keep my Treo 800w in my pocket totally. Yippie!!!!
Posted Nov 04, 2008 · 23:08 UTC#259
Has anyone had any luck with the new Blackberry Bold, 9000? They refuse to auto connect
Posted Nov 06, 2008 · 03:39 UTC#260
Yes I got this to work tonight after much frustration. I will try to explain what steps I took. For search purposes this guide pertains to Bluetooth pairing on the AVIC D3 with the Blackberry 9000 also known as the Blackberry Bold.
Before you start, make sure on your Bold/9000 that you go to Manage Connections --> Bluetooth Options and then click your Blackberry button. You should get a pop-up menu and one of the choices on the menu should be Options. Click this and verify that Discoverable is set to Yes and all the listed services have a check mark by them. For whatever reason it seemed to only work for me when I discovered the phone from the head unit, but not when I discovered the head unit from the phone. Screwball.
I had to delete my BB8820 from the system. I could not get the BB9000 to connect without this. i.e. it would not let me have both devices registered. Who knows why. I never tried to add the BB8820 back in after getting the BB9000 registered. If you have another BB registered you might have to do this. To accomplish this, from the main menu do the following:
1. Press AV Source
2. Press BT-TEL
3. Press Menu
4. Press Function
5. Press Phone Register
6. Press the Delete button next to your old phone.
I also had to reset the pin number on the head unit/BT module because for whatever reason the default 0000 pairing pin that worked fine for my BB8820 would not work for the BB9000. How to do this was on page 24 of my factory Pioneer Bluetooth guide. In case you don't have the factory guide, here are the steps:
1. Click the Menu button
2. Go to AV Source and press the Off button in the lower right corner
3. Press the Initial button at the top middle of the screen
4. Press the PIN Edit button
5. Key in whatever you want, I used the last 4 digits of my SSN
6. Press Enter
7. Press the Back button
8. Press the AV Source button
9. Press the BT-TEL button
So now you should have your BB9000 set up for discovery, your old handset deleted from the D3 registry, and a new pin number in the system. Time to make a BT connection.
1. From the main menu, press AV Source
2. Press the BT-TEL button
3. Press the Menu button
4. Press the Function button
5. Press Phone Connect
6. On your BB9000, go to Manage Connections --> Bluetooth Options, and press your Blackberry button. One of the choices on the pop-up menu is Add Device. Select this. The BB9000 will then ask you if you want to Search, Listen, or Cancel. Select Listen.
7. IMMEDIATELY press Search on your D3. It will search, and should shortly present you with a button with either "Name not found" or your BB9000 device name. Pressing the Phone Name button gives you the hardware address of the device.
8. On the D3, press the button that has the name of your BB9000/hardware address on it. The word Connect should flash in the top right hand corner of your D3, and after about 10-15 seconds should connect to your BB9000
In order to get the device to Auto Connect every time you get near your vehicle, you may have to make two more setting changes - one on the BB9000 and one on the D3. On the D3, Auto Connect has to be set to On in the BT-TEL configuration. If you don't know how to do that, let me know and I'll post the procedure. To set your BB9000 so it can auto connect, do the following:
1. On your BB9000 go to Manage Connection --> Bluetooth Options.
2. You should see "Pioneer BT Unit2" or something like that listed in the Paired Devices list.
3. Select the Pioneer BT Unit and click your Blackberry button.
4. Select Device Properties from the pop-up menu.
5. Make sure Trusted is set to Yes.
This process is needlessly complex, laborious, and non-intuitive. I like this head-unit, but I think someone was on crystal meth when they came up with this pairing process. The process to transfer the address book from the BB9000 was even more screwball. That's the topic of another post. I did discover in all this that I could stream music and movies from my BB9000 to the D3. That didn't work with my BB8820 and is definitely cool.
-E
FINE PRINT
This forum has helped me out so much since I got my D3 and I am eternally grateful. I was fortunate to get two BB9000 from my company's AT&T rep on Nov 4 for 50% of the retail price. I figured it was my turn to give something back to this community. Hopefully this guide will help someone else almost as much as I've been helped by everyone here. Thanks everyone!
Posted Nov 06, 2008 · 03:46 UTC#261
Thank-you eheisig for having a step-by-step directions on how you got it to work. The old phone on my Avic is my 8525 so maybe it was having a similar problem to your old BB.
I really want to go out to my car right now and try this but I need to wake up early tomorrow, lol.
Posted Nov 06, 2008 · 03:46 UTC#262
Phone: Blackberry 9000 (aka Bold)
Auto-Connect: Yes
Basic Function: Yes
Phone Book Transfer: Yes (about 200 records in 30 seconds)
Voice Calling: Yes
Signal/Battery Strength Indicator: Yes/Yes
BT Video Capable: Yes
Posted Nov 06, 2008 · 03:50 UTC#263
It's a good bet. Either that or the PIN number needs to be changed.
Tomorrow when I get home I will trying registering one of my 8700s and one of the 8820s as well and see if I can get them all married up and working without deleting the 9000. Wait...is that polygamy...? ;)
I'll post my results if I get to it.
