CD-BTB200 & Bluetooth Phone Compatibility Guide
By Itchy · Apr 04, 2007in General💬 311 posts👁️ 131,434 views
Page 7 of 13
Posted Feb 13, 2008 · 21:20 UTC#151
Just wanted to add that I installed Microsoft VoiceCommand on my tilt, and while it works, i can't hear the voice prompts through the stereo. If i turn the stereo up allllll the way i can hear it faintly, but otherwise nothing. If i switch to BT-Audio mode, it comes through nice and clear, but that doesnt really help. Every volume option i could find was already turned up all the way, so i'm not sure what else to try. The program works really well, and can be activated with the Voice button in the BT-Tel screen, so if i could just hear it that would totally rock.
Posted Feb 14, 2008 · 02:48 UTC#152
Service Provider: AT&T Wireless
Phone-SW Version: Samsung SYNC A707
Autoconnect: Yes
Basic Function: (Make & Recieve a call, ) Yes
Phone Book Transfer: No & does not work with pushing 1 contact at a time either.
Signal & Battery Strength Indicator: No / No
Custom Ring tones work through the AVIC
Posted Mar 03, 2008 · 14:27 UTC#153
Anyone tried the Blackjack II for AT&T?
Posted Mar 04, 2008 · 04:10 UTC#154
has anyone used this with the T-Mobile Dash
Posted Mar 07, 2008 · 12:10 UTC#155
Service Provider: Sprint
Phone-SW Version: HTC Touch (w/ Jetware installed)
Autoconnect: Yes
Basic Function: (Make & Recieve a call, Call History, Preset Memory)
Phone Book Transfer: With Jetware I can push the whole book
Voice Calling: Yes, Seems to work, but phone commands are not ouput through car's speaker
Signal & Battery Strength Indicator: Yes / Yes
BT Audio Capable?: Not tested
Question... I can't get the Caller ID to show up on the D3... anyone able to get their caller ID up on a WM6 PPC???
Posted Mar 07, 2008 · 13:58 UTC#156
Not looking through 11 pages to see if this is a duplicate, so here'goes it:
Phone-SW Version: Motorola RAZR V3xx
Autoconnect: Yes
Phone Book Transfer: Yes. 1 contact at a time via "send contact" > "via Bluetooth" while in phonebook area in AVIC.
BT Audio Capable?: YES. No autoconnect. Set AVIC source to BT-Audio. On phone goto: Music Player. Begin song. "Options" > "Listen via Bluetooth"
Custom Ring tones don't seem to work through the AVIC...but I haven't played with it too much.
Posted Mar 07, 2008 · 23:13 UTC#157
I have, but with a different ROM than the T-Mobile factory config. I have the T-Mobile Dash, but I put on the official HTC ROM and reflashed the phone (the stock T-Mobile ROM was just too slow and had too many apps that I didn't want/need). I doubt that this makes any difference given that JetWare is a 3rd party app, but I just wanted to let you know. I believe that it should work just fine.
I used JetWare Mobile 1.31 to get it to work. I gave up trying to get it to work with the stock BT setup (maybe it will work, maybe it won't - I just didn't want to sit around trying over and over with different settings since I knew that Jetware was pretty much a sure bet).
With Jetware 1.31 Installed...
Service Provider: T-Mobile
Phone-SW Version: T-Mobile Dash (flashed to the HTC ROM)
Autoconnect: Yes
Voice Call: Yes, both speed dial and voice command
Phone Book Transfer: Yes. Jetware allows you to do all contacts at once if you wish.
BT Audio Capable?: Yes. No autoconnect. Set AVIC source to BT-Audio. On the phone: I had to enable the bluetooth audio. It does work, however.
I will also confirm that this works with T-Mobile's Samsung T809 as well (no need to install a 3rd party app). Autoconnect, make/receive calls, transfer entire phone book at once, but not BT audio capable (from what I could tell) and it will not show signal/battery strength.
