Anonymous said:
Sloppy said:
On the bypass I used a PacTR7 basically does the same thing as ducati boys Circuit. I ran my tR7 off of the Illum wire on the Avic which I believe was the orange wire. then at first came off of that with a wire to the parking light switch even with auto healights it would'nt mess with the screen until the switch was moved, then ended up taking that off and going straight to a toggle just for more flexability. So you should be good either way you go. I also have a viper 791vx W/ Remote Start and wired up this way or with ducatiboys circuit you will have all options as long as the illumination wire gets a pulse, the bypass is good. I like the option with the toggle be able to turn the navigation black is pretty nice I like that look better than the daytime navi screen, but the toggle gives you some options instead of straight off the switch
Ok, so just to be clear on this...if I don't use a TR7 or toggle switch, and just use Ducatiboys bypass flasher, I will have access to all the functions of the Z1 even when in motion. The only thing that I won't have is when it is dark, the Z1 screen will not dim and the nav screen will still appear as daytime sky rather than changing to night sky?
Actually if you hook it up correctly you will get all the functions and it will go into night mode with the lights. I made it to replace the functioning of 2 TR7's not just 1.
If you have 1 TR7 hooked up to pulse, and you start your car and your lights go on within 10 seconds of starting the car (if you have auto headlights or you turn them on manually) you will interfere with what the 1 TR7 was about to do (tell your head unit you flashed the lights).
So what people were doing was to hook 2 TR7's up. One to flash the lights and the other to "hold off" the signal to the head unit from the lights saying they were on. So if you did turn them on (or with auto headlights at night) before 10 seconds was up the first TR7 would do it's job.
I designed my circuit to go inbetween the car and the head unit so for the first 10 seconds after starting the car, it would tell the head unit you flashed your lights. Then after 10 seconds it would pass through what the state of the lights was so it would dim and go into night mode. But my circuit disregards the state of the lights for the first 10 seconds.
So basically my circuit does the work of 2 TR7's. If you don't have auto lights and are sure you won't turn on your lights for 10 seconds after you start the car, you only would need 1 TR7. Or my circuit. Either way works the same.
