Im curious on if anybody has done the phonebook tranfer wit the LG Shine VX8700??? If so do tell...
LOL. Poor Kryngle. Brutha I have been reading of your pains on this forum. As you can read above I have the VX8600 and I have looked at the manual for the 8700 and they are almost identical. You have a couple more options than I do but.....this can be done.
The most important thing is that YOU MUST BE IN THE PHONEBOOK TRANSFER SCREEN.
At the AVIC: At your BT phone screen hit the hard button MENU --> FUNCTION soft key --> PHONEBOOK TRANSFER. If you can't choose it make sure your parking brake is set.
Now go to your VX8700
PHONE: Now, this is direct from your manual. Press OK [MENU], press navigation key (down to select SETTINGS & TOOLS and press OK. Press #3 (Bluetooth Menu). I realize you are probably painfully aware of how to get there by now but it does not hurt to state what may be obvious just in case. Highlight the "Pioneer BT Unit 2" and select OPTIONS.
Hopefully you will see something like SEND NAME CARD. If that is the case then when you hit that it will take you to your contact list and you can "mark" one contact and then send it. You will have to do it one at a time but at least you are getting them over there. Have patience. Once you are done you will notice that your phone is no longer paired with the BTB. I don't know why this happens but you can just do a direct connect afterwards.
I really hope this works for you since it seems you have had this problem all month long.
Peace.
