the generic beeping ring is from the headunit itself, and you can disable it in the menu while in BT-Tel mode. I have "use phone ringtones" enabled in Jetware and my ring tones play through the stereo. When i had MS voicecommand installed i would even hear the call announcment (e.g. "Call from Mom's cell") through the stereo.
CD-BTB200 & Bluetooth Phone Compatibility Guide
nope, just checked, it is in the IP Bus input side closest to the power molex
That's wrong i'm pretty sure. It should be in the one labled "IP Bus out" which is the one furthest from the power.
What are the other setings in your phone's BT menu?
I had to disable security beam authentication to pair sucsessfully, andmy bluetooth explorer is enabled but Bluetooth file sharing is not, and I have no COM ports setup, do I need to setup one?
and within the HTC's Settings do you have your device set to use wireless stereo, and Handsfree?
Thanks- Jonah
nope, just checked, it is in the IP Bus input side closest to the power molexThat's wrong i'm pretty sure. It should be in the one labled "IP Bus out" which is the one furthest from the power.
I'll buy that...
I am going out to switch them now, I'll let you know how it goes
I left all other settings as default.
Beam Authentication: On
Turn off visible mode: never
Enable Bluetooth Explorer: Off
Enable File Sharing: Off
Under the settings for Pioneer BT unit, i have Hands Free and Wireless Stereo both checked, but i still have to connect the BT Audio manually each time. I am also using a cooked ROM from xda-developers FWIW.
You Sir Are A Gentleman And a Scholar!!!!!!!!!!!!!!!!!
Words cannot explain my appriciation right now!
IP Bus just needed to be connected to the IP Bus OUTPUT NOT INPUT!!
With it in the wrong port I could get no audio, but once I switched it over
IMMEADIATE DIFFERENCE! THANK YOU SOOO MUCH! thing works like a charm now! and to think i was ready to box it back up and return it!
WOHOO, is there anyway to get the D3 to play custom ringtones over car speakers though?
NEVERMIND>...
upon further testing it looks like the IP bus fix had also fixed the ringtones issue, now everythings sounding great!
haha, i wouldn't quite say that, but i'm glad it worked! I certainly know how frustrating it can be.
yeah, its kind of like installing a time bomb in your car, if you cant figure out how to get it working before the refund period you end up stuck with a 180$ paperweight, lol. Thank you again for your help, I am sure glad I found AVIC 411!!
I just bought the Samsung r610 slider phone yesterday, and had the BTB200 installed already. Both the phone and the headunit/BT module find each other, but cannot seem to pair. The headunit (D3) gives me "connection error", and then will connect the odd time, but not hold the connection. The phone never gives me a successful pairing message and just continually gives me the "pairing" screen. The odd time, it will display a message of "the key didn't return during pairing". Any help, please?!?!?
What kind of bluetooth settings does the samsung have? List em along with their settings and maybe we can help further.
SPrint releases the Treo 800w (Windows Mobile 6.1). It has Bluetooth 2.0. Anyone using bluetooth 2.0 able to connect to a D3 without using Jetware?
IGO
Service Provider: at&t
Phone-SW Version: Sony Ericsson W760i
Autoconnect: Yes
Basic Function: (Make & Recieve a call, Call History, Preset Memory) Yes
Phone Book Transfer: Yes
Signal & Battery Strength Indicator: yes/yes
BT Audio Capable?: YES
Phone-SW Version: Apple 3G
Autoconnect: Yes
Service Provider: at&tPhone-SW Version: Apple 3G
Autoconnect: Yes
i cant find if the iPhone 3g has the OPP bluetooth profile or not...so i'll just ask...can you transfer the phone book in one transfer? or do you have to do it one contact at a time?
-KNemesis
Autoconnect: Yes
Just curious but how did you get yours to autoconnect? I have to pair iphone 3g each time the radio/car is turned on.
Autoconnect: Yes
I had the same probelm until I deleted other phones I had saved in my D3. I then deleted the pairing on the iphone, and re paired and ever since then It connects every time, and also unconnects when I turn the car off, the call is still going on phone. As well as if I get in my car on the phone it transfers to the cars speakers once turned on!
Autoconnect: Yes
Thanks for your suggestion.
What I figured out was that I needed to register the phone. For some reason I forgot it does not automatically register any phone but after I held down one of the slots on the registration page it connected the iphone. Now I get in the car and everything connects without having to pair each time. I remember it automatically registering my Blackberry Curve but I was wrong.
Now if we could only get it to charge the iphone. Maybe that is just wishful thinking.
Is it possible to transfer phonebook from iPhone 3g to the D3? I tried the phonebook transfer and it just disconnecting the pairing.
Service Provider: Verizon Wireless
Phone: LG VX10000 (Voyager)
SW Version: VX10KV07
Auto-Connect: Yes
Basic Function: Yes
Phone Book Transfer: Yes (ALL - Select Mark All and Send via Bluetooth)
Voice Calling: Yes
Call History Log: Yes
Signal & Battery Strength Indicator: Yes to both
BT Audio Capable: No
So I set up the bluetooth today right after I had the d3 installed and was surprised how smooth everything went. Phone was able to auto-connect, after it did the 1st thing I did was registered the phone. Then I tried the phonebook transfer; Selected the option on the d3, the phone did its thing & I went to bluetooth menu, highlighted pioneer bt unit, chose options, send name card, then selected mark all then done. The d3 accepted everything the 1st time no problem.
As far as bluetooth audio goes I was not able to get that to connect but didnt really mess around with it too much. I'll try again tomorrow and If I have any luck I'll let you guys know what I did
Any questions feel free to ask
My LG Voyager wont pair at all however my brother's RAZR paired just fine, is there some kind of trick to pairing it that I'm not getting? Even the guy who installed it couldn't figure it out and he's supposed to be a professional lol.
I had no issues. Try deleting any other bluetooth devices from the bluetooth menu and then restarting the phone. When you try to connect again make sure you put the voyager into discovery mode.
Verizon LG 8350
All functions work great
had to load contacts one at a time
ALL MOTOROLA RAZR's- I read someone's instructions and it worked perfectly but ONE ENTRY AT A TIME. You must be on the screen with the phonebook download is. Once you disconnect, don't touch the screen but go to your phone and bring up one entry. Once on your chosen name, push the view button and scroll down until it says: "Share phonebook entry". Select and hit bluetooth. An "object exchange" screen appears with Pioneer BTB or "look for devices". Since my phone has already been established, I chose Pioneer BTB and it downloaded number and checks it off. The screen will say COMPLETED(on top) after every entry. You have to do one at a time. It's less than a minute for entire step once you get the hang of it. Just make sure your engine is running cuz my battery DIED while editing my phone numbers using the AVIC screen editing tab.!!!
Does this apply to the newer razr v9m? I'm thinking about picking one up but want to make sure it's going to work fine. I have a Samsung Alias now and that worked flawlessly.
