CD-BTB200 & Bluetooth Phone Compatibility Guide
By Itchy · Apr 04, 2007in General💬 311 posts👁️ 131,434 views
Page 8 of 13
Posted Mar 20, 2008 · 03:13 UTC#176
My Samsung Blackjack does'nt work with the avic-d3 it will only hook up but wont upload the phone book
Posted Mar 21, 2008 · 00:31 UTC#177
Sprint Mogul 6800
ROM 2.17.651.0
radio 1.47.01
Installed Jetware and ALL the functions work including phone book transfer. Slow searching but it works.
I had a problem pairing them up for a few days...then reset the BT adaptor and all is well now! Auto connects, works 100%
I am using the latest ROM and radio (3.35) with A-GPS and Rev-A. Have you upgraded your Mogul? and if so does the pairing still workin perfectly? I'm thinking I may need to reset the BT adaptor in the car as well. Let me know please.
Posted Mar 22, 2008 · 19:50 UTC#178
Service Provider: Cingular (AT&T Wireless)
Phone-SW Version: Samsung D807
Autoconnect: Yes (register 807 in the avic d3)
Basic Function: make call/receive call ; speed dial
Phone Book Transfer: no everytime i tried phone gets disconnected
Voice Calling: Yes
Signal & Battery Strength Indicator: Did not look at time
BT Audio Capable?: i can connect but did not test if it works
D3x kit on an Audi 2004 S4
Posted Mar 22, 2008 · 19:54 UTC#179
I just returned this phone. It had other limitations which I didn't like.
I bought the Samsung U 740. I was able to tranfer the phone book but I can't auto connect.
Any advise on how to auto connect?
thanks
J
did you register your phone in the d3? you have to in order to auto connect. page 106 and 109 on manual
Posted Mar 23, 2008 · 02:49 UTC#180
Voice Calling: Yes
phone book transfer works! one at a time though
after you finish registering the d807 in the avic d3 ;
you go to phonebook transfer this will make the d807
disconnect dont panic on you d807 you could go to your contacts
and send each contacts' detail via bluetooth and voila.
Posted Mar 24, 2008 · 01:07 UTC#181
Hello all.. new to the boards...
Has anyone had any luck transferring contacts from the Samsung SGH-a737? There isn't any option, that I've found, in the contacts menu that allows me to transfer them. Every time I use the phone book transfer from the CD-BTB200 the connection between it and the phone disconnects. I've found that I can move contacts from the address book to "My Stuff" folder where the entries become .vcf files. The phone offers the option to transfer these over bluetooth but, again, I can't seem to maintain the connection everytime I try to use the transfer phone book option from the B2B200.
Posted Mar 24, 2008 · 01:44 UTC#182
when your phone disconnects, you could transfer only one contact at a time ; on your phone go to the address book and highlight the person you want to transfer and transfer it via bluetooth. then you will see on the d3 confirm the transfer.
Posted Mar 24, 2008 · 01:55 UTC#183
Do you have the same handset Tony? I tried looking for an option to send right from the address book on the phone but there isn't. When moving the contacts to the "My Stuff" folder on the phone, I'm allowed an option but when I select it, the BTB200 is not on the device list to send to.
Posted Mar 24, 2008 · 03:45 UTC#184
i have a samsung d807 also a slider phone. make sure you register your
phone first in the d3. from your phones contact list choose a contact click options then send via bluetooth. did that make sense?
Posted Mar 25, 2008 · 04:07 UTC#185
Tony it makes perfect sense... two problems though:
1. send via bluetooth option is not available from the contacts menu (i.e. it's not on the options list when going into the contacts menu and hitting options)
2. even when moving the contacts to the "my stuff" menu where the send via bluetooth option is available, the phone is apparently not recognizing the BTB200 as something it can send the contacts to. It lets me send info to my laptop from here but the BTB200 doesn't even show up on the devices list when I try to select the device to send to.
It's tough not to get really frustrated with this.. the bluetooth module and phone are brand new and I can't get the contacts into the phone book.