Posted Mar 07, 2008 · 23:17 UTC#158
Phone-SW Version: iPhone v1.1.3
Autoconnect: Yes
Basic Function: Make calls receive calls, no voice dialing, no phonebook transfer, no data on screen when receiving calls at the head unit or making calls from the iPhone (and using handsfree set to talk).
Phone Book Transfer: No!!! iPhone will not have the ability I expect it is because it does not have Object Push compatibility.
Voice Calling: No
Signal & Battery Strength Indicator: Didn't really notice
When I bought this at Car Toys I was told that it was compatible with the iPhone. It in fact is not very compatible. The iPod part works great (with a warning on the iPhone that goes away after it starts playing). The phonebook transfer will not work for the iPhone at all and I tested the phonebook transfer with many ohter cell phones we have here and they all failed. I tested the Motorola Razr (do not know model), Sony Ericsson W810i, iPhone 4GB v1.1.3.
I believe if I had known this was the facts before i bought it I probably would have bought it anyway because I solved it like this:
I moved the iPhone (iPod) cable from the glove box to a location where I could connect it to my mounted dock and then use the iPhone in the mounted dock for the calls I need to make and receive them through the handsfree set.
In all other aspects this is a great stereo and handsfree set up.
I might add that with the AVIC D3 the idea of having to have the navigation DVD inserted to make new routes is troublesome though.
Posted Mar 09, 2008 · 19:12 UTC#159
Autoconnect: Yes
I'm having one heck of a time getting my Sprint HTC touch to work. I installed jetware and could make a call once. Now sometimes it pairs and I can make a call through the d3, but the sound is output through the phone only. However, BT audio works great and pumps through the car speakers. Also, everytime I try to push the phonebook, the system crashes and I lose BT connection completely. What am I doing wrong?
Posted Mar 10, 2008 · 12:38 UTC#160
Service Provider: HELIO
Phone: Pantech Ocean
SW Version: n/a
Auto-Connect: n/a
Basic Function: n/a
Phone Book Transfer: n/a
Voice Calling: n/a
Signal & Battery Strength Indicator: n/a
BT Audio Capable: n/a
CONNECTS AND THEN SHOWS ERROR CONNECTING
Phone: Samsung HEAT
SW Version: n/a
Auto-Connect: n/a
Basic Function: n/a
Voice Calling: n/a
CONNECTS FOR LESS THAN 1 MINUTE, THEN DISCONNECTS AND IS NOT FOUND WHEN SEARCHED, ONLY APPEARS AGAIN WHEN I RESET THE Pionner Bluetooth.
Posted Mar 11, 2008 · 20:27 UTC#161
Phone-SW Version: Tilt (HTC 8900)
Autoconnect: Yes
Basic Function: Yes (Make & Recieve a call, Call History, Preset Memory)
Phone Book Transfer: Yes, transfered entire phonebook at one time.
Voice Calling: Not sure, havent tried, dont use it much.
BT Audio Capable?: Yes, worked fine
Other Comments: Had loads of trouble with trying to connect to the BTB, until I installed the jetware software, then it worked like a charm. Only trouble I had was registering the phone (guess I should read directions.... I wasnt holding the "slot" long enough :oops: ) Otherwise, no complaints, autoconnects everytime, caller id works, direct dial works, very satisfied.
Posted Mar 12, 2008 · 13:37 UTC#162
Autoconnect: Yes
finally got my htc touch to work using the orange version of jetware. however, im not sure how to push the entire phonebook over at once. i must have read the manual 3x and couldnt get it to work. could you tell me step by step how you did yours on your tilt? thanks!
Posted Mar 12, 2008 · 18:51 UTC#163
Autoconnect: Yes
I believe that its not the phone software that sends over the entire phonebook its the jetware software.
On the Tilt I went to program files then to the bluetooth options folder. thats were the Jetware program is (on mine its labled hands free config). Go to menu and then phonebook options. In the phonebook options go to menu again and there is a send contacts item. Make sure your d3 is ready to transfer phonebook then click done on the phone and it should send everything over.
Hope this helps.
Posted Mar 13, 2008 · 00:11 UTC#164
worked perfectly. thanks!
