CD-BTB200 & Bluetooth Phone Compatibility Guide
By Itchy · Apr 04, 2007in General💬 311 posts👁️ 131,434 views
Page 6 of 13
Posted Jan 06, 2008 · 18:17 UTC#126
Thanks toytaco. I did post in the tech help forum and u guys where right. They hooked the BTB to my remote start which turns off everytime. It took them 2 mins to change it and now it works great!
Service Provider: Verizon
Phone-SW Version: Moto Razr V3m/ NEWC_01.05.0A
Autoconnect: Yes
Basic Function: (Make & Recieve a call, Call History, Preset Memory): Yes
Phone Book Transfer: No
I saw somebody post earlier in this thread that his V3m did not work till he flashed to alltel but mine works fine without flashing.
Posted Jan 07, 2008 · 13:07 UTC#127
Is there any way to input the phonebook manually?
Posted Jan 09, 2008 · 05:38 UTC#128
I just bought a new phone today after long research lol
Phone: Samsung SCH-u740
Autoconnect: Yes
Phone Book Transfer: Full!!! I was surprised. I saw somebody else posted that it was only one at a time but NOPE it did them all :)
Posted Jan 09, 2008 · 12:36 UTC#129
Despite what I have read on this forum my new Tmobile Wing Autoconnects in handsfree mode with the latest Jetware Mobile installed (it is useless without this software) and works in handsfree mode flawlessly. I have also tried the BT Audio streaming which also seems to be functioning properly. I have yet to try both at the same time which I hear is impossible with the Wing...then again, I heard it was impossible to Autoconnect as well.
Posted Jan 13, 2008 · 06:18 UTC#130
You should look at the power conction on your BTB it is suposed to be connected to the battery terminal but it sounds like it might be connected to the accessory lead.
Question**
Even if the phone does not auto pair shouldn't it be listed on the list of phones I have registered? Because I have not seen a phone save in my list after I turn off my car....
Update**
I think there is something wrong with my Avic or BT adaptor because not even my friend's at&t blackberry pearl will auto connect. Nothing saves in the list of registered devices on my D3. Help please!?
My first question would be if you are completely registering the phone? Once your phone is connected to the BTB and at the Phone Register screen do you press and hold the user #1 field until your phone name populates it? And I also suggest hitting BACK and not ESC afterwards.
And as far as The auto connect problem, I think it is directly related to the phone registry but there are only two things I can think of once you get the phone registered. At the same Function screen as Phone Register is the AUTO CONNECT set to ON? I know, stupid question but it does not hurt to ask. One other thing is that on my phone there is an option in the BT menu, when Pioneer BT Unit 2 is highlighted for INCOMING SECURITY where I have choices to either 1. Always Ask or 2. Always Connect.
But after all that if your phone does not stay registered in position one I would say that the BTB is having a problem. Try a couple other phones? My wife's Verizon Blackberry 8830WE had no problems pairing, registering, and transferring the whole phonebook at once
Does your wifes BB 8830 run the same OS system as the BB 8130? What version OS is she running on that phone and do you think the BTB200 will run the 8130. Just curious...
Posted Jan 13, 2008 · 06:25 UTC#131
Hi, I have a D807 and I was unable to get the phonebook to transfer also with the voice calling could not hear the voce promts, any help would be much appreciated
V3xx && D807:
Service Provider: Cingular (AT&T Wireless)
Phone-SW Version: Motorola RAZR V3xx && Samsung D807
Autoconnect: Yes / Yes
Basic Function: ALL
Phone Book Transfer: Yes / Yes both one at a time.
Voice Calling: Yes / Yes
Signal & Battery Strength Indicator: Yes V3xx / Did not look at time
BT Audio Capable?: Not tested
Also Samsung Sync A707 Auto connect basic funtsion, no phonebook transfer.
Burn
Posted Jan 15, 2008 · 18:56 UTC#132
All, I have just recently purchased the Avic D3 and all is working great with the exception of the bluetooth phone. I have read all of the comments regarding pairing the phone with the avic D3. Still having troubles.
When pairing the phone, it recognizes the phone name. I can dial out on the AVIC D3 but no sound comes through the speakers. I can hear the sound on my phone.
I have a verizon 8830 Smartphone and was wondering have I truly paired the phone with the system. I even was able to register the phone but it still did not work when trying to connect the phone and hear through the speakers.
Any guidance or assistance would be greatfull.
D
Posted Jan 15, 2008 · 20:00 UTC#133
Sounds like an installation issue. Of which I am no help.
Posted Jan 15, 2008 · 20:14 UTC#134
I do not think it is an installation issue. The bluetooth on the AVIC D3 still shows invalid phone at times.
I was just curious if anyone had a similiar issue with this version of phone since it is fairly new.
Everything else works great.
D
Posted Jan 21, 2008 · 18:36 UTC#135
Service Provider: AT&T
Phone-SW Version: AT&T Tilt / 8925 / HTC TyTN II
Will not even pair as a phone. Either "connection error" or "invalid device". It pairs and works fine as a BT Audio device however.
With JetWare installed....
Autoconnect: Yes
Basic Function: (Make & Recieve a call, Call History, Preset Memory) Yes
Phone Book Transfer: Not automatic, but can push OK
Voice Calling: Yes
Signal & Battery Strength Indicator: Yes / Yes
All i can say is Pioneer sucks and JetWare rocks. This phone works fine in our BMW and Jeep without JetWare.
