avictahoe said:Ducatiboy and sloppy,
Thanks for all the great info. You'll have to forgive me for all the questions, my experience with installing navs is very little. I've done regular single dins, but they were very easy to do in civics and integras. No modules to deal with and never had to use any form of bypasses, so these parts are still relatively new to me. I was initially going to do the install myself, but a friend of mine has a buddy who does installs at a local audio shop and is very reputable. He said they would do the install for me for free. But, since I am also going to have them install the bypass, I wanted to make sure I could explain to them exactly what was going on with it and what needed to be done. If I didn't care about the auto dimming... Ducatiboy, would there be anything different as far as your instructions on installing the bypass? Aslo, correct me if I'm wrong, but I should be able to manually dim the Z1 if it was really necessary right? Could I also manually make the nav in black, instead of the daytime white?
No problem, this was my first nav system as well. I didn't even think of a bypass or anything, till someone figured out the first TR7 setup. So I jumped in with both feet and learned real quick. :)
As for what your buddy needs to know how to install the flasher, look at the attached picture in the order post:
http://www.avic411.com/forum/viewtopic.php?t=166
There are instructions in there as well. If you want to print out the picture and tell him to not connect the parking brake wire and connect my circuit like shown in that picture. If he is a good installer this would be super easy for him to do. Once he sees that picture he will understand. The only "weird" thing is to NOT connect the parking brake wire to anything.
As for manually dimming the bypass, I don't think you can do it in settings, but if you have him hook the white input wire from my circuit through a toggle switch to 12v, when you flip the toggle switch it will go into night mode, when you flip it back it will go back to normal. But I think it's better to run it off the lights myself. But that's just a preference.