-E
Posted Nov 06, 2008 · 04:12 UTC#264
But the weird thing is... with my 8525, I dont ever recall having my phone in the register slot. It just worked, haha. And with my Bold, I have to keep searching on the avic, like you stated and re-enter my password. While, on the 8525, whenever it was near, it would auto connect. Nor was my Bold in the registered slot too
Hopefully, I can just change the PIN and have it work like my old phone
Posted Nov 06, 2008 · 05:37 UTC#265
I just picked up the Sprint HTC Touch Pro today, and after installing the JETware mobile software it connected right up. So far it looks like auto-connect is working, but that's about all I've had the chance to test so far. I'll edit this post and let everyone know what else is working with this. I love this phone!
Posted Nov 06, 2008 · 21:32 UTC#266
-E
Well, I was able to get it working and it is working perfectly. For some reason, I cant send my contacts over but that isnt a big deal since I never used it. Not to mention, with voice command and vlingo, I dont really need to have that either
Thank-you again
Posted Nov 19, 2008 · 06:33 UTC#267
Phone-SW Version: AT&T Quickfire
Autoconnect: Yes
Basic Function: (Make & Recieve a call, Call History, Preset Memory) Yes
Phone Book Transfer:Yes
Voice Calling: No
Signal & Battery Strength Indicator: No / No
BT Audio Capable?: Not tested
Posted Dec 02, 2008 · 23:34 UTC#268
Phone: HTC Fuze
Auto-Connect: No
Basic Function: No
Phone Book Transfer: No
Voice Calling: No
Call History Log: Not Tested
BT Audio Capable: Not tested
Well, after maybe 2 trys of trying to get this god sent phone to work normal and having no luck I thought back to my HTC Tilt I just upgraged from and went to the jetware website downloaded it and babaaam...works like a charm.
Phone: HTC Fuze
Auto-Connect: Yes
Basic Function: Yes
Phone Book Transfer: Yes, One Transfer of all
Voice Calling: Not Tested
Posted Dec 04, 2008 · 01:49 UTC#269
Great info but I have a few questions. I have the Blackberry Curve and it auto connects everytime however the BT Audio connects sometimes and when it does I can't get the audio player to work. How do you load the songs and start BT Audio to work?
I was also able to transfer my phone but and using the Category functions within phone.
Another questions. How do we get the D3 phone ringer to ring louder? Mine rings very softly and the only option seems to be on or off.
Lastly does anyone know how to answer the phone only/disconnect from the D3 BT when the phone rings? Sometimes I don't want everyone in the car on the conversation.
Thanks,
1. Press AV Source
2. Press BT-TEL
3. Press Menu
4. Press Function
6. Press Enter
-E
FINE PRINT
Posted Dec 13, 2008 · 20:15 UTC#270
Phone-SW Version: Samsung Eternity
Autoconnect: Yes
Basic Function: ALL
Phone Book Transfer: Yes, but only one at a time.
Voice Calling: No
Signal & Battery Strength Indicator: Yes and Yes
BT Audio Capable?: Yes, well, sorta. It doesn't connect reliably at all. Works fine with my Motorola S9 headset though.
Posted Dec 18, 2008 · 06:15 UTC#271
ok i have the LG VU TU915 , i can get it to pair and connect etc, but when making a phone call or recieving, the unit disconnects from the phone...how can i fix this?
Posted Dec 19, 2008 · 13:50 UTC#272
Not sure why it would do that, but try it again as I suggested one page back...start clean and delete all previously paired devices from both the phone and the HU. Make sure the phone is set to "visible" under BT settings, let the HU find the phone, enter passcode, it will connect, then go to the BT registration settings on the HU and hold down the appropriate button (#1, perhaps?) until you see LG CU915 or whatever it says. That's all I had to do to get it to work.
Regarding you not being able to hear them and vice-versa, reconnecting the two might fix that.
Posted Dec 20, 2008 · 03:47 UTC#273
I have been using a Verizon xv6800 (running Jetware) with a Pioneer AVIC-D3 unit in my vehicle for about a year without any problems. I installed the latest Verizon update for the XV6800 to correct some other issues; among other things, the update brings the phone to Windows Mobile 6.1.
Since doing the update, I can't get the phone to work with the Pioneer. I reinstalled the latest Jetware software, but this caused a new problem:
The phone pairs with the Pioneer, it shows the signal strength and battery level, contacts can be transferred to the Pioneer, a phone number can be entered on the Pioneer and the phone dials it-- however, it will not use the Pioneer as a headset/handsfree. The phone shows the headset icon, indication that it is connected to the Pioneer, but as soon as the phone begins to process make the call, the headset icon disappears until after the call is completed.
I have unsuccessfully tried every combination of switches under the Jetware advanced options.
HELP!!!
Thanks,
Doug
Posted Dec 30, 2008 · 22:41 UTC#274
I finally got my D3 installed and am having some issues with the TMobile G1.
So I get in the car the first time and pair it up and start making calls no problem. Address book doesn't transfer but I had a feeling it wouldn't since I remember reading that the G1 only supports the handset/headset profile. So next time I get in the car I assume it would auto-pair and my phone rings but my phone rings instead of my head unit. Is there a reason that the G1 doesn't auto-pair with the head unit and asks me for the passcode everytime. Its just a bit of an annoyance everytime I get in the car to have to type the passcode in for my phone.
Posted Feb 14, 2009 · 23:43 UTC#275
can anyone confirm they have transfered there phonebook from the iphone 3g
Page 11 of 13