[edit] forgot to mention, the phone is registered and it pairs up with the module automatically, every time I get in the car.
Posted Mar 25, 2008 · 15:25 UTC#186
first connect /register phone in d3 which i believe you did
when you hit phonebook transfer on d3 your phone will disconnect
time to transfer your phone contacts (1 at a time via your phone)
Heres what i see on my phone
contact list > i choose 1 contact (lets say wife) > option > send via > bluetooth >search new device > u should see pioneer> thats it
hope that helps you out. let me know if it works
Posted Mar 26, 2008 · 16:54 UTC#187
Doesn't work..
Here's how my phone is laid out:
contact list > choose 1 contact > options > at this point there is no "send" option offered but there is a "send business card" which I think is just a new name for the option of sending the contact > pick 1. Message or 2. Bluetooth for transfer method.
Problem is, when I do the above and select bluetooth, the "Pioneer BT unit2" is not on the devices list to select from. If I hit search for more devices, more often then not it'll find it but I'm only allowed the opportunity to connect or disconnect with it - never the option to send to it.
It has to be this model of phone. I tried transferring contacts as .vcf files this morning from my laptop and they actually transferred. Trouble is, the BTB200 doesn't list those contacts in the phonebook for my phone so I suppose they're actually assigned somehow as they're getting transferred in... I'm just about ready to give up.
[EDIT] Having re-read both of our last responses, I'm realizing my issue is not finding the option to send the contact but getting my handset to connect to the pioneer when I want to send.... that's strange because in general the pioneer and phone pair with no problem whenever I get in the car and I can make calls from the handset that go through the pioneer and manually dial numbers out with no problem from the pioneer... but the handset just wont connect to the pioneer while it's in transfer phone book mode... any thoughts anyone?
Posted Mar 26, 2008 · 17:25 UTC#188
Im having the same issue with my Sanyo M1 and tried the same laptop fix as you (see my previous posts) with the same problem. I think we are SOL until we get different phones.
Posted Mar 26, 2008 · 18:51 UTC#189
Hi guys,
I am using the Btb200 with the Motorola Ming and it works pretty well. As always I was not able to transfer my phonebook, but, I was able to send contacts one by one. It was not that bad since I saw it as an investment and I only sent over about the 25 people who I know I would defiantly call while in my car. When the phone rings it sends my ring tone directly to the unit. The way that I was able to do this was that I turned the avic ring tone option off so instead of getting the annoying beeps that you get when you have a call I hear, Jay- z "roc boys". It auto connects by the time I put my car in reverse and performs just as it was intended to (ie pausing tracks upon receipt of a call and resuming upon completion).
Phone Specs
Service Provider: Unlocked (Using with Cingular)
Phone: Motorola A1200 (Ming)
Carrier: Unlocked
Functionality
Phonebook Transfer: No
Auto connect: Yes
Bluetooth Audio: Yes
Voice Calling: No
Posted Mar 26, 2008 · 18:51 UTC#190
t4o6o2l you may be right.. I sent off to Samsung earlier this week to see what they had to say about it and this was their response:
"Dear Luis,
Thank you for your inquiry. We cannot guarantee complete functionality and compatibility with our phones used in conjunction with third party devices such as this. These devices may possibly cause damage to your product thus we recommend not to use the device as this may void the warranty. Samsung does not support the use of third party devices.
We do apologize for your inconvenience.
Sincerely,
Technical Support"
I knew I shouldn't have gotten a Samsung phone.
Posted Mar 26, 2008 · 23:50 UTC#191
I purchased the Pearl (through Verizon) and thought it was the answer (see earlier posts as I have tried many phones). While the Pearl Auto connects, I can't transfer the phone book (which if I have to I can live with) but I have a call waiting problem.
The call waiting keeps ringing and ringing through the car speakers, even if I answer the call or ignore it. I have to end all calls and then call someone back. This I can't live with.
Bottom line, all Verizon phones suck. I think I am goin to cancel and go w/ ATT. They can't be worse.