Posted Jan 22, 2008 · 20:56 UTC#136
Service Provider: Verizon Wireless
Phone-SW : Samsung Flipshot U900
Auto connect: Yes, most of the time. Sometimes I have to go through some menus on the phone and then it connects. Or turn off Bluetooth and turn back on.
Basic Function: (Make & Recieve a call, Call Waiting, Call History, Dialed Calls, Received Calls, Preset Memory, Search PhoneBook)
Phone Book Transfer: Yes, finally after 4hrs of messing with this option. I'm not sure the order in which I accomplished this. I kept messing with it until it finally transferred the phone book. I don't think everything completely transferred, almost everything. Some #'s wound up as just 0 for the phone number.
Voice Calling: Yes, Seems to work, but is tethered to using the phone for this function.
Signal & Battery Strength Indicator: yes / yes
BT Audio Capable?: Not as of yet. Only slightly persistent in trying to get BT audio to function.
Posted Jan 23, 2008 · 17:41 UTC#137
Phone-SW : Razor V3m
Auto connect: Yes, all the time
Basic Function: Make & Recieve a call, Preset Memory, Search PhoneBook
Phone Book Transfer: Yes, one by one, but it transfered them
Voice Calling: haven't tried yet
BT Audio Capable?: not sure
Posted Jan 24, 2008 · 16:30 UTC#138
anyone have sidekick 3 ? does it work with this ?
Posted Jan 24, 2008 · 21:26 UTC#139
Just to advise everyone I have a Blackjack and just did the WM6 Upgrade, and that killed my ability to connect to my truck.. I am downgrading right now to WM5
Posted Jan 24, 2008 · 23:02 UTC#140
Sprint Mogul 6800
ROM 2.17.651.0
radio 1.47.01
Installed Jetware and ALL the functions work including phone book transfer. Slow searching but it works.
I had a problem pairing them up for a few days...then reset the BT adaptor and all is well now! Auto connects, works 100%
Posted Jan 27, 2008 · 21:12 UTC#141
Service Provider: ATT
Phone-SW Version: Palm Treo 750 - Windows Mobile 6 Upgrade
Autoconnect: Yes
Basic Function: (Make & Recieve a call, Call History, Preset Memory) Yes, however cannot edit names to preset memory.
Phone Book Transfer: Only 1 at a time.
Voice Calling: Not yet tested
EDIT: Voice Calling works...it kinda jumbles up who im trying to call...but i think that may be the phone itself not recognizing what i'm saying.
Other Comments: Everthing seems to work. I will be testing the voice command this week. It would seem that people have problems with this phone with Windows Mobile 5.
Posted Jan 29, 2008 · 03:13 UTC#142
Service Provider: tmobile
Phone-SW Version: nokia n95 8gb
Autoconnect: Yes
Voice Calling: yes, it works... indeed it does perfectly
BT Audio Capable?: ooooh... no problems!!
Posted Jan 30, 2008 · 02:25 UTC#143
I've read that some poeple have successfully connected the Pearl 8100 to the BTB200 with v4.2. I have Verizons new Pearl 8130(just an updated pearl) with v4.3. Has anyone here tried to connect the two or should I just assume that it works since the 8100 Pearl works. I know the phones are identicle with minor cosmetic changes and a few new features.
And insight?
I was wondering if you have an update on this topic?? My new every two is up this month and the BB Pearl 8130 is my front runner. Any information would be appreciated....Thanks
Posted Feb 01, 2008 · 20:29 UTC#144
Service Provider: Helio
Phone-SW Version: Ocean
Autoconnect: No
Basic Function: (Make & Recieve a call, Call History, Preset Memory)No
Voice Calling: No
Signal & Battery Strength Indicator: No
Posted Feb 04, 2008 · 22:16 UTC#145
Has anyone tried the verizon samsung juke?
Posted Feb 07, 2008 · 01:55 UTC#146
Service Provider: Sprint
Phone: Samsung A940
SW Version:
Auto-Connect: Yes
Basic Function: Yes
Phone Book Transfer: NO
Voice Calling: Yes
Signal & Battery Strength Indicator: NO/NO
BT Audio Capable: YES
Service Provider: Sprint PCS
Phone: Palm Centro (Red)
SW Version:
Auto-Connect: NO
Basic Function: NO
Voice Calling: NO
BT Audio Capable: No,
Posted Feb 07, 2008 · 22:37 UTC#147
Phone: Motorola Q9C
SW Version: Windows Mobile 6
Auto-Connect: Yes
Basic Function: Yes
Phone Book Transfer: Yes; one at a time manually
Voice Calling: Yes, but can't hear the voice prompts over the speakers
Signal & Battery Strength Indicator: Yes and Yes
BT Audio Capable: Yes (haven't tried it, but when pairing it says this is available)
Posted Feb 08, 2008 · 01:07 UTC#148
Phone-SW Version: Motorola RAZR V3m
Autoconnect: Yes
Basic Function: ALL
Phone Book Transfer: Yes (en masse, all at once)
Voice Calling: Yes (But cannot hear voice-dialing prompts back from phone)
Signal & Battery Strength Indicator: Yes to Both
BT Audio Capable? N/A
Posted Feb 08, 2008 · 22:34 UTC#149
I am thinking of getting a RAZR 2 or a Tilt ( both AT&T) does any one know if these work :?:
Posted Feb 11, 2008 · 19:46 UTC#150
i noticed a few people here with the Moto Q from verizon but has anyone with cingular/at&t service tried pairing it yet. i would like to know if that connects. the Pantech Duo & BlackBerry 8310 as well (also cingular/at&t).
thanks guys. i would really like to get one of these once i drop my helio service.
Page 6 of 13
