Posted Jun 11, 2006 · 05:32 UTC#1
like ^^^says anyone with a vw or an audi self install the Z1? im curious if i should atempt this or just get it professionally done
thread said:Here's a pic pf the D1 installed but, it's coming out this weekend for a Z1. I've since modified the trim so the inner corners are sharp and not rounded.
dionga said:
Thead, Nice to see you post over here as well. I will probably be hitting you up with some questions on Vortex IM. I am ordering my Z1 today.
Does the cluster have to come out to get to the speedpulse wire??
dionga said:Do you have sat module?? how did you do the antenna?
I don't want to add an additional sat antenna and want to use my stock antenna if at all possible. I have a pkg 2 w/XM.
dionga said:Do I need anything other than the Metra 70-9003 harness adapter?
Dustin
Yep, but it's just two torx screws and a good yank.
Same as my car. You can't use the stock SAT antenna. I put the pioneer one on my dash in front of the center vent and it works great. I put the GPS antenna behind the insturment cluster so you can't see it and it also works great in that location.
Dustin
Butt splice connectors at least. And a multimeter comes in handy. To find the reverse wire just read my rear fog DIY in the MKV forum and it will tell you chich wires are the backup lights. You can tap right at the ECU and don't have to run a wire all the way to the back of the car.
dionga said:
Nice, I used your DIY for the LED tails and rear fog so I have that printed out.
Thanks for the help.
Dustin
Dustin
I'll do a DIY for this kind of install then. Sounds like it's needed. Only difference is that I've got the DIETZ can adapter so I get everything like speed pulse, lighting, parking brake, backup light, and steering wheel controls through it. But, it's $300 and we're still working out how to get the track forward and back buttons working since the MFD has to be in radio mode for those to work. Basically the DIETZ unit has to fake being a can enabled radio.
This is one of the reasons I'm getting the Z1. I hate the D1 track ahead and back "button" it's hard to get accurate when the car is moving.
dionga said:
Wonder if prices will come down on the adapters :shock:
Enfig had one coming out(maybe this is it) and it was priced like that I heard.
Too steep for me to justify at this point. I assume that I will have to tap the fuse panel for switched power? Constant should be at the harness.
On a side note, just realized that my "retained power" has never worked.
everything shuts off when I pull the key, not when the door opens as it did on my MK IV. :?
thread said:Ducatiboys mod works like a champ. Only caveat is tha ton the VWs, if you stop at ACC for a bit and then crank the switched power shuts off and on quickly and the ducati thing does not catch it. So, just go from off the crank and you're good..
thread said:I've got a multimeter, what would you like to try? Jus verifying that your circuit sends a flash pulse down the ILL wire to the HU when I go from acc to crank?
ducatiboy said:
You are sure the red wire from my circuit is connected directly to the red wire out of the Z1 right?
ducatiboy said:Well, you say when you turn the car on and wait, then crank the engine, the flasher doesn't bypass things right?
ducatiboy said:Does the Z1 reset when you crank over the engine?
ducatiboy said:Find out if the flasher circuit does, watch the orange output of my circuit with a meter.
See what happens on my circuit's boot up. Turn on the car, the output should be 0v for 1 second, then 12V for 5 seconds, then flicker a bit over one more second, then ground after that.
ducatiboy said:Crank over the engine, does the Z1 reset? Does my circuit go through this cycle again? Or is the output from my circuit 0v after that?
ducatiboy said:I'm working on a slight modification for my circuit for these issues. So far you are the second person who has had any issue like this, but I'm sure I can come up with something.