J
Posted Mar 27, 2008 · 00:45 UTC#192
Doesn't work..
did you remember how did you connect/register your samsung to the d3? i remembered i initiated the registration of the phone through the d3
(d3 did the search) and not the other way around . this is just an idea, i would cancel the registered phone and do a reset on the btb200 (theres a button there) and start from scratch. i dont know if that will make a difference. good luck, hope you could get it to work.
Posted Mar 31, 2008 · 02:36 UTC#193
Thanks again Tony, for the suggestions, but I've tried them too and no go. I deleted, registered the phone and reset the btb a number of times, in all different orders and nothing...
Looking through the phone's menus a little more closely I found that it can display the bluetooth service lists of devices it's been connected to before. For instance, after having paired with my laptop I can look at the computer's bluetooth service list from the phone. It includes object push which is the method the btb uses to receive contacts. The phone doesn't show object push as an available service for the btb though so, apparently, it doesn't recognize it's there (even though it is)... so I don't know where to go from there.. no help from samsung or pioneer and, even though the phone's been out for a while, I can't seem to find anything online about this... it may be time to exchange this phone.
Posted Apr 06, 2008 · 07:10 UTC#194
Anyone figure out how to connect the Palm Treo 755p from Sprint? There were a couple of posts last year but no replies.
Posted Apr 07, 2008 · 07:08 UTC#195
Yeah... Anyone.... Anyone....?????
Just tried mine tonight and got nothing by either method (searching from phone for pioneer unit or searching from pioneer unit for the phone).
They both detect one another but they just won't pair....
HEEEEEEEEEELLLLLLLLLLLP!!!!!!!!!!!!!!
Posted Apr 07, 2008 · 15:33 UTC#196
Has anyone got the transfer to work with a Tmobile Razr 2? If so can you shed some light on it for me?
Posted Apr 09, 2008 · 07:57 UTC#197
Pioneer says that a Palm Smartphone won't connect to the CD-BTB200. I tried to raise this issue with Pioneer customer service, in that there are several million Palm OS-based phones out there (Palm just sold its millionth Centro, and that's just the newest model), and that this known incompatibility could have been posted on their web site. I pointed out that there is an FAQ devoted to telling everyone that the iPhone will work, and there aren't anywhere near as many iPhones out there as there are Palm OS phones. The CS guy's reply was that marketing wasn't going to pass along negative information.
BTW, he hinted that the next generation AVIC D-4(?) would have the Bluetooth receiver built in, not an add-on module. He didn't say whether it would be any more compatible with smartphones.
The upshot is that if you have a Palm OS phone and a CD-BTB200, you're hosed. Thanks, Pioneer. Perhaps they think that I am going to dump another $1000 or so on the D-4. They can think again.
I did just purchase a Palm 700wx on eBay and am trying to make it work now. I did get it to connect and dial through the AVIC once, but I couldn't get the connection to "stick." When I tried to re-pair it, I couldn't. I will be troubleshooting this further. Yes, I did get the JetwareMobile software.
Posted Apr 10, 2008 · 20:22 UTC#198
Wow this sucks, Pioneer knew this and could have saved people with these phones the cost of the module plus install since they are completely useless, I used to have a Palm 700wx, they use Windows Mobile instead of Palm OS so maybe you have an outside chance to get it working, good luck and thanks for the info.
Posted Apr 11, 2008 · 13:04 UTC#199
there's a lil of caveat emptor so to speak.
Buyer beware. as long as Pioneer knows what phones don't work and has a list available, it is our duty as a buyer to do a lil research to find otu if it works or not.
However, I never bothered to check if there is a compatibility list.
a simple good list would be great listing each phone with what functions work. This thread is a bit of a chore to wade through
Posted Apr 11, 2008 · 15:11 UTC#200
I was bored
I went through this entire thread this morning and created an excell document based on anyone who listed their phone.
I ignored paragraph conversations and just used the ones that were listed clearly.
I'm hosting it on my webpage so i can update it regularly
http://goalielife.com/BTBComp.xls
Page 8 of 13