Posted Mar 13, 2008 · 22:45 UTC#165
Service Provider: Verizon Wireless
Phone-SW Version: Blackberry 8830
Autoconnect: Yes
Basic Function: (Make & Recieve a call, Call History, Preset Memory) Yes
Phone Book Transfer: YES!! :D
Voice Calling: Yes, Seems to work, but phone commands are ouput at very, very low volume
Posted Mar 16, 2008 · 03:20 UTC#166
I just got the LG VX 8700 - and I can connect but once I shut off the D3 or my phone I can no longer auto connect.
Auto Connect is selected on the D3
Incoming security on the LG is set on always connect
I've tried all steps suggested and this one http://www.avic411.com/forum/viewtopic.php?t=11873 to a T. Still is doesnt seem to work.
could the blue tooth be shutting off when I close my phone? only thing I can think of.
HELP as I can't return this phone and it was not cheap.
thanks
J
Posted Mar 16, 2008 · 16:41 UTC#167
I just returned this phone. It had other limitations which I didn't like.
I bought the Samsung U 740. I was able to tranfer the phone book but I can't auto connect.
Any advise on how to auto connect?
thanks
J
Posted Mar 16, 2008 · 23:08 UTC#168
Phone-SW Version: Sanyo M1
Autoconnect: Yes
Basic Function: (Make & Recieve a call, Call History, Preset Memory) Yes, however cannot edit names to preset memory.
Voice Calling: Yes
On thing that I tried was that I bluetoothed my contacts to my laptop in vcard format, then paired my laptop with the D3 and promptly it allowed me to import my vcards from my laptop. However, since I cant figure out a way to share the phonebook with my Sanyo M1, it appears that all was for not. Anyone have any ideas on this?
Posted Mar 17, 2008 · 01:06 UTC#169
I just spent 2 more hrs in my car and no luck. My BB 8703e always connected.
what am I doing wrong?
everyone else said that the Samsung would connect auto
thanks
J
Posted Mar 17, 2008 · 02:01 UTC#170
Concerning Samsung, I have the A900 and it took me a few tries to get it working right. At first I did the connect to phone from the AVIC-D3, worked but would not auto-connect. Then I deleted the registered phone in the D3 and same on my samsung and instead initiated connect from my phone. it said it paired but didn't work. Finally I deleted all again and connected from the D3 with the auto-connect off, worked, then enabled auto-connect and all working great.
Only thing left to get is the phonebook transfer which doesnt work for me at all, not even one contact at a time.
Good luck
Posted Mar 17, 2008 · 02:55 UTC#171
just tried this and no luck. I must be doing something wrong.
I turned off all the features that are displayed on the bottom (auto answer, connect, echo ....) then I cleared all the phones and shut off my car. I then paired my phone w/ the D3 and then turned on the options including auto connect. I turned off my car again waited for the phone to disconnect and turned the car back on and NOTHING
this is beyond frustrating.
any other suggestions? I think I've tried everything. Parking brake on, off, half way - everything. I can pair the phone just can't auto connect (which is the most important thing to me).
thanks
J
Posted Mar 17, 2008 · 23:40 UTC#172
thanks
J
this may sound a bit trivial... but... did you register it? just making sure....
Posted Mar 18, 2008 · 02:50 UTC#173
Yes.
I was told that they changed the firmware in the Samsung and it wouldnt work w/ any blue tooth.
I didn't want another blackberry but I got the pearl. works like a charm.
thanks for all the help.
Posted Mar 20, 2008 · 02:52 UTC#174
I've got a verizon GzOne and I can't get it to bond. If I search the device through the phone it comes up, and if I search the phone through the unit it, it comes up but when I try to put in the code and bond them it says "incomplete" and won't bond. I've got an LG on there so I know it works but I can't get the address book to pull over. I'm more concerned with getting my GzOne put on. Anyone got any ideas?
Posted Mar 20, 2008 · 03:08 UTC#175
My Samsung Blackjack does'nt work with the avic-d3 it will only hook up but wont upload the phone book
Page 7 of 13
